Page 1897 of 2776 FirstFirst ... 8971397179718471887189518961897189818991907194719972397 ... LastLast
Results 28,441 to 28,455 of 41632
  1. #28441
    At last I've got all measurements of the ports in place! It's amazing how much time you need to get all angles and area in place. Thank you Frits for the amazing library of pictures and drawings you posted on the RSA and RSW over the years.
    Does anyone have any tips or experience regarding the design such as wall thickness or the like?
Name:	Skärmavbild 2018-01-25 kl. 21.05.22.jpg
ID:	334910   Click image for larger version.
Name:	Skärmavbild 2018-01-25 kl. 17.08.21.jpg
  2. #28442
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    this is all good stuff , thanks for sharing
    Mr B, - mate you could have said that easily with one line, we didn't need to have the whole bloody scenario all over again, once was enough!
    I say put it all to rest and lets get on with the thread as it should be, it was going well!
    Now go and answer MUHR's question!
    Strokers Galore!
  3. #28443
    Obviously you do quite a lot Same as with the Ryger - mucho blabla to convince people of your amazing achievings. you have to be a great guy to hang out with...
    I'm using 15 mm on my 50cc. Diameters below that value killed overrev, the engine was hard to jet and build up heat like crazy. So far I'm not sure if the increased backpressure is needed.
    This is 14,7mm
  4. #28444
    3rd August 2012 - 02:39
    yzf 250
    holland
    This is 14,7mm
    Yes smaller as 16 mm is worse
  5. #28445
    27th January 2011 - 11:30
    asdasd
    AKL
    This is 14,7mm
    KTM SX?
  6. #28446
    KTM SX?
    No that piston i from a Malossi
  7. #28447
    Scooter friends. I have a 2001 Aprilia Ditech Morini. I'm looking for a big bore cylinder that has ability to go 50mm. 47mm is max off the shelf 70cc kit. I know I'll have to bore cases for bigger than 47mm.
    Problem is I'll need a cylinder that a Ditech head will fit. Do you know of any cylinder that I could use?
  8. #28448
    Scott is just stirring, feeding the Troll its called. he doesn't care.
  9. #28449
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    no , i like what he made , face it you all did , what the hell went wrong ?he never bought the rygar into this thread , you lot did , so what if it never made what it intended , face it he got it going , runs not to bad , with more work you never know , i thinkl shame on the lot of you the way you lot be carrying on . treat others the way you like to be treated !
    i'm over buckets
  10. #28450
    asdasd
    AKL
    Thought that cylinder in the background was a KTM. Looks a lot like the (slow) engine project 50SX of mine.
  11. #28451
    20th September 2015 - 03:19
    1981 Vespa p200
    San Diego, CA
    To my knowledge there has never been a 100% bolt on solution for this. One could assume a non-ditech morini big bore kit of same vintage would be a good start.
    I would scrap the morini and fit a minarelli or piaggii carb engine
  12. #28452
    It´s always good to have metal to grind in, that´s my advice =) (experience tells me that one is never happy with the porting)
    One thing i would try is some coolingfins on exhaustduct to increase heat dispertion into the surrounding water.
    rgds.
  13. #28453
    rgds.
    I tested to do a little different variants to the exhaust side but was questioning if the risk of film boiling was too big? is that something you have experience with?
  14. #28454
    Thumbs up
    You're right, a real sniper! Did not even notice it myself, but it's another project
  15. #28455
    9th August 2013 - 20:06
    kreidler rs 1976
    Netherlands
    Thanks mr Bucketracer, and for everyone to know Ryger has not finnished at all, it just has to start !
    And I'm glad that there are still people who realy can read and not only bla..bla.. bla.... without reading well !
