Page 1813 of 2774 FirstFirst ... 8131313171317631803181118121813181418151823186319132313 ... LastLast
Results 27,181 to 27,195 of 41608
  1. #27181
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Having all 3 of the Ex ports closed by a PV in effect reduces the blowdown to virtually nil.
    This works OK in a MX situation, where the engine is used well off the pipe and the low PV setting reduces the really bad effect of the pipe being way to short for the rpm.
    In a roadrace engine the combination of the open Aux port with the PV down in the main port, allows a usable amount of blowdown at the lower end of the powerband.
    Then the PV is lifted over a fairly wide band of rpm, giving a much wider powerband ,in the range that is used on track.
    The Aprilia, and many other engines using this setup,they dont have the PV all up until about 1000 rpm before peak power.
    Yes Wobbly, exactly!
    By the way, did you already test the ceramic coated exhaust duct?
    And what was the result?
    Is there any news about TM's 'uncooled' exhaust duct?
    Regards, Jan
  2. #27182
    I dont recall a single protest in Chch buckets in the last 15 years, that doesnt mean there is no reason for them as i have seen plenty of evidence that not everyone plays by the rules, the score is still zero
    Levels has a nice big scrutineering shed....how do you feel about stripping the first three in the BoB ?
    Back in the 90's we stripped the whole field of 250 production - with some amusing results....
  3. #27183
    Wouldnt worry me, but then Im not entering this year. Up to Cams to do what they want. Wouldnt hurt, bit expensive for the FXRs to reassemble
  4. #27184
    My MB wouldn't raise many eyebrows except for the triple exhaust port and rather conservative timings,. But full story would take more than a strip down.
  5. #27185
    Hi Jan, I have been flat out building test pipes for TM, as well as doing the record breaking 350cc Pre 81 Land Speed Project at Bonneville.
    Thus I have not been able to remove the test cylinder from the dyno to get it coated.
    Franco is way too secretive to tell me I think, if his non cooled duct was a failure or not.
    But i will ask, as soon I have a result to show him - wont be long.
    I had originally been obsessed with getting over 50 Hp along with plenty of overev power, but the 30mm carb seems to prevent any real
    extra peak power.One pipe made 49.6 and had 6 more at 14500, but on track that was barely faster.
    So I have been hard at work trying to get more front side power, ie going up to the peak.
    Here is where I am at now, and building/dynoing this pipe today.
Name:	Stock Vs Pipe R.jpg
  6. #27186
    16th February 2017 - 14:26
    2002 Yamaha YZ250WR
    Brisbane, Australia
    the 30mm carb seems to prevent any real extra peak power
    If the carb is restricting airflow, could you use an additional volume in the intake after the carb to reduce the peak velocity through the carb but increase the average velocity?
    Maybe a helmholtz resonator tuned to the peak, with a valve so it doesn't affect the rest of the range.
  7. #27187
    Rob
    We'll the TF inlet is a mess anyway with piston port and then a big hole in the floor for the reed.
    I needed to fill in the manifold I'm using so made up this taper. It's hardly a shallow taper but will do as a stopgap and maybe be the 2nd trailing part of venturi.
ID:	332470   Click image for larger version.
ID:	332471   Click image for larger version.
  8. #27188
    First stumbeling tests with turbo.
    Fueling issues.
    Need to revert to gasoline i guess.
    If idling for a long time, i figure the fuel(methanol) drops out of airstream and then when hitting throttle the engines takes a big gulp.
    One can fix this with heating the inlet manifold, but heck,, the engine isnīt warm yet, nothing to heat it up with(coolant water)
    Leaning out the jet donīt work, yes it runs nicer, for a while... but after some revving the engine runs out of control and need bigger jet to idle at lower rpmīs.
    Gasoline doesnīt have this issues, well a little but not this big.
    However, in posted video i got it to run(not letting it idle) and it made 0.4bar boost(5.9psi) just holding the throttle(end of video)
    I later leaned it out a bit and got a whole 1bar boost(14.7psi)
    But i never got response from idle good.
    Iīll switch to gasoline for a test.
    I can use methanol for cooling later on if needed(meth/water injection).
    I dunno if you can hear it, in the end when boost hits it revs up a little bit more(12800rpm).
    Before that the pipe 'keeps' it on ~12000rpm
    Rgds
  9. #27189
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Fueling issues.
    Rgds
    is the engine fuel injected?
    i'm over buckets
  10. #27190
    That looks the business......
Name:	The Business.jpg
  11. #27191
    No, simple Mikuni VM44 as it is in video.
    But with added powerjet and 'ufo' plate.
    And high flow floatvalve.
    Rgds
  12. #27192
    The problem with the 30mm carb on the KZ engine is that the inlet is as short as it possibly can be, and it is connected to a reed
    that is capable of over 50 Hp.
    Thus no room for any divergent duct.
    The current setup has alot of area infill from the stuffer, keeping the area pretty constant right up to the petal curtain area.
    I am trying all manner of test shapes using 3D printed inserts with various wings and guides,as the best power is had using very soft top petals
    along with stiff lowers.
    This biases the flow upward toward the transfer duct entries.
Name:	KZ10 Reed Stuffer.jpg
ID:	332487   Click image for larger version.
Name:	Wing Stuffer.jpg
  13. #27193
    8th July 2013 - 11:01
    2001, Aprilia, RS250
    Oz
    What material are you printing in for petrol resistance Wobbly?
  14. #27194
    The best material I have found so far is ABS,that has then been vapor blasted to seal the surface.Cheap to.
    But i have a Nylon one coming to try as well.
    This is fine for testing, but if I was to use it long term then I believe the simplest way would be to spray paint the surface with a 2 pot epoxy
    like automotive clearcoat - havnt looked into it in detail yet.
  15. #27195
    12th October 2016 - 01:24
    1964 Vespa GS
    San Francisco
    I've found Nylon holds up quite well around the carb, been playing with 3D printed bells on Vespas for some time.
