Page 1805 of 2773 FirstFirst ... 8051305170517551795180318041805180618071815185519052305 ... LastLast
Results 27,061 to 27,075 of 41593
  1. #27061
    20th June 2012 - 00:17
    yamaha
    Hey guys thanks in advance for your thoughts
    Im working on a new head for our vintage skis and I have finished the drawing except for the combustion chamber shape.
    From the reading on here from people who are clearly in the know I will be using a toroid shape chamber. My question however is there a magic number when it comes to squish band ratio.
    Or what is the effect on the power of having the squish band ratio to much or to little.
    Please note im not talking about clearance its the ratio of squish to combustion chamber I am after.
    Cheers
ID:	332299   Click image for larger version.
  2. #27062
    Squish width is dependent upon how much piston clearance you have.
    I have found that a calculated MSV of 38M/Sec gives the beat result in most cases.
    To achieve this number you start with the clearance and keep increasing the width until the velocity is correct.
    What is your bore/stroke/clearance/com.
  3. #27063
    yamaha
    Thanks Wobbly
    my bore is 75mm
    The stroke is 60mm
    My projected squish clearance is .9 mm
    The engine will rev to about 7500
  4. #27064
    With those numbers I get 57% SAR = 13mm wide.
    The effect of excessive MSV is that in effect the added chamber turbulence is the same as adding advance,the result being lack of overev.
    The excess volume trapped in the squish also burns too late in the cycle to create as much power as the energy could do if it was done correctly.
  5. #27065
    Interesting. That sounds like there's a formula. True Wobbly? Or are you simming it?
  6. #27066
    There are plenty of calculators available on line, but the best rule is to drop the clearance to the point that the piston will just clip the head
    when overeved, thus the clearance will be zero in effect.
    In that big bore short stroke ski engine only reving to 7500, the safe limit would for sure be closer to 0.8 mm, and then the width can be reduced to around 10mm.
    This gives the same MSV, but way less mixture is trapped and not contributing to making power.
  7. #27067
    So knowing nothing is skis one would expect over-rev would be king. I'd guess single gear and you have several props maybe adjust final drive so it matches what that prop can turn at without cavitating. But with it all being a guess how rough it will be having over-rev would make it more tolerant.
  8. #27068
    yamaha
    Thanks alot wobbly. i really appreciate it
  9. #27069
    19th June 2011 - 00:29
    Cheers
    no exhangeable combustion chambers? seems like a missed opportuniy.
    I made one for a KR1S :
    http://kr-1s.co.uk/forum/viewtopic.php?f=2&t=11307
  10. #27070
    yamaha
    It looks great
    Whats the crush you ran on the domes to make them seal properly
  11. #27071
    yamaha
    Ok well this is the combustion chamber finished
    Thoughts and constructive criticism is most welcomed
  12. #27072
    RSW and RSA ducts were the same. Roof angles did not change since 1995.
    What did change, were the leading directional angles of the A-transfers. Aiming them more away from the exhaust port proved beneficial.
Name:	FOS scavenging concept.png
    ... it becomes clear that all the work done by hand in the R&D dept to match the Blowdown flow numbers with the transfers gave a highly synergistic scenario.
    That hand work in the Aprilia Racing Dept. included modifying every dimension of every port in 0,25 mm steps over a 10 year period; not something you are likely to equal by yourself during a winter season... It would take the likes of Honda to put in a similar effort. But Honda could not manage.
    So in a way you might say that it was Jan Thiel who drove Honda to ban two-strokes from GP racing .
    There are plenty of calculators available on line, but the best rule is to drop the clearance to the point that the piston will just clip the head when overeved, thus the clearance will be zero in effect.
    Indeed, there are a lot of Mean Squish Velocity calculators available on the internet, but I haven't yet seen a single one that takes the dynamic stretch of a high-revving engine into account, and it makes a lot of difference whether your squish clareance is 0,6 mm or 0,06 mm. As a rule of thumb that stretch will be about 0,1% of the stroke, assuming that your crankshaft is sound. I agree with Wobbly: reduce the squish clearance until you are going to suspect that the piston may be kissing the head. Then there will be zero clearance and zero mixture in the squish band. And you won't get detonation if there is nothing there to detonate .
  13. #27073
    yamaha
    Indeed, there are a lot of Mean Squish Velocity calculators available on the internet, but I haven't yet seen a single one that takes the dynamic stretch of a high-revving engine into account, and it makes a lot of difference whether your squish clareance is 0,6 mm or 0,06 mm. As a rule of thumb that stretch will be about 0,1% of the stroke, assuming that your crankshaft is sound. I agree with Wobbly: reduce the squish clearance until you are going to suspect that the piston may be kissing the head. Then then will be zero clearance and zero volume in the squish band. And you won't get detonation if there is nothing there to detonate .
    Thanks Frits
    I have told people about that before. That the squish being at zero at high rpm and they say it causes deto. I always reply " whats going to deto"
    I have set the head for .9 of a mm in clearance and my eyes are about to fall out of my head from to many hours drawing hahaha.
  14. #27074
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    We did that test on a 26 cc racing engine that developed peak power at around 18,000 to 19,000 rpm. We ran the over rev to 23,000 rpm and found that the piston hit the head button with .05 mm clearance. since the stroke was 28 mm that's about .2% of the stroke.
    The engine had 4 main ball bearings and caged needle bearings on both ends of the rod. The big end bearing may have had its clearance increased a little to help it live.
    Lohring Miller
  15. #27075
    Experience will of course overrule rules-of-thumb, Lohring.
    I've witnessed Kreidler engines with reputedly stiff crankshafts, but with angular contact bearings, that needed at least 0,7 mm clearance for their 39,7 mm stroke;
    I've also tested Rotax engines with a 54,5 mm stroke and 0,4 mm squish clearance, that merrily revved past 14000 rpm without the piston touching the head.
