Yes, I have drawn a pic of how i´m designing my new cylinder, it is very similar to your drawing actually.
Then i drew that idea of water all into the flange, roostcylinders for scooters have this design.
Then also another thing, i altered the auxports on picture to be more similar to my porting.
I don´t want the wristpin to pass over the port to much as it is expensive to laserweld the wristpin shut in the ends like Aprilia did.
The wristpin passing over the auxiliary exhaust windows need not be a problem Patrick. The problem arises when the wristpin passes over those aux windows and the transfer windows simultaneously, as indicated by the yellow circle in the first picture. That is why the aux ports in the Aprilia cylinders have sloping undersides in order to minimize the port area in the 'danger zone'.
Laserwelding the wristpin ends is not the most effective solution. You might want to try the type of synthetic plug that I developed.
They are closer to the cylinder bore and fairly easy to produce, although the necessary material, Torlon, is not cheap.
Nice Info Frits, Thanks.
I had the problem in an earlier build, long time ago, thereby my caution.
It was like a handgrenade in the crankhouse, it flew reedpetals all over the garage, and it actually chopped off the needle in the carb =)
someone asked me if it was possible to switch of the wobbly-duct for 2/3stage in my FOS excel. it wasn't so I changed it now.
also added volumes.
http://users.telenet.be/jannemie/FOS...E%20black.xlsm
Measure bore wear Roger. Usually takes out inlet but vould gave been weak in that piston front.
Yellow Torlon plugs looks nice, simple and effective.
Long time ago, made wirstpin plug in more complicated way. Found 25 year old piston with this plugs.
Torlon is fantastic material. Once made thrust washers for small end bearing from Black Torlon and they work fine.
