I'm about 10 pages behind and have to catch up on the conversation, but...
I might have had a 24/7 experience.
First(and only) dyno run with the Spx today produced 17whp. No subsequent runs because the rotary valve had come loose from the crank, and also had developed some cracks and needs to be replaced.
Last session I got 16,3 hp, and the only difference this time was a slightly thinner straight section on the needle - should not affect WOT at all.
Either the valve shifted slightly on the crank, and this was better, or it got stuck open and that was better. It was stuck shut when i teared it down.
Interesting.
Two strokes & rum!
husa, I think that luc is refering to me, some time ago I posted a direct link to the patent (pending) papers, with some comment on the drawings and all that. Luc send me a private message with the request to withdraw the name of the inventor (which -of course- anyone can read in those papers, that is the point of a patent aplication...)
I chose not to do so, because there is no point in doing so. The papers are out in the public domain since february, what is the point in acting like there is a "mister Ryger" ? That is a clear lie...
I do not feel comfortable in such hypocrisy and it is in everyones richt to discuss documents that are in the public domain.
You can not file for a patent and then think that you can do so in an anonimous way.
Now as I'm waiting for a replacement valve would be the perfect time for some research on the matter.
Wonder if I could get it started and into the powerband with a reedvalve mounted on the bellmouth of the carb? Would effectively make the carb part of the crankcase. Sounds like a bad idea, but simple enough so I'll have to try it.
Nitromethanol could be an advantage here, as long as you pour in enough it doesn't seem to be very picky about the a/f ratio.
Two strokes & rum!
There was a Jaros flow bench at Aprilia, it proved to be useless, with unrepeatable results...
And even with repeatable results it is useless.
Think of moving piston, pressure pulses, circumstances constantly changing on both sides of the piston!
The only way I found of testing various transfers was by actually making them.
And testing them for power!
The results were quite good....
Frits had posted the patent as well
You are naughty
I think luc objects to the patent being in the public domain and being discussed, which is odd as thats exactly what happens when you patent something.
if they wanted to to remain a secret they should have patented under a name not associated with Ryger.
That said if he had asked politely (or at least not utterly rudely) i would have removed the reference to the creator in what i posted.
But he didn't. Quite the opposite.
The Ryger may be the best thing since sliced bread, but with an attitude like that running the PR, people are going to think they are a scam out for quick dough.
Still think he's a troll with nothing to do with it.
Jan, did you ever try using a Jante rig with a series (or sometimes called a comb) of very fine pitot tubes that were traversed across the top of the cylinder (with the head off) whilst blowing air into the crankcase and the piston at varying transfer port heights? A static crank rig. From this a map or pattern could be generated of the upward velocity component of the scavenging flow. Sometimes also done with a motored engine, again with head off. I know Blair was a bit supportive of this method. But in the end, they also a developed a single cycle rig that motored the engine over for just one revolution and, using CO2 in the crankcase (bit hazy on this one), measured the residue CO2 in the cylinder to gauge the trapping efficiency.
Yes, we made such a rig at Jamathi, used it many years
I even 'flowed' a Suzuki 500/4 works cylinder on it that Barry Sheene brought for me to Bultaco....
When Bultaco closed it stayed there.
I can't say I missed it afterwards.....
A 'real' flow bench proved to be much more useful.
Two strokes & rum!
