Page 1777 of 2774 FirstFirst ... 7771277167717271767177517761777177817791787182718772277 ... LastLast
Results 26,641 to 26,655 of 41608
  1. #26641
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    The square piston is so 1970's
    Yes Husa, a 'windup' was really all I could have expected!! - at least I tried and I'm sure Luc will already be back on the drawing board feverishly working on the modifications!
    Strokers Galore!
  2. #26642
    SO Seventies!!
    And This is a Bad Thing?... because???:
  3. #26643
    9th August 2013 - 20:06
    kreidler rs 1976
    Netherlands
    Quote Originally Posted by jellert View Post
    The way you put it makes it sound like the max RPM can't be limited with the ignition. Am I right? Very interesting if that's true.
    Right, its not allowed to change ignition !
    No reason to change anything !
  4. #26644
    19th October 2014 - 17:49
    San Francisco
    I don't know when Jeff Henise will get time to reduce the size and post some photos of his killer TZ350 engine project (wobbly guided him on the design) here or on his highwaymanbikes.com website but those of you on FB can see some there
    https://www.facebook.com/jhenise/pos...55500252306228
    I've attached a sample photo.
    cheers,
    Michael
  5. #26645
    11th October 2016 - 21:23
    1974, Guzzi, 750s
    Finland
    Quote Originally Posted by JdG View Post
    70 hp without being dependent on the pipe?
    Verzonden vanaf mijn iPhone met Tapatalk
    Supersonic exhaust port.
  6. #26646
    Yes Neil, we tried several portangles.
    We still can change to the old concept of 70hp at 17.500rpm and max rpm of 30k.
    But we don't want to sell an engine which runs to easy to 30k.
    That we will leave that to anyone who want it.
    This is the current Ryger https://www.youtube.com/watch?v=RJbxxdzhESA
    So Luc you are saying there are two Ryger engine designs?
    The new one is not just a de rated version of the original?
  7. #26647
    Looks about as fast as a Clubman J motor
  8. #26648
    Any 2 stroke put up against a bunch of lawn mower engines will always look good.....
  9. #26649
    The Ryger engine answer must lie in the free piston engine. How do these engines oscillate to such high frequencies with no where near enough blow down time area. Not pipe dependent AND I would image they would be a form of HCCI once up and running under load ??
    I don't know enough about these engines apart from a few articles I've read over the years, but I understand they have a similar high pressure transfer system.
    Husa will find pictures I imagine. (I hope)
    https://youtu.be/OVWZFdb_AGc
    http://www.google.com/patents/US8127544
  10. #26650
    1974, Guzzi, 750s
    Finland
    1. Not in the patent, as sonic nozzle is not patentable.
    2. Small entry area-> longer effective working stroke.
    3. Pressure ratio is there
    4. Shapes common knowledge
    5. Flow speed at contraction mach1, but mass flow increases. No blowdown issue.
    6. Extracts heat from exhaust to accelerate flow. -> efficiency & no heat problems from exhaust. Can run it lean,
    7. Eliminates reversion, making it insensitive to the pipe.
    8. Requires an intake system that is separated from exhaust and can deliver.
    Sounds exotic, but proven technology with no foil hats required.
    Now, where is the flame suit.
  11. #26651
    some examples?
  12. #26652
    1974, Guzzi, 750s
    Finland
    some examples?
    Free design calculators all over the google. Area ratio defines exit velocity and shape is important not to have shock waves in the nozzle.
    In the 4-stroke world an engine builder (who had worked for Lockheed-Martin) claimed to have used that approach (among others) in the Bob Glidden's engines for unbeatable row of pro-stock victories. Got a lot of suspicion from experts for that claim:
    http://theoldone.com/boss429head/index.html
    Saw years ago his design for an updated port, with 1.6" ex.valve for pro-stock engine. Might still have it somewhere on my computer...
    Of course, anyone can claim anything over the internet, but what would be the reasons based in physics why it wouldn't work? It's been utilized in the aircrafts forever. Of course not applicable in the traditional 2-stroke with connected intake and exhaust.
    edit: For the efficiency side, in addition of being able to run it lean without heat issues, the inertia from exhaust will pull a vacuum in the cylinder for reduced pumping losses.
  13. #26653
    kreidler rs 1976
    Netherlands
    Yes necessary in a normal twostroke, but Ryger is not a normal 2 stroke !
    If you have read it well than you know why it has to be changed last year.
    Every user can change it back to 30k, but at his own risc.
    Beside there will be like in a normal 2 stroke much more to change, but that we leave for the experts.
    The homoligation has not been changed and ofcourse no HCCI
    If you are experienced enough, than you can eliminated what is not important.
  14. #26654
  15. #26655
    1974, Guzzi, 750s
    Finland
    Nope, normal two stroke wouldn't work with supersonic port, because you would lose pulsing and extract intake charge to the pipe, without any way to return it. Close to sonic, yes.
    Or maybe it could work timed right, but without the pipe supercharging effect. So, if you are not doing it, maybe you should give it a thought.
There are currently 122 users browsing this thread. (0 members and 122 guests)
