Page 182 of 2774 FirstFirst ... 821321721801811821831841922322826821182 ... LastLast
Results 2,716 to 2,730 of 41610
  1. #2716
    Do you think it necessary to have the plenum between the carb and the crank case ? Wouldn't a "pressurized" airbox be of benefit, without the risk of 1,5 liters of petrol vapor blowing your leg off..
    Not being a naysayer mind you.. Just trying to work through the nuts and bolts of it.
    the plenum has more air behind the carb ready for the engine to draw from instead of being choked by the carb. A pressurized air box would help but not as much. you could have both maby
    as for it blowing your leg off, how big is the crank case volume and why dosent that blow up ?
    why would a plenum be any more likely to go bang ?
  2. #2717
    4th February 2005 - 07:32
    Rattlecan blue
    I know there has been a fair bit of chat on here lately about forced induction two strokes of one sort or another but the rule book turns it into an interesting diversion and nothing else really.
    To whit
    All engines must be
    normally aspirated except F4 4 stroke engines of less than 100cc capacity, which may
    be turbo or supercharged.
  3. #2718
    To whit
    All engines must be
    Plenum is not forced induction
    I think thow there is a 100cc 4stroke in the works with a turbo ( but that has to come after everything else. and there is a lot of everything else)
  4. #2719
    Is that a Kawa 100 or 125 bottom end maybe???
    Yea its one of those
  5. #2720
    Rattlecan blue
    I know that a plenum is not forced induction but there has been plenty of spirited discusion here lately about turboed kreidlers and the like.
    I'm not suprised you guys have plans for a blown 100 either, you seem to have either plans or work in progress on just about every possibility.
  6. #2721
    I have had a bit of experience with blown motors over the past few weeks, blown FXR, G4 and blew my KC100. I think they are overrated , just seem to be constantly rebuilding them
  7. #2722
    Rattlecan blue
    I know it;s been said before but f*ck you guys are hard on gear down there.
  8. #2723
    10th December 2008 - 07:39
    07 fz6n. 07cbarrrr600
    STRAYA
    Crankcase volume would be at a guess 1.5x (or there-abouts) the cylinder volume ? Plus with the restriction of the carb and whatever valving is sealing the crankcase, I imagine it would be a bad bad day if a crankcase ever popped.
    Dunno, this is just me thinking about it, it just seems a bit dodgy having a big chamber full of vaporized fuel quite near to the exhaust. I mean obviously the concept works and it has potential..
    Shh, just ignore me.
  9. #2724
    ........Dunno, this is just me thinking about it, it just seems a bit dodgy having a big chamber full of vaporized fuel...........
    Yes at the first look its not a pretty thought, 1.5l of fuel/air mixture would be an explosive problem in a confined space and definitely dodgy but with the blow off valve and the carb there are plenty of places for the ignited gas to escape before it reaches an explosive pressure.
    Having seen a few "Pops" I think the plenum is about as dangerous as a small backfire in a 4-strokes muffler, more fun than dangerous............
  10. #2725
    ........the plenum has more air behind the carb ready for the engine to draw from instead of being choked by the carb.............
    Thank's Buckets4Me, that's it in a nut shell................ a real simple concept when you think about it.
  11. #2726
    Another turbo 50 , might struggle round mt wellington but makes 20+ hp
    http://buddfab.net/buddfabhomepage.html
  12. #2727
    Yow Ling, thanks for the link you sent me, lots of interesting 50's on that one too. http://forums.autosport.com/index.ph...c=98711&st=200
ID:	218745   Click image for larger version.
ID:	218744   Click image for larger version.
ID:	218743   Click image for larger version.
ID:	218742   Click image for larger version.
ID:	218746   Click image for larger version.
  13. #2728
    A supercharged 1937 DKW and supercharged 1936 water cooled 500cc 2-stroke Scott from Britain.
ID:	218875   Click image for larger version.
  14. #2729
    STRAYA
    That Scott looks pretty damn cool.
  15. #2730
    Pretty interesting blog about some guy building his own moto 2 engine , untill they changed the proposed rules to one make engine. He decided to carry on and finish the project anyway
    http://moto2-usa.blogspot.com/
