Page 1875 of 2776 FirstFirst ... 8751375177518251865187318741875187618771885192519752375 ... LastLast
Results 28,111 to 28,125 of 41631
  1. #28111
    That would imply that the blowdown period lasts all the way from exhaust opening to where the piston reaches the exhaust floor. Then at the end of blowdown,
    the transfer ducts will be completely filled with exhaust gases, and it will take a similar amount of time and crankshaft degrees, i.e. from BDC to transfer closure,
    to expell those exhaust gases again. In other words: the 'scavenging' will be performed with exhaust gas only. I can guarantee that no engine will run like that.
    Of course you're right.
    Could we postulate that, at peak power RPM, blowdown is complete by first transfer opening? Wouldn't that be the ideal situation for best power?
    Assuming (and hoping) that your exhaust duct diameter is smaller than the bore, then the duct volume will be a lot smaller than the cylinder volume. And this would imply that part of the washed-through charge makes it into the hot exhaust header before being shoved back by the pipe effects. Not quite what you want.
    Yes, I was mistaken in thinking that Wobbly had said that duct length is usually about 1 x bore. He actually said 2 x bore. In which case my duct is very short, and as you said, must negatively affect washed-through charge.
    Should the volume of the duct be related in some way to the capacity of the cylinder? Would the efficacy of the pipe effects also be a factor, since this must affect the volume of washed-through charge?
    If I find a way to extend the duct on my (water-cooled) engine, can I assume I must also find a way to cool it?
    Thank you for your advice.
  2. #28112
    13th September 2016 - 00:30
    a lot
    somewhere over the rainbo
    The exhaust duct of this engine has a bit of a bottleneck about halfway down, whose CSA is about 66% of the port window area.
    If you got an exhaust port that is too small for sufficient blowdown (undersquare engines with single exhaust f.e.) reducing the cross sectional area behind it will make things worse. I have seen engines benefiting over the whole power band from grinding the flange diameter bigger as 90%.
    So the percentual approach needs a sidekick: a rule of thumb how big your exhaust area must be according to your cubic capacity.
    This rule of thumb might be found using Time Area or Wobblys approach to get the area of carb, transfers and exhaust in the same ballpark. But this ballpark gets wide whilst comparing a bunch of high bmep engines...
    A friend told me that in an old version of Mota, there was a good working formula for the needed exhaust window size and exhaust flange diameter. Anyone here that knows the maths behind it?
    Happy Holidays
    Chris
  3. #28113
    V-twin
    Hey all
    I'm doing some work with the exhaust systems, I am thinking of doing a few different for testing.
    The first system I have thought of is with a shorter register to cylinder B, don’t not know if it's stupid but felt like it might be good,
    but what do I know about 2-cylinder applications or V twin for that matter.
    Thankful for thoughts and ideas!
    It will be a variator engine with peak at 15800 rpm (2x50cc 41 stroke)
    Muhr
    Attached Thumbnails Attached Thumbnails exhaust 12.pdf   exhaust 8-Scene 4.pdf
  4. #28114
    My cylinder has been decked and raised, so the bottom of the exhaust port is already 2mm above BDC, but of course this has not reduced the duct volume. In fact, by the time I widen the top of the port, the volume will be even larger.
    I hesitate to try and raise this floor further by other means, as I know of no published experimental data on the effects of the floor being higher than about that amount. I believe Jan tried 2mm on the RSA125 with some improvement but did not go any further than that.
    Rotax Max kart ( engine without gearbox ) original cylinder - 2.2mm barrier.
    And two other pic: pressure at partly open EX port and reed petal shape at different rpm. From old book, but interesting theory and experimentation.
Name:	Rotax Max kart 2009.jpg
ID:	334232   Click image for larger version.
ID:	334233   Click image for larger version.
  5. #28115
    Someone help me!
    I´m redesigning my crankcase as i had a HUGE volume due to ~20mm spaced upwards cylinder.
