Page 1786 of 2773 FirstFirst ... 7861286168617361776178417851786178717881796183618862286 ... LastLast
Results 26,776 to 26,790 of 41594
  1. #26776
    Just a thought.
    Some of you may remember when I was struggling with getting the Spx to rev and discovered the intake valve was loose and able to shift about 30° on the crank. You may also remember that fixing it made no difference at all. Almost like the engine didn't care, at least not about intake close timing.
    Frustrating then, interesting now.
    Two strokes & rum!
  2. #26777
    18th May 2016 - 19:19
    Aprilia rs 125 2000
    France
    There was a Jaros flow bench at Aprilia, it proved to be useless, with unrepeatable results...
    And even with repeatable results it is useless.
    Think of moving piston, pressure pulses, circumstances constantly changing on both sides of the piston!
    The only way I found of testing various transfers was by actually making them.
    And testing them for power!
    The results were quite good....
    Thanks for the answer mr jan, i will test this several levels, right now i test that 2 level 16 and 40 mm but you say useless for you the results are insignificant not precise enough? I look in a post you worked with a flowbench MCF what difference with jaros?Thanks
  3. #26778
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Quote Originally Posted by Greg85 View Post
    With the MCF you measure the total flow in duct or ducts.
    After many years of using flow benches I think they are most useful for developing exhaust ducts.
    I can not see the usefulness of a Jaros bench....
  4. #26779
    Aprilia rs 125 2000
    France
    Thank you mr jan for your informations
  5. #26780
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Jaros seems interesting for the symmetry of the flows of the transfers.
    But maybe it does not matter?
  6. #26781
    The bellmouth startup reed.
ID:	331992Click image for larger version.
    Just a proof of concept.
    I actually made this a couple of years ago as a cure for hard starting with late intake close timing. Soon after I realized my problem was a massive case leak, and never tried it.
    Two strokes & rum!
  7. #26782
    a bit more sophisticated than using your hand... nice
  8. #26783
    The bellmouth startup reed. Just a proof of concept.
    This is very interesting, looking forward to hearing about the results, could be good......
  9. #26784
    Can you get a VForce model?
  10. #26785
    Anything is possible but what good would a VForce reed do? Once the engine is running on the pipe, the reed is removed anyway.
  11. #26786
    Think he's joking Frits 😀
    Two strokes & rum!
  12. #26787
    Frits the term "running on the pipe", at what point can you deem this is happening?
  13. #26788
  14. #26789
    oh of course... you cant explain it with words either... thats why i asked Frits.
  15. #26790
    you don't really need words though......... who is this frits character
    if Frits was here he would say something like its when all the results of the volumes and the wave actions from lengths and durations that result from either complex math or painstaking trail and error or both finally start to work in unison to produce a pitch perfect HARMONY
There are currently 50 users browsing this thread. (0 members and 50 guests)
