I can imagine a reed valved engine making more power without the obstruction of the reed in place - but does a rotary valved engine benefit in the same way? A rotary valve, when open, gives no more resistance to flow than if there was no valve at all... and if the longer duration does give a power increase wouldn't this have shown up in the timing tests that so many have done?
A long time ago, when most two strokes were piston ported, I experimented with intake timing and found that too much intake duration helped the top end but also killed the bottom. At low RPMs they'd load up easily from double or triple carburation and lost a lot of torque. On a race bike I guess this isn't a problem if it can be kept on the pipe. The standoff was quite noticeable in Alex's video; it'll be interesting to see where in the rev range it clears up. I can't wait to see the dyno results.
Thanks!
Haven't been this excited for a long time!
As long as it can rev into the powerband with no load this should work.
Good point!
With my setup what's going on below or low in the powerband isn't too important.
Guess it boils down to if ever increasing intake duration when rpm rises beyond peak power is beneficial or not.
If you had a "variable with rpm" rotary valve, how would you set it up beyond peak?
Two strokes & rum!
In the video it looked like some of that blue mixture in the squirt bottle was dripping into the brown mixture in the glass. Good video.
Two strokes & rum!
My H100 broke a steel reed. Started as easy as the pie I'm currently eating. Actually it's more a corrnish.
Did notice a stutter up top that sent me searching. But that's a small section of a 4 petal reed. Not a gapping hole.
Having experienced load up on a piston port bike which on race start, bogged unrecoverably until the clutch basket was replaced I'd expect a similar load up if thrown too much load quickly. Auto clutch no idea how they behave.
I thought you had no chance of starting that. Until it burbled time before.
I would have lost some money there.
Makes me wonder about the 256 that would either start or tire you out pushing.
Now I guess if the engine was TPI, this over rich situation wouldn't happen.
I'm sure off the pipe performance must be compromised?
What's the story about Cagiva running reeds that didn't clise all the way? To hurt explosive power? Was that on EFI or carb?
Here is the story Jonny:
https://www.kiwibiker.co.nz/forums/s...post1131051402
And here's a better one I initially missed (thanks Husaberg):
https://www.kiwibiker.co.nz/forums/s...post1130474766
If you know, or can guess, on which site to search, this works fairly well in Google: [word you are searching for] site: [site name]
Here is what I entered in Google Search in order to retrieve the post you were asking about:
Cagiva site: https://www.kiwibiker.co.nz/forums/s...s-engine-tuner
Google still came up with 133 hits that I had to plough through, but hey, what's a little effort between friends?![]()
The better explaination is here
as you were.........15 seconds.........
I used Cagiva reed and user name Frits Overmars
i knew you had posted it here though
Mine is currently set up to start grabbing well into the powerband, hoping that'll work.
Without that burble I would have given up after a few more pulls and tried the reed. We would never have known that it could start without it.
Luckily my fuel is pretty tolerant to rich running.
Too bad it's difficult to test off pipe performance with my current setup.
Really looking forward to seeing how it behaves on the roller!
Two strokes & rum!
When do you plan on running the engine and seeing what happens and if it is ride-able?
Neil
There are currently 137 users browsing this thread. (0 members and 137 guests)
