Page 1930 of 2776 FirstFirst ... 9301430183018801920192819291930193119321940198020302430 ... LastLast
Results 28,936 to 28,950 of 41630
  1. #28936
    And for a starter maybe the best craft beer.
    I call bullshit on that Dave.
  2. #28937
    I said maybe because I was a bit drunk and I haven't tried much overseas stuff lately. But beer here has improved enormously in even the last 5 years. Of course you can still get th e usual bus drivers swill, but the supermarkets carry a huge range of diverse beers as a sideline.
    Well, probably not so much in Fonganui.
  3. #28938
    Well here is one the you cant call bullshit in in shape or form.
    Wild Earth, Central Otago, Pinot Noir - best red wine in the world at the biggest international competition.
    Goes fairly well with Wakanui Brisket on the smoker for around 12 Hrs.
  4. #28939
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    5 component completed, evolution progresses,
Name:	avanza evolucion2.jpg
ID:	335772   Click image for larger version.
Name:	avanza evolucion.jpg
ID:	335771   Click image for larger version.
Name:	avanza evolucion3.jpg
  5. #28940
    Did somebody say brisket?????
  6. #28941
    I've not been keeping up to date on this thread, what are we looking at here?
  7. #28942
    Daelim besbi 2008
    España
    there is no thread here of this project, some of you know where this thread comes from and you know what is shown, how it works (basic concept), and what it is for
  8. #28943
    So, what about the rest of us?
  9. #28944
    Well Dave has vino?
  10. #28945
    Daelim besbi 2008
    España
    Some of you know that it comes from a facebook page in which I have shown more photos and I have explained my ideas, this is the last 20% corresponding to the 5th component, if the one that has to avoid the loss of hydrocarbons
  11. #28946
    Ceci, I looked up your name in FB, but I could find nothing.
    It’d be nice if you could give us more details, given that your interesting design is in the public domain.
    From what you have said, it appears that there is some focus on emissions and reduction, which is always good for the 2 stroke.
    The cylinder appears to have 2 exhaust outlets each feeding from 2 cylinder ports, not unlike other FOS style arrangements.
    The crankcase looks interesting, with what appears to be a mounting flange for an oval shaped catalytic converter. Can this be right?
    Assuming I’m wrong, we’d love to have more details of the concept.
    Cheers.
  12. #28947
    Obviously. But that is true for all piston shapes. And as the piston edge is radiused all-around, matching the combustion chamber to it is a piece of cake.
    How do you figure that? A radiused piston timing edge at the transfer ports greatly promotes flow attachement to the piston dome, which does wonders for both the flow coefficient and the piston cooling.
    Attachment 334949
    Flow from the cylinder into the transfers must of course be discouraged, so the top edges on the transfer windows must indeed be sharp. But a radiused piston top edge has very little influence on flow in that unwanted direction.
    The nozzle effect that we hoped to achieve at exhaust opening, does not play a role at transfer opening because, even if the blowdown time.area has been insufficient and the cylinder pressure is still higher than the pressure in the transfer ducts, the pressure ratio will be subcritical, so the flow will be subsonic.
    The benefits of a radiused piston top edge for better transfer flow into the cylinder and better piston cooling are far more important.
    Friend tested KTM SX 65 radiused piston top edge and without any head matching modification, power rise 0,8 hp.
    I have never seen a better school class room than this, Frits.
Name:	KTM SX 65.jpg
ID:	335785   Click image for larger version.
  13. #28948
    So 0.8Hp with a piston edge radius, but where ?
    Did it lose 2 Hp at another point in the powerband.
  14. #28949
    Ceci,
    It has been pointed out that the oval feature has a moving piston, so nothing to do with the catalyst. Dumb me.
    So, as its movement appears to be in close phase with the piston, then it may provide some sort of extra crankcase pumping capacity, something like DKW etc have done.
    Still interested.
  15. #28950
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    Ceci,
    Still interested.
    At first I did have the idea that it was the same as a diapraghm pump (but using a piston instead of a diapraghm), ie driven by crankcase pumping in order to keep the fresh charge from the crankcase.
    I thought someone would explain but it seems that everyone else is in the dark as well!
    Why all the mystery in the replies? - not a wind up I hope!
    Strokers Galore!
