Page 1799 of 2776 FirstFirst ... 7991299169917491789179717981799180018011809184918992299 ... LastLast
Results 26,971 to 26,985 of 41630
  1. #26971
    Did anyone say blowback?
    I will make up a bunch of different length carb spacers to see where that gets me.
    Pah! You're still using a carb? Get outta here grandad. The scooter kids are clearly the real trail blazers. Next attempt; no head fitted.
  2. #26972
    If I inject fuel directly into the EGT fitting maybe I can get the pipe to work as a scramjet. Could do away with the whole bike and just ride the pipe. Would need a serious slingshot to get it into the "powerband".
    But seriously.
    I'll play around with intake length and jetting. If it doesn't lead me anywhere I'll put it on ice for a while and get that replacement valve.
    The charge is pushed out of the carb with quite some force.
    First this had me thinking that in no way will I be able to "stop" it with just a longer intake.
    But thinking about it now, charge going in the right direction is probably pushed in with similar force.
    Maybe there's not that much required to "tip the scale"?
    I mean all I need is to stall the outgoing charge, not reverse it.
    Two strokes & rum!
  3. #26973
    4th May 2016 - 21:50
    Bultaco Metralla GT
    I guess it might be possible to use an intake tract long enough and small enough to let the engine pull itself onto the pipe. But then it'd lose a lot of power when it was on the pipe..
    I can't help thinking the whole diskless thing is a solution to a non-existent problem. Sure, a reed valve is obstructive but I'm not convinced there's much to be gained by deleting the disk. Maybe with enough work a no-disk engine could be usable but I suspect it would remain compromised, and the necessary kludges to make it work could well be more complex than the disk itself.
  4. #26974
    19th June 2011 - 00:29
    I
    maybe fit a rotating disk with a cut-out between the carb and that big hole ?
    I guess that would stall the outgoing charge
  5. #26975
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    If you really want to know the answer to what is happening, ask Jan (I'm sure he has tried everything - and he isn't saying much) but then, that would spoil all the fun of finding out! If you just want to fool around with different possibilities, then carry on I reckon.
    (BTW I like to try everything - well, I did a long time ago,- it didn't get me far, but it was a very enjoyable pastime).
    I do like your enthusiasm and videos!
    Strokers Galore!
  6. #26976
    16th February 2017 - 14:26
    2002 Yamaha YZ250WR
    Brisbane, Australia
    But seriously.
    Wacky idea but hear me out, what if you put a cone that expands outward from the carburettor so the air/fuel escaping the carb is pulled out even more, then attach another cone to the first cone, but the other way around, to 'bounce' the air/fuel back into the carb? Perhaps make it from plastic, variable length. You might need to lean the carb out a lot, since the air will be travelling through it many times.
    I made a rudimentary drawing.
  7. #26977
  8. #26978
    5th January 2007 - 14:58
    motocompo
    Buttfuck nowhere
    You could drive it off the end of the crankshaft & experiment with the cut out timing to gain peak performance!!!
  9. #26979
    heres a oil question. i had been using 6% oil in methanol and decided to try 9%. i didnt notice the engine run any better or worse so i thought of trying 12% next time. if nothing else maybe the bearing and cylinder bore might last a bit longer. what do you guys think of this idea ?
  10. #26980
    21st August 2014 - 13:28
    2001, Honda, RS125
    Melbourne, Australia
    maybe the answer lies in the valveless pulse jet's "inlet"
    sorta getting back to the origins of the expansion chamber here
    or a tesla valve on the inlet
    This might be making the motor increasingly a single speed motor however
    I was really hoping this would work. maybe with a secondary, electronic throttle slide or something like Flettner's variable timing slide.
  11. #26981
    No. No. I like it.
    Then maybe fit a sparkplug that goes every 5 seconds to reduce the surprise of the inevitable
  12. #26982
    What oil, and are you dissolving it in a solvent before adding it to the methanol ?
  13. #26983
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    Another video about the Maxda HCCI engine:
    https://www.youtube.com/watch?v=9KhzMGbQXmY
  14. #26984
    klotz benol 100% castor and klotz super techniplate which is 80% synthetic-20% castor. they are intended for petrol, methanol, nitro methane. they can be mixed to atleast 18% oil content when used in methanol or nitro. im pretty sure the super techniplate is what some rc fuel manufacturers like VP are using, although the msds sheet doesnt say specific name brands. it dissolves just fine but beyond 18% i think it gets to viscous and some kind of thinner oil is used, thats my understanding anyway. i just figured with the corrosiveness of methanol and nitro why not use more oil if the internal components last longer.
  15. #26985
    2002 Yamaha YZ250WR
    Brisbane, Australia
    No. No. I like it.
    Fire on both sides of the piston = more power?
    Maybe put the carb on the inlet end of the theoretical chamber so it's not so fuelly.
There are currently 66 users browsing this thread. (0 members and 66 guests)
