Page 1924 of 2776 FirstFirst ... 9241424182418741914192219231924192519261934197420242424 ... LastLast
Results 28,846 to 28,860 of 41630
  1. #28846
    Cool video Chris. RS125 frame I assume, but what's the engine?
  2. #28847
    26th November 2006 - 14:22
    Rolleston
    NF4 & Derbi 50 I believe.
  3. #28848
    Ex Honda Dave Aprilia RS50 engine isn't it?
  4. #28849
    Derbi
    Thanks Chris, I watched it all. Miss that bike.
  5. #28850
    Katinas, I find your posts about new flow paths and so on very interesting. Hopefully you will be able to do some real testing as the snow goes away..? About the "c-port powervalve", your thought is that the c-port shall be blocket up until about mid-range?
    Yes Norman, would be interesting how engine respond with blocked C, until higher rpm, before pipe goes on and this is would be not difficult to try. If torque at mid revs rise up, then possible connect adjustable C valve to Ex PV through linkages.
    Now revert my engine to rygerised shape, but very different from last year, and maybe fire it in two weeks time. So I am not sure which type try first on the road, when snow goes away. If all pieces is in place, then would be possible revert engine, from one type to other, in one day.
  6. #28851
    Thanks for that, the boysens are not to bad on this cylinder. Interesting you found a gain with no piston holes
    First time, it was four or five years ago, when I made two 7mm holes, on std. NS 400 piston with two big holes on lower skirt side, directed upwards just below second ring in arrange with two small C ports. On the road, some engine sharpness disappeared from 6000-8000 rpm. And then I try so many different combinations, add photo with tested pistons, from last year post. But again, piston without holes work just with Boyesens, without them, maybe arrange of pistons would be in opposite way.
    Even last year, when tested piston with pockets, I drill two 8mm holes (add photo),to communicate space over the small end and side piston pockets. And again, some sharpness gone. Then put plugs with 9 mm tread and power restored. Now I am scared about additional holes on pistons skirts.
    Add photo of cylinders with the biggest Boyesens I ever see. Don't know engine performance capability with this cylinders, but if for some reasons reed cylinder continued exists, this type looks reliable for pistons and promising for power.
ID:	335617   Click image for larger version.
ID:	335618   Click image for larger version.
ID:	335619   Click image for larger version.
ID:	335624   Click image for larger version.
  7. #28852
    What are those cylinders ?
  8. #28853
    4th September 2017 - 10:39
    Daelim besbi 2008
    Espaρa
    la locura de uno
    Solo muestro , no comento nada,
  9. #28854
    Flashy vid, but something of interest. Look at the chamber shape in the stills.
    https://snowmobiles.polaris.com/en-u...atriot-engine/
  10. #28855
    Looks like snowmobilecylinders(Rotax)?
    If around 800cc they often produce around 130-140hp OEM, and a whole lot more in tuned versions, up against 180hp.
  11. #28856
    Yes, this cylinder block from SKI-DOO-ROTAX-800. Saved this photos from ebay.
  12. #28857
    Rotax max cylinders doesn't use piston windows either.Click image for larger version.
  13. #28858
    I have seen good results with just a small window as high as possible underneeth the pistonring, aimed upwards into boost runner together with huge boyesens.
    The port is about 6mm high and 18mm wide, aimed about 50-55 degree upwards.
    But this might be because cylinder has the C-port wide open into reedhouse.
    I think it helps push the mixture upwards into the short runner there is.
    And if having holes lower down in piston might disturb reedpetals.
    And maybe even blow away mixture that should have gone upwards into c-port, due to ejector.
    A bonus is that you get some cooling effect underneeth the pistoncrown.
  14. #28859
    that large boyesen port must make the B passage extremely short. is that no concearn ?
  15. #28860
    Thanks, and this is why so interesting to have a deal with 2 stroke engines.
    Other things, like powervalve or reed house petals seat angle, can make a difference. Honda NS cylinders is without powervalve, and some torque drop always persists around 7000 rpm, but pistons without holes eliminate this, its like with powervalve.
    On the other hand, with powervalve cylinders maybe not so big difference and holes can help add some power at high revs.
There are currently 172 users browsing this thread. (0 members and 172 guests)
