This info from NTN and INA on crankshaft needle bearings may be of use:
http://www.ntnglobal.com/en/products...f/2300E_03.pdf
https://www.schaeffler.com/remotemed...pi94_de_en.pdf
I think one problem with using KT100 pistons is the process where a piston which is only a very small amount larger is fitted after a hone, and then the next one and the next one and so on. The bore changes shape slightly each time it's used and the hone simply changes the surface texture. I think it would be worthwhile to have the bore ground in a cylindrical grinder every 2nd piston to maintain it's cylindrical shape and remove any taper that may develop. I quite like the look of the Burris pistons but don't know that they are actually any better. They can certainly extend the life of a cylinder due to the increased clearance required versus say a Yamaha piston. there might be some slight difference in the shape of the crown requiring a different head.
Thanks Mike, duly noted. This has been a simple overbore to match the supplied piston, so that shouldn't be an issue this time. I'll bear it in mind for future replacements though.
I make my own head inserts to match whatever piston I'm using, so that also shouldn't be a problem.
If you are running a regulated return system what if you plumb the top side of the regulator (boost reference) to the pipe??? This is how a lot of turbo 4T adjust the fueling as boost rises and falls...maybe it would work the same with the pipe on the 2T. As pipe pressure rises, so would fuel pressure and hence more fuel. If the pipe collapses then pressure would also, so the fuel pressure would drop as a result.
I think the purpose of the manifold pressure referenced regulator is not to supply more or less fuel but to keep it constant, if you have 3.5 bar of fuel pressure and 1 bar or boost the rail pressure has to increase to 4.5 bar to counter the 1 bar on the nozzle, and likewise if you have vacuum in the manifold the rail pressure decreases to maintain a constant pressure at the nozzle, this means the computer does not have to account for these changes electronicly
What would be best gasket material - cylinder to header? BTW chainsaws use thermal screen beetween muffler and cylinder.
Possible as well cover header by simple basalt tape
https://www.amazon.com/Titanium-Basa.../dp/B0022QOY0C
Question. For simple muffler and 2-stroke. What is optimal stinger diameter for simple lightweight exhaust systems?
Or what optimal back pressure in muffler?
Saw one interesting idea http://www.dragonfly75.com/motorbike/stingersizing.html
Can anyone help me with an ignition timing map for a TZ250 5F7
The cylinder to do the Exhaust Port thermal barrier coating test has been at HPC for over week ,and they now say it wont be done till mid next week.
I to am hanging out for the result, and will have it on the dyno the same day it arrives.
The deto sensor will tell immediately if it goes into destruction mode or not.
Re stinger size and pressure.I have measured several engines and found that 2.5psi at full noise seemed to be a constant.
But the process is a bit counter intuitive in that less pressure in the pipe ( ie a big stinger ) renders the pipe less "efficient " at low rpm.
Thus when the return wave comes back to the piston face too early at lower speeds this reduced pressure also reduces the power loss due to the wrongly timed stuffing process.
Increasing the pressure ( a smaller stinger ) makes better power higher up.
This is used in the Jetski world to good effectby having a oversize stinger, and using a rpm controlled solenoid, water is than dumped into it to increase the back pressure at higher engine speeds.
PWM valve control makes it even better.
Easy way to size a stinger ( or nozzle settup ) is to look at the Mach number in the restriction using EngMod, 0.8 Mach works best every time.
There are currently 103 users browsing this thread. (0 members and 103 guests)
