Just thought that I'd share this....
The NSR150 has a rather short exhaust duct according to Wobbly's explanation of what's needed. So I've modeled and adapter up that bolts to the exhaust duct exit to lengthen the duct to 1.5*bore and as and when I have time I'll CNC something up and give it a try.
3D printed out a sample last night for a test fit. Seems ok.
I've done a couple of models of different "effective diameters" @ 1.5*bore, so it'll be interesting to see what happens on the dyno.
Also took the theory of cooling the duct and added a water passage. This'll mean mods to the std cylinder to allow water to get into the adapter. I'm temptered just to add a couple of spigots to it for now and just flow water through it. Saves me a bit of work for first test
I'll also have to adjust the pipe to compensate for the longer duct, but that hopefully shouldn't be a task. But if I just change the header length (minus the additional length of duct), without any other changes, that'll give me a 4 degree included angle header. Any comments on this?
Anyway, here's a couple of pics.
I'll let you know what happens.
Matt.
The edge angle of the piston I have is more than 15deg. Would need to check. So, I meant the angle between piston top corner and the tip of the top. Because the shape is rounded the tangent at the piston corner is more. The dome begins ~1mm towards the center from the piston corner.
The raising column speed is definitely something that didn't even cross my mind. As the lower speed translates to higher pressure, I can see how that would be better for less mixing of the fresh charge and exhaust.
I would also think that the higher dome not only shifts the direction of the transfer flow upwards, but also makes the jet flatter forcing it go around the dome and begin the pressure recovery sooner than what would happen with the free jet. How much flow losses this would cause is hard to say, as the directional change does not happen in the duct and more gradual pressure recovery may also be a good thing from the flow perspective, but it probably messes up the designed scavenging pattern. Considering higher surface area of the combustion chamber with the dome and painstakingly designed scavenging for a lower dome piston, it's predictable that the end result has to be worse.
I've struggled to find a good piston with the right compression height for the 44mm bore. Now I have another bottom end, where I could use 5mm longer rod and that would allow using kx60 piston. My cylinder, however, is cast iron and I'm a bit concerned if the ring(s) meant for nikasil would cause me problems. As the piston is such a stressed part and elemental for the performance, I think I need to find a better solution.
The current B-port angle is 15deg before grinding, so I could relatively easily test it with the stock bottom end, then grind and re-test to see the impact with the current piston.
http://www.tz250.com/forums/showthre...A-kit-cylinder
but it can be made to fit rather easily it seems. see link above.There was a major cylinder change at 1997 I think and the stud spacing will not allow newer cylinders on the older 1995-1997 bikes (I think).
But you might be far better off with a 04 PV CR125 cylinder.
Testing on original cylinder in simplest way, just add profiled sleeve on cylinder to isolate crankcase , blocked intake windows and increased boyesens. A and B sum area equal to 31 mm dia.
Much better, would be made straight transfer ducts on both sides of cylinder with two carb, but cutting, welding and so on need more time.
And eventually, maybe its just revs without power.
Thank you Husa for this RS/CR collection
Thanks Husa
always on the hunt for a cheap 04 125. ended up getting a 05 250 instead
be interesting to see if anything lines up on the nx5 cylinder. lucky I have some scrap cases to play with
If you want to beat NX4 with a NF4 try a 2004 cr125 cylinder with a PV. If you get out of the corners quicker you will beat them around the track.https://www.tapatalk.com/groups/nsr2...rels-t414.html
Jerry Burgess and Doohan then Rossi did this for years.
Pray on the weak points of a NX4 rather tha try to replicate one.
Get yourself a decent carb
if moneys tight.A Keihin PWK38S (short body w/Power Jet)of a KX250 the electric solenoid and tps arround 2001.throw in a decent pipe and a VF3 Reed valve and a short intake
Spend the rest of some decent suspension.
Ask Wobbly about the rest he has given out the details on how to mod the mx carb.
Interesting how wind is blowing in A B C tunnels with this scheme.
When piston moves up, is more or less clear. But what happening on down stroke. Maybe at low and mid revs some gas return to A B tunnels and build up pressure and when windows open, pressure help for scavenging. At high revs, maybe wind blows in one way with help from exhaust diffuser and what's happening in C.
Maybe, with isolated bottom, piston not cooled well and for big end needed additional oil. But fresh gas is less contact with hot parts.
Interesting how transfer duration and size influence this type engine performance and what kind exhaust is needed ( Tested without exhaust, just with ex header, and revs easily, but can't say how much, because very strange, Koso tachometer not working with this huge sound in closed area, can't understand ).
Will try to film outside.
In 2002 or 2003 Honda on Cr 125 use biggest reed cage with smallest 28 mm insert, but carb is 38 mm.
2004 they return to std. smaller six reed cage type and normal insert. Maybe with big reed cage they lost speed in midrange and try compensate with smaller insert.
Very interesting, maybe someone know about this and had experience with that time Honda Cr 125 engine
There are currently 198 users browsing this thread. (0 members and 198 guests)
