Page 1794 of 2776 FirstFirst ... 7941294169417441784179217931794179517961804184418942294 ... LastLast
Results 26,896 to 26,910 of 41630
  1. #26896
    [QUOTE=JanBros;1131058426]when starting, the throttle valve is down and almost completly closes the crankcase. one could say that their is only a small "leak" : not enough to push everything that the piston moving down is pushed out through the carb and so some make it into the cylinder
    is it possible that a fluctuating pressure differential between the leaking through the carb at btdc and atmosphere is occurring, performing a pumping action?
  2. #26897
    18th July 2015 - 16:21
    2015 Avanti
    My cousin was in a really bad accident when the throttle would not close, the ignition was disabled, it continued to the wall flat out.
    It was put down to the platinum iridium plugs that they were using at the time. Model glow plug engines have been know to start
    from dead cold from time to time when people put the starter on to them. I have seen a near flooded engine start from just flicking it over.
    These engines that have easily started were using just methanol and castor oil. Engines that run the 10% to 30% nitro definitely restart
    easier and will do so upto 10 seconds from the engine stopping and just a flick will make them restart without electrically igniting the glow plug.
    Model engines usually use a fuel shut off to stop them.
    Something that has been over looked , but is easiest done with EFI is to stop the fuel to shut down the engine. It is a good idea to develop some
    form of fuel shut off that closes the main jet by some yet to be developed means could be a good thing.
    I know it does not happen very often, an auto ignition situation, but if it is you that goes into a wall and then spend the rest of your life in recovery mode
    is no fun at all.
    Discussion is always good though and seeing other peoples experiences.
    Neil
  3. #26898
    Two solenoids, one cutting off supply to the carb, one dumping the floatbowl into suitable place would do the trick. Could be connected to the ignition kill switch.
    Might make something like that if I ever get on the road...
    Two strokes & rum!
  4. #26899
    28th November 2013 - 21:58
    Dawes Jaguar
    UK
    Old aircooled VWs had an "Anti-dieseling solenoid valve".
    And, Mazda have just announced their new "Compression Ignition Petrol Engine" that only uses plugs for starting and cold running...
  5. #26900
    Dawes Jaguar
    UK
    Fletto, absolutely. Well done Alex.
    Aways wondered if this one actually ran or even started. (was a simple Ozzie mod to make a Beeza Bantam to put out more than 3 hp)
    Attachment 332112Attachment 332113
    Funny when one sees a reed valved 125 kart engine not even start/run properly when a reed tip has broken off. Maybe the starting was due to being cranked with an electric starter, whereas that muscly Alex was probably spinning his at well over 2k rpm at least. (Probably could have done more, but didn’t want to wake all his kiddies).
    Maybe for KZ racing one could have a reed valve made with some material that would fail (eg a condom, preferably new ) that would pass thru the engine with no damage and then be 24/7 from then on, gaining its 5 hp.
    So many things to try. 1 hour to go til the Moto GP starts, been a bit starved of late.
    Not exactly a performance engine - this is from an article called "The Old J80 Johnson" and elsewhere he said it was a 1hp outboard:
    "The old motor ran good too... first pull,
    hot or cold... had to work the choke and sihgle
    needle valve with some expertise. My grand-
    children and I took it to Lake Iamonia on my
    old Grumman Sport boat to see what it was
    like.Though it thrummed the aluminum pretty
    good, it didn't vibrate nearly as bad asl ex-
    pected. It is one of those primitive old
    slow-speed, two-cycle engines that aspirates
    right into the cast iron cylinder when the little
    two inch piston opens the port at the bottom
    of the stroke.
    Since the fuel doesn't go through the
    crankcase like modern two cycle engines, all
    that is lubricated by an expostulation of oil
    and gasoline (8o2., a small Coca Cola bottle,
    to the gallon) from the cylinder at each com-
    pression stroke through little tubes to both
    crankshaft bearings and through holes in the
    crankshaft to the connecting rod joumal, wrist
    pin, and all, like a four cycle engine with an
    oil pump... kind of marvelous.
    There are no seals on anything (except a
    regular adjustable, leather packing gland,
    "Chicago Rawhide" on the propeller shaft) and
    that makes it smoke out from under the fly-
    wheel a little bit while it is cold but when it
    warms up, it is cleaner running than a British
    Seagull. It has a dry exhaust and you can see
    how much it is smoking and lean it on down
    with the big-knob style needle valve. Got a
    big aluminum take-apart muffler sort of like a
    Model T which it is good to avoid when you
    have to tilt it, that and the spark plug and the
    flywheel."
  6. #26901
    http://newatlas.com/mazda-skyactiv-x...gnition/50803/
    Didn't say anything about 70k rpm though..
  7. #26902
    Still using spark plugs but.
  8. #26903
    Question:
    Pvl analog ignition,
    Is there any way to get more meat out of the spark?
    I´m at this point using no resistance things thoughout whole system
    Getting misfires when trying to reach more power at this point.
    I have gapped the plug down to 0.3mm, under that it starts to misfire at idle.
    But it still misfires above 74hp(engine hp)
    I have tried different plugs and different setups with resistors, best is totally free from resistors and non iridium/platinum
    plugs.
    I have also tried a ignitech ignition, it had no juice at all, but big possibilities of upgrades, but i felt that if everythings getting beefier the bike gets heavier and gained power would be eaten up by weightincrease so i ditched that
    The PVL is an '458' with 4000 windings, and the curve seems to work just fine therefor i would like to give it a chance.
    Rgds
    Patrick
  9. #26904
    Question:
    plugs.
    Rgds
    Patrick
    What coil?
    Maybe you could try one with higher primary-secondary winding ratio?
    Two strokes & rum!
  10. #26905
    I knocked this up the other day.
    It's just a prototype to test whether the twisted belt arrangement is capable of high revs.
    To my surprise, it was untroubled by blips to 14,000RPM and sustained 12,000 for a few seconds.
    Here's a video of it running: https://youtu.be/7Ffs1x145zw
    I set the timing to: Open 135º BTDC, Close 80º ATDC, but once assembled, I found it was 5º late (at both ends, obviously) so it ran a bit hairy. I can fix that of course. Main object was to prove the belt drive.
    I have no idea whether this setup will provide more power, although I suspect it might produce a better mid-range curve.
    I'd appreciate any comments or advice.
    Dyno time needed...
ID:	332132   Click image for larger version.
ID:	332133   Click image for larger version.
  11. #26906
    Dyno time needed...
    Nice!
    Two strokes & rum!
  12. #26907
    Dyno time needed...
    Very clever .... looking forward to seeing it at the track.
  13. #26908
    Gordon Bennett. Looks good. Supposed to be dirt riding Sunday but if its too wet might get some dyno time in. Or one night.
  14. #26909
    Dyno time needed...
    Nice, x2....
  15. #26910
    What coil?
    PVL 458 coil.
    I dunno the exact function of PVL´s coils, but they have some sort of internal electronic that one could say very simplified has a function of a cdi.
    From stator to coil there is only two wires that controls everything *lol*
