Page 1933 of 2773 FirstFirst ... 9331433183318831923193119321933193419351943198320332433 ... LastLast
Results 28,981 to 28,995 of 41594
  1. #28981
    Katinas, only to make sure: in your printouts from the dyno the temp, ambient pressure and humidity is the same for all tests. Do you have the "weather" station connected to the dyno software, does it get the actual pressure, temp and humidity for each individual run?
    Thank's
    Juergen
    Juergen, do not pay attention to all atmosphere parameters, they are left from previous dyno owner tests.
    This tests just for comparisons and interval between Black/Green graphs - 2 hours. Red/Blue tests on second day.
    All tests done until power goes down, when engine temperature reached 70-80 C.
  2. #28982
    29th January 2015 - 09:21
    kart
    wellington
    coolant flow
    Hi Wobbly
    in regard to coolant flow through a kz10 engine which option do you prefer to use
    a. bypass hose removed and plugged with crankcase to barrel plugs removed or
    b. bypass hose fitted and crankcase to barrel plugs fitted
    I see that you posted a pic of the coolant flow entering through the front of the barrel ,
    is this a mod that can be done under the rules .
    regards Richard
  3. #28983
    16th November 2016 - 20:47
    73 kawasaki h1
    U.K.
    F5 Dave. Have you checked it's not something as simple as a crappy TPS?
  4. #28984
    Thanks Nick. TPS is quite consistent in diagnostic test, can see readout as you wind it back and forward.
  5. #28985
    9th August 2013 - 20:06
    kreidler rs 1976
    Netherlands
    Derby 72cc almost reaches the RSA level
    Derby readvalve engine 72cc bore 47.6 stroke 40mm
    Result 32.75 hp this means 97% of Aprilia level
    150m dragrace 6.62sec with total weight 130kg
    If there exist a breeding ground for horsepower in motorsport, than it is the NSSC dragrace competition. Several experienced tuners prepare there engines every year to the limit close for the new season at 150 meter distance competition. The accompanying example shows that the Aprilia RSA level was almost achieved in 2017. Moreover, it was a reedvalve engine of which up to now it was assumed that approaching the power up to 3% would be impossible. Maybe we should adjust our opinion on this now! Or is it the advance of 4x cranckshaft bearing, which were not on the Aprilia RSA.
    More information and pictures: https://www.deraceheldenvanweleer.nl...p?topic=2007.0
  6. #28986
    https://www.facebook.com/photo.php?f...type=3&theater
    1st link no good unless you have log in information.
  7. #28987
    These results raise many questions
    Type of dyno crank / weel?
    32.75 hp crank / weel (Bhp)?
    Fuel?
    Octane?
    4x cranckshaft bearing?
    if above is comparable, pV is startling with less than 20ms
    Regards Muhr
  8. #28988
    11th October 2016 - 21:23
    1974, Guzzi, 750s
    Finland
    That and the second one doesn’t look like dyno data, what is it?
  9. #28989
    Oh god, here we go again. Piss off.
    Don't you understand? Why do you keep coming back? You should seek help.
  10. #28990
    Thank you very much Lucf.
    There is just one small problem: I cannot see that Facebook-page because Lucf has blocked me. I am not sure why, because I never wrote anything about him on Facebook. Maybe he does not want me to see what he writes about me...
    I asked Jan Thiel to take a look at that Facebook-page, so he might tell me what it was all about.
    Jan's answer: "I cannot see it either; Lucf has blocked me too."
    I seem to remember a Ryger-argument in which Lucf publicly accused Jan Thiel of not understanding how a two-stroke works....
  11. #28991
    16th January 2016 - 04:20
    1984 Moto Guzzi V65 Lario
    The Netherlands
    Looks like he calculated the power output using time vs distance and the weight of the bike. Fun as a little hobby MatLab project, but you can never account for every variable. So again some arbitrary calculated power curve... Also even if the 97% figure was accurate, I bet that last 3% is insanely hard to get.
    Come back when you have an independent dyno result. Or don't...
  12. #28992
    1974, Guzzi, 750s
    Finland
    Suppose this is just a comparison table between RSA and given set of 72cc numbers...
  13. #28993
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Do not confuse the sterling work of Sietse and Gerard with Luc's calculation, if you have an issue with one do not also make the other off as the same. My reading Dutch is not so good but it seems in the first post on the topic they measured on a Tovami dyno 31.9hp at 13200rpm, it made more at higher rpm but starts wheel spinning.
  14. #28994
    1974, Guzzi, 750s
    Finland
    I suppose you were able make that first link work to see the dyno data?
  15. #28995
    There is just one little problem: I cannot see that Facebook-page because Lucf has blocked me. I am not sure why, because I never wrote anything about him on Facebook. Maybe he does not want me to see what he writes about me...
    I seem to remember a Ryger-discussion in which Lucf accused Jan Thiel of not understanding how a two-stroke works....
    He´s in 'keyboardwar' with your supposed lie about the FOS cylinder project.
    He writes about he was before you etc etc.
    A small person he is.....
There are currently 27 users browsing this thread. (1 members and 26 guests)
  1. JanBros
