Page 1869 of 2773 FirstFirst ... 8691369176918191859186718681869187018711879191919692369 ... LastLast
Results 28,021 to 28,035 of 41589
  1. #28021
    20th June 2012 - 00:17
    yamaha
    We tested a lot of different fuels on an industrial style 26 cc racing engine. Because we could only change the mixture and ran the same pipe for all tests, there was very little power difference. The mixture needs to be richened for alcohol containing fuel. Below is the report.
    Lohring Miller
    Attachment 333886
    Thank you, interesting reading
  2. #28022
    Hello guys this I my first post!
    I've followed this thread for a while and you guys seem to keep up with a lot of fun stuff.
    I'm doing a small hobby project that is a bit out of my comfort zone (a rotary valve 100cc V-twin 90 °).
    I was wondering if there is someone who has some heads up regarding twin rotary valve assembly?
    best regards Johan
    Part by part, had an ambition to start it in 2018 but feels far away.
    Attached Thumbnails Attached Thumbnails Spräng skiss 2.pdf
  3. #28023
    Looking good, Muhr.
    But I would leave the red plastic parts out if I were you. You do not need the crankcase volume reduction, and what's worse, they are shrouding the big end bearings that need all the lubrication and cooling they can get. I would also remove the cover over the crankshafts: better for lube and cooling, and better for the flow of the mixture between the crank webs.
    You are right about 2018 being far, far away. First we will have to eat ourselves through a shipload (I spelled that deliberately correct) of turkey and accompanying carbohydrates. But don't worry: it doesn't matter how much you eat between Christmas and New year, as long as you are careful between New year and Christmas.
  4. #28024
    Looking good, Muhr.
    You're probably right, the plastic is 10.8cc a piece. I'm at about 263cc now TDC managed to get them very even with the offset disc.
    I want some material on thecover left to make adjustments afterwards
    Me and food have always been best friends
  5. #28025
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    V2
    Where you going to place the rotary valwe? At both case sides? Or modify crank disk in the middle...
  6. #28026
    11th October 2016 - 21:23
    1974, Guzzi, 750s
    Finland
    Perhaps this is one of those out there, but anyone tried spraying metered amount of mixture to the ex port to extend pipe range?
  7. #28027
    Does the engine then become a generator for a pulse jet ?
  8. #28028
    1974, Guzzi, 750s
    Finland
    Was thinking more like simply adding heat for something like high compression ratio engine.
  9. #28029
    Like this.
    Attached Thumbnails Attached Thumbnails Spräng skiss 3.pdf
  10. #28030
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    I present you the work of a French tuner on exhaust pipe.
    I translated the text as best as I could
    The following graph shows the parent dimensions of the expansion pipe of several modern and efficient engines
    the engines are very different:
    - since a KX 500 1989, which must be rather progressive and having a modest relative power (for the cubic capacity)
    - up to a Honda 125 RSR 1997 racing bike who makes 40 hp and who favors above all the maximum power
    The shape of the pots is nevertheless very similar: the proportion of diameter (difference in diameter / deviation maximum diameter) as a function of the proportion of length (length / length "reference") follows almost always the same law:
    - the position of the midpoint of the divergent is constant (68% of the reference length)
    - the position of the midpoint of the convergent is constant (124% of the reference length)
    - the length of the second half of the divergent is constant (25% of the length of the reference)
    - the length of the first half of the divergent is at least (25% of the reference length)
    - The length of the convergent is also constant (34% of the reference length)
    - length of the right part (14% of the reference length)
    The proportions in parentheses are an average of 35 engines, of which 10 are represented on the graph. This average is the red "reference" curve. These proportions are used to determine the dimensions of the pots afterwards.
    It remains more to determine the length
    I have complete information on 7 engines: all the dimensions, the curves of torque and power, the pressure readings in the exhaust:
    On average, the peak of the pressure wave is formed at 1/10 of the exhaust time (thus 18 ° crankshaft after the opening of the exhaust (OE) for an exhaust of an opening time of 180 ° ).
    After several tests of recipe, the "benchmark" constant of all these engines to wedge the motif of the pattern of pressures and depressions with that of the openings and closures of the port is the following: the cross between the depression and the pressure, which correspond at the rate of 10% before the closing of the transfers (FT) (10%: 10% of the transfer opening period). I give you a grace of physical interpretation. For those interested in it can talk about it more.
    That is why I took as reference length, the length between the exhaust port and the center of the right portion (since the piston therefore, including the duct in the cylinder, the flange of the cylinder, the tube or elbow , the divergent and half of the right portion).
    We know when the pressure wave is emitted (10% after OE), we know when it must return from the middle of the right portion (10% before FT). The formula for calculating the reference length, very simple from the desired speed and the speed of the wave, is written on the following page.
    All of these values are set at the maximum speed power peak, because it is more available information and easier to use than another system. So the regime to take into account is the one wanted for the maximum power regime. If we want the maximum torque regime, it will be necessary to change the 10% (calculation to be done).
    Full version => http://as3-rdx-club.clicforum.fr/t90...DE-DETENTE.htm
  11. #28031
    1997 Yamaha rd 350
    Russia
    V2
    Like this.
    Thanks Muhr. Me thinking about placing cylindrical rotary valve at medium of cranckshaft to both functions:
    separate volumes
    regulate intakes.
    BTW I made Excel spreadsheet to calculate balance of 2-cylinder engines. At my case V2 90 generates 4 time less shaking force than just one half of V2.
    I have rather short connecting rods L=73 for 40mm stroke.
  12. #28032
    Looking good, Muhr.
    Do you know what crankcase volume the old gp 50 bike had like the Kreidler gp 50?
    Thank Frits
  13. #28033
    I present you the work of a French tuner on exhaust pipe... Full version => http://as3-rdx-club.clicforum.fr/t90...DE-DETENTE.htm
    I rather enjoyed that lecture, and it'll do your French some good as well. But we must remain critical, for example:
    - since a KX 500 1989...- up to a Honda 125 RSR 1997 racing bike who makes 40 hp
    So the most 'modern' engine in that lecture was a 20 year-old Honda that was 14 hp down on state-of-the-art power.
    The outcome of any averaging will always be worse than the data of the best engine in the bunch. Sometimes averaging is sensible; sometimes it isn't .
    Are we talking about the twelve-speed works Kreidler of 1960 or the Van Veen Kreidler of 1983, or somewhere in-between? Never mind, I have not memorized those values for the good reason that they all were too small.
    The Aprilia-values that I know off the top of my head, may be more useful to you. The RSW125 had a volume of 650 cc at BDC, including transfer duct volumes, and the RSA had 675 cc. For a 50 cc that would work out as 270 cc. But if you are going to try that, you will also need porting and pipe efficiency as high as the RSA's....
  14. #28034
    1988 cagiva freccia
    france
    The article I present and translate is not mine.
    I think interressant to share it here
  15. #28035
    Really good information, I'm going to start a little shy, then go bananas! Getting up to the RSA level is probobly many peoples goal(dream). It's just that it's damn far away!!!
    I was thinking of the Van Veen
There are currently 116 users browsing this thread. (0 members and 116 guests)
