Page 1871 of 2776 FirstFirst ... 8711371177118211861186918701871187218731881192119712371 ... LastLast
Results 28,051 to 28,065 of 41633
  1. #28051
    Quote Originally Posted by varthrix View Post
    Hello everybody, I was going to refrain from posting until I had read the whole thread, but I'm only about 700 pages in and I have a question. Tee Zee, I saw the post about moving the ring positioning peg and that it went wrong, if you were going to do it again what approach would you pick to do it?
    This thread is best read backwards, that way you get to the good stuff first. Page's 500, 1000 and 1500 are worth a visit.
    And there are thousands of pictures you can look through if you use the thread tools.
    What went wrong, poor workmanship and the retaining tip of stainless wire I used fractured from vibration.
    If I was to try again I would use the Yamaha racing TZ approach of drilling down from the top and piano wire with the tip bent over in the hole. Piano wire wont fracture like the SS did.
    I couldn’t find anything with the search function, but it's probably my fault. Greetings from Bulgaria.
    Emess posted a very helpful tip for searching this or any other thread.
    Rather than use the site search which usually fails, use Google so to search this site use an ordinary search phrase and after it add
    site:www.kiwibiker.co.nz
    Frits pisa site:www.kiwibiker.co.nz
    the same will work for other sites with the appropriate site address
  2. #28052
    I had the same problem with setting up the Ignitech static timing on an old Ducati.
    What you need to do is using a straight edge,line up the center of the timing cover and the middle of the trigger pole, and make a mark on the
    cover gasket face.
    Then fit the cover, and transfer that mark onto the engine gasket face.
    Again, using the straight edge, line up the rotor center and the new mark on the engine, this gives you the trigger position in relation to
    the trailing edge of the lobe on the rotor ( with the piston at TDC ).
    Measure the base timing angle using a protractor ,or trig, or using piston position height with the center line and lobe edge lined up.
  3. #28053
    29th December 2011 - 04:14
    rd 350 ypvs 1985
    netherlands
    Hi all,
    engmod question time again...
    Turbulent mode, I still don't get it.
    I start with a 'simple' cbd file, run it in engmod, get result (purple line) Put it in turbulent mode, run engmod and get a result, (black line) looks good, fine.
    Write the new combustion file, load it in dat2t, set it on prescribed burn rate and... I get this result (green line)
    And I can't figure out what is happening or why cause I a. don't understand what engmods magic is doing and b. what the chicken or the egg is in the differences I see (tubmax, delivery ratio etc.)
    What am I missing?
ID:	334097   Click image for larger version.
ID:	334098   Click image for larger version.
    O no, red pilled...
  4. #28054
    Thanks Wob, that makes good sense. With an asymmetric cover I'll lengthen the crank somehow to provide a tit I can engineers blue a centre point to mark on the inner cover.
    Which means draining the oil again, oh well. A path ahead. Cheers.
  5. #28055
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    KTM engmod file
    wobbly:
    Thank you very much for the KTM 250 RR engmod file. But when I try to unpack it I'm getting a message that the engine file is incomplete and I get a bunch of error messages. I tried to unpack it again but no go. Could you resend it when you have the time? Thanks Jeff
  6. #28056
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Jeff,
    You need the latest version, I sent out update notification yesterday. If you did not get it let me know. The notification is via bulk email with links which gets blocked by some firewalls.
    Vannik
  7. #28057
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    V2
    If I go whit the left web it will give 23cc more and same weight/balance factor
    BTW what is the best possible, but still easy to get material for disk valve? Me experienced in reeds, but 0 in disks.
  8. #28058
    Hi all, engmod question time again... Turbulent mode, I still don't get it. I start with a 'simple' cbd file, run it in engmod, get result (purple line) Put it in turbulent mode....
    Hi Ief, those Engmod pics look rather familiar. You don't happen to be working on a Dutch 50cc twin, are you?
    Carbon. It used to be hard to get, but nowadays you can simply order it: http://www.emot.nl/.
  9. #28059
    3rd August 2012 - 02:39
    yzf 250
    holland
    Yes Frits looks familiar
    Change AV gas to regular
  10. #28060
    https://www.rockwestcomposites.com/p.../401-410-group
    https://www.carbontech.com/
  11. #28061
    rd 350 ypvs 1985
    netherlands
    Hmm, what gave it away?
    Saw Dutch posted some numbers so figured I'd give it a go.
    Regular, ok. Not related to what I experience I presume.
    O no, red pilled...
  12. #28062
    1980 Suzuki Gs1100E
    SWPA
    EngMod update
    Hello Neels:
    No I did not get your update notification. I also tried to contact you using your form on your website but it doesn't seem to work. I am using Windows 10 if that helps you. Thank you very much.
    e-mail is jneilan46@gmail.com
  13. #28063
    yzf 250
    holland
    Looks very simulair Ief
  14. #28064
    rd 350 ypvs 1985
    netherlands
    Oh, I see I've got some work to do, is that with a realistic model you'd say?
    Having detonation issues as is
    Changing to regular lowered my dip with 1000 rpm, otherwise no change.
    On we go
    O no, red pilled...
  15. #28065
    yzf 250
    holland
    Then go to Premium
    After installing the update from Neels lots of deto