    I´m reading '1.3' here in the thread.
    Is that cylindervolume x 1.3 ?
    In my case 211x1.3=274,3cc
    Or have i misunderstood the way to calculate it?
    Rgds
    Patrick
  6. #28116
    Someone help me!
    Rgds
    Patrick
    (slagvolym + vevhusvolym "bdc)/ vevhusvolym "bdc= comp
    in your case (211cc) 703,3cc BDC = 1,30001422
  7. #28117
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    Attachment 334208
    Got my Arduino Nano project working Ok on the test bench.
    Computer programming, who said an old dog can't learn new tricks ...... Woof.
    Always impressed by what you do TZ, good doggy, very clever.
  8. #28118
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    he told me he would get more done if his tired sons helped him out(-;
    i'm over buckets
  9. #28119
    Hey all
    Muhr
    I recon that your setup would be used for "moped" drag racing?
    Anyway, it looks to me that such a wheel would have a rather high moment of inertia. Perhaps you could improve your results using a different wheel setup?
  10. #28120
    Thanks!
    I had it all confused there for a while
  11. #28121
    Quote Originally Posted by _____ View Post
    If you got an exhaust port that is too small for sufficient blowdown (undersquare engines with single exhaust f.e.) reducing the cross sectional area behind it will make things worse. I have seen engines benefiting over the whole power band from grinding the flange diameter bigger as 90%. So the percentual approach needs a sidekick: a rule of thumb how big your exhaust area must be according to your cubic capacity. This rule of thumb might be found using Time Area...
    Chris, from your text I gather that in your 'undersquare' engine the bore is bigger than the stroke, but that is usually called oversquare.
    There has been confusion over this before but if we stick to long-stroke and short-stroke instead of undersquare and oversquare, we can avoid this ambiguity risk.
    Regarding your suggestion to base exhaust duct cross flow areas on blowdown time.area, that is what I keep preaching. But as I wrote on the previous page, Wobbly's approach has its reasons too.
    PS: good that you signed your post with your first name; I would not have paid attention to scribblings from an anonymous contributor .
    Благодарю вас Katinas
  12. #28122
    In disregard of Ryger phenomena with a single exhaust port and huge rpm, I'd say yes it would.
    Yes, and yes again.
    That would be good.
  13. #28123
    It may look like they are heavier then a standard wheel but the are actually significantly lighter, and friction is relatively low.
    Having said that, I do not know if it's something I'm going to use. However, I wanted to make sure it was possible if you wanted to.
    I do not know what to do with the engine the trip is the goal.
    Maybe it will be something to go to the store with.
    Attached Thumbnails Attached Thumbnails exhaust 14.pdf
  14. #28124
    21st October 2017 - 20:27
    S51
    Bulgaria
    Frits, I have a question about your FOS pipe, before I knew about this thread someone sent me a link to http://www.underdogsracing.com/fospipe/ I used it to calculate a pipe, but used the 5 stage experimental calculator thinking it would be better. The pipe was almost complete, but got stolen from my place along with a lot of other things. My question was should I make the same pipe again, or should I use the original FOS formula? With the 5 stage calc I came up with this.
    The hp figure is a bit generous I think, it's a Simson S51 motor, with a different sleeve to accomodate a 44.98 mm piston, which is due for rebore now, 6 transfers with okay scavenging now, it was really bad before but I need to work on it a bit more and fix the transfer timing to 130°, either using jbweld or by machining 1 mm from the cylinder base (it's 134° now), running a 28 mm pwk carburetor and a reed valve from minarelli horizontal which I think has insufficient area for the given carburetor, but I'm not really sure how to calculate needed reed petal area. Husaberg had posted it should be 0.8 reed petal area per 1 carburetor area.
    Kind regards from Bulgaria, Jordan.
  15. #28125
    18th May 2016 - 19:19
    Aprilia rs 125 2000
    France
    hello mr vannik is engmod2t compatible with any windows?Thanks
