Page 1876 of 2774 FirstFirst ... 8761376177618261866187418751876187718781886192619762376 ... LastLast
Results 28,126 to 28,140 of 41606
  1. #28126
    i use it with windows7 and it seems to do fine
  2. #28127
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Quote Originally Posted by Greg85 View Post
    hello mr vannik is engmod2t compatible with any windows?Thanks
    Win XP and newer. I cannot test on older so do not know. 32bit and 64bit.
  3. #28128
    18th May 2016 - 19:19
    Aprilia rs 125 2000
    France
    Thumbs up
    thanks peewee, vannik for the information
  4. #28129
    18th August 2015 - 20:39
    2005 honda hornet
    italy
    Question to Wobbly & Frits working on a TM KZ10B:
    using this link (http://www.underdogsracing.com/fospipe/) just posted i tried to find setting for having right parameters (similar: only lengths are not correct but total and central lengths are right) with the fixed pipe in homologated fiche. But setting are a lot of distance for the reality about "target HP" (72 ) and "Lcyl" (the real is 60.25).
Name:	TM KZ10b Pipe.jpg
    So, why this pipe have these measures? What TM want to get in this way?
  5. #28130
    Quote Originally Posted by varthrix View Post
    Frits, I have a question about your FOS pipe, before I knew about this thread someone sent me a link to http://www.underdogsracing.com/fospipe/ I used it to calculate a pipe, but used the 5 stage experimental calculator thinking it would be better.... My question was should I make the same pipe again, or should I use the original FOS formula? Jordan.
    Jordan, all these programs claiming to calculate a FOS-pipe were created without my involvement.
    Moreover, several of those programs are based on obsolete data, so I won't comment on any of them. Here is my recent version.
Name:	FOS exhaust concept.png
    Quote Originally Posted by ranasada View Post
    Question to Wobbly & Frits working on a TM KZ10B: using this link (http://www.underdogsracing.com/fospipe/) just posted i tried to find setting for having right parameters (similar: only lengths are not correct but total and central lengths are right) with the fixed pipe in homologated fiche. But setting are a lot of distance for the reality about "target HP" (72 ) and "Lcyl" (the real is 60.25).
    Ranasada, see my above answer to Varthrix.
  6. #28131
    21st October 2017 - 20:27
    S51
    Bulgaria
    Thank you for the quick answer Frits, I will do some calculations later when I have the time. What would you say about the reed valve area I asked about? I'm thinking of ditching the reed valve altogether, seeing people from Germany making 20 hp from 85 cc Simson engine with piston port, I should be able to get at least 10-12 hp from my 70 cc engine.
    Also I hope it's not a problem that I'm calling you by your first name, read a couple hundred pages ago that you like to be referenced by your first name.
    Sorry for all the questions, kind regards Jordan.
  7. #28132
    Piston port induction will be fine for getting 10 to 12 hp from a 70 cc engine. If you're not careful, you will get more power than that.
    I haven't got the faintest idea about the dimensions of a 'Minarelli horizontal' so I cannot comment on your reed valve question. Maybe Wobbly can help you there.
    And I still prefer to be called by my first name .
  8. #28133
    The TM-B pipe you have shown is not close at all.The stinger of a stock engine is 24mm for example.
    And a stock B will make around 44HP @13200 at the sprocket thus the crank power will be only +5% on this.
    The big issue with the engine is the straight line ignition and this dictates the pipe is VERY short for peak power at 13200.
    I cannot give you any more info at this point as my very expensive video card has let out the smoke - due to constant use on EngMod
    to design the D model pipe for TM.
    Hopefully I will have a new 5MHz overclocked rocket computer running in the New Year.
  9. #28134
    S51
    Bulgaria
    Frits, sorry about missing out on information. I just measured up and came up with this.
    Reed petal area - 243.09 mm2
    Total reed petal area - 972.36 mm2
    Area of reed cage entry from carburetor flange side - 930 mm2
    Reed lift 5 mm
    Reed cage angle 60°
    Reed stopper angle 16° ( Relative to the reed itself - assuming it's flat (0°))
    Carburetor area (28 mm bore) 615 mm2
    Inlet port area 619 mm2
    So pretty much I have no idea if the reeds are suitable, got them for about $3, everything I did on the engine was in the spirit of buckets - low or no cost and diy. Most expensive part I bought was the carburetor - 50$. Even the cylinder liner was free, found an old wheelcart bushing and machined it on the lathe. I hope I can squeeze out some power out of it, there is a word that there will be a Simson cross race this year and if all is well I hope that I can participate.
    Attached a drawing of the measurements, excuse my poor drawing and writing skills.
    Also thanks for the time spent helping me out.
    Kind regards
    Jordan
  10. #28135
    24th December 2017 - 09:10
    Triumph 1955 T110
    Adelaide Australia
    Yamaha RD48 and RD56
    Hi All I hope this is a good spot to put this , I am trying to find some information about the Yamaha RD48 and RD56 engine A 250cc Disk valve twin, 1961 to 1964
    The crank diameter and length
    Disk valve diameter
    conrod length
    piston compression height
    would any one know if any of these motorcycles sold to customers or purely works bikes
  11. #28136
    Presumably you've read this
    https://www.amazon.com/Yamaha-Racing.../dp/1852239204
    Can't imagine any escaped the clutches of the factory.
  12. #28137
    Quote Originally Posted by Twopints View Post
    Disk valve diameter
    conrod length
    To the best of my knowledge neither the RD48 nor the RD56 were ever sold; they were pure works bikes and it won't be easy to find any information about them after more than 50 years. The best I can do is a couple of lists and drawings from the RD56 and the 125cc RA41 which had the same relevant dimensions as the 250cc RD48. Working from the known bore dimension you may be able to extract approximates of the other dimensions you were asking about.
Name:	Yamaha works machine code numbers.jpg
ID:	334333 Click image for larger version.
Name:	Yamaha racers 1962-1984.jpg
ID:	334334 Click image for larger version.
Name:	Yamaha RA41 1961-01.jpg
ID:	334335 Click image for larger version.
    You made me curious: what are you planning to do with those dimensions? Build replicas maybe? And while you're at it, you might tell us a bit about yourself as well.
  13. #28138
    Disk valve diameter
    conrod length
    Pretty sure the "Dutch Yamaha Fairy" has built a replica
    https://www.pressreader.com/australi...83102773739289
    http://www.classicyams.com/early-fac...56-250-cc.html
    http://blog-883r.jp/archives/52479023.html
Name:	Yamaha-moto-Yamaha-cylindre-piston-m%C3%A9canique-Yamaha-moto-de-course-250-RD56-cylindre-quatre.jpg
  14. #28139
    2005 honda hornet
    italy
    Moreover, many of those programs are based on obsolete data, so I won't comment on any of them. Here is my recent version.
    Quote Originally Posted by Wobbly View Post
    thank you Frits and Wobbly for your answer.
    i take misures from homologation form for finding setting in inversal way having fixed pipe, so i find that the big problem is on D5 (from Frits attachement) that is 26 and it is for more than 70hp. Why so bigger?
  15. #28140
    I suppose the diameters on that sheet are external. Internal diameters on a homologation sheet wouldn't make sense; nobody would be able to check those without cutting the pipe up.
