Page 1931 of 2774 FirstFirst ... 9311431183118811921192919301931193219331941198120312431 ... LastLast
Results 28,951 to 28,965 of 41608
  1. #28951
    Given the evasive responses I wondered if he was related to Wobbly's mate.
  2. #28952
    Friend tested KTM SX 65 radiused piston top edge and without any head matching modification, power rise 0,8 hp.
    I have never seen a better school class room than this, Frits.
    what did he do with blowdown / duration during the test?
  3. #28953
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    The main question on this topic is: Does your engine perform "better" due to the better discharge coefficent of your ports, or does it perform "better" because it has higher timings?
    I'd love to see the compared dyno sheets of
    -the original setup
    -radiused edge
    -original piston with the cylinder raised 0,25 / 0,5 / 0,8 mm.
    Because what I have seen on the radiused piston topic is similar to the "piston shamrock"
    as used by...
    http://www.mofapower.ch/viewtopic.ph...366&start=1160
    ...basic tuners.
  4. #28954
    So 0.8Hp with a piston edge radius, but where ?
    Did it lose 2 Hp at another point in the powerband.
    Yes, it lose 1,5-2 hp at mid, add 0,8 hp on top, add 3-4 hp over peak. This tests done without any other modifications, so trans/ex duration little higher and head shape not modified for radiused piston.
    All would be more clear with lowered cylinder (for same duration) and adjusted head shape/volume.
    For me its very interesting too and if he do some tests again, I write something
  5. #28955
    That can be either good or bad. I'd like to do a power range comparison. Can you post rpm-hp or rpm-kW listings of the original and the modified engine Katinas?
  6. #28956
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    I am rookie in the forum and I will not answer as you do. Better that the images speak, being of parts of 2T engines you understand them without wordsClick image for larger version.
Name:	avanza evolucion4.jpg
  7. #28957
    does it run? or is it still just a picture.
  8. #28958
    Daelim besbi 2008
    España
    for now it's just a picture, does it run? God and time just know it
  9. #28959
    we are all rookies, no problem, speak up.
  10. #28960
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    "Pictures are worth 1000 words" - (that's what they say anyway) but not here! - here pictures and words always work well together...... prove that it's not just a silly guessing game.
    Strokers Galore!
  11. #28961
    Ceci What they are asking is if you will you post a link to your facebook page?
    por favor haga un enlace a disposición de su página de facebook
  12. #28962
    13th September 2012 - 07:48
    1991 NSR300
    In a house
    wobbly please get in touch with me .
  13. #28963
    1991 NSR300
    In a house
    Wobbly please get in touch with me
  14. #28964
    We have some doubt about rpm., maybe this needed some dyno calibration and more practice with this new thing , but for comparison tests its no mater.
    Before tests - engine Ktm SX 65 2016, cylinder tuned, head - 4,8 cc with spark plug, gasket under cylinder 0,8 mm.
    1. Black: std piston, head- 4,8 cc, squash - 0,65 mm, max ign advance, RON 98.
    2. Green: rounded piston (0,8 mm X 0,8 mm), no other adjustments , so head- 4,8 cc plus volume of skimmed piston material (not measured) Ron 98.
    3. Red : rounded piston, head matched to piston, head volume - 4,5 cc, max ign advance, squash - 0,65 mm, Ron 102.
    4. Blue: same like 3. just ignition retarded to middle point (like std).
    Black and Blue very similar at mid.
    Power very sensible to engine temperature, so this graphs more or less bests from all tests. Of course, would be more informative test, if Ex/Trans duration and head volume (with matched to piston) be the same like with std piston, but maybe, later after track tests.
    Add my drawing graphs for quicker comparisons.
Name:	Standard piston, head-4.8cc, ign max advance (Black).jpg
ID:	335811   Click image for larger version.
Name:	Rounded piston , no other adjustment, ign max advance, head 4.8cc plus volume of rounded space (.jpg
ID:	335812   Click image for larger version.
Name:	Rounded piston  mached with head, higher compression - 4.5cc with plug (Red) ign max advance.jpg
ID:	335813   Click image for larger version.
Name:	Rounded piston  mached with head, higher compression - 4.5cc with plug,  ign retarded to std. ad.jpg
ID:	335814   Click image for larger version.
ID:	335815   Click image for larger version.
Name:	Ktm Sx 65 cylinder 2016.jpg
  15. #28965
    [QUOTE=Tim Ey;1131090210]The main question on this topic is: Does your engine perform "better" due to the better discharge coefficent of your ports, or does it perform "better" because it has higher timings?
    This is the main most interesting question, but I don't know, because he did not lowered cylinder and want to try on track with this little higher timing duration.
    This is not my engine and I just can say thanks for him, about this all tests info.
