Page 1953 of 2773 FirstFirst ... 9531453185319031943195119521953195419551963200320532453 ... LastLast
Results 29,281 to 29,295 of 41593
  1. #29281
    Sure TeeZee, you post the pack, and i will do a pipe,with some insights into the process.
    Great, I will carefully work through modeling my engine setup and post the pack.
  2. #29282
ID:	336216 my preliminary EngMod simulation, (crank hp). Click image for larger version.
Name:	NSR 29.85hp.jpg
ID:	336217 real life dyno run of the engine being modeled, (rw hp) .
    The EngMod simulation is starting to look like the real thing. I will refine the model a bit more then Wob can work his magic and hopefully let us in on a trick or two.
  3. #29283
    15th May 2017 - 14:26
    2002 Aprlia RS125
    Yes, these ones:
    What size rim do you run them on? 1.4 or smaller?
  4. #29284
    I run the rear tire on a 1.6" rim
    And the front tire on a 1.2" rim
  5. #29285
    3rd August 2012 - 02:39
    yzf 250
    holland
    I was saying that putting the short A kit pipe on an older RS125 engine simply wont work - plenty have tried, and failed.
    Why Wobb everytime I make pipe in Engmod the pipe on de dyno is on the left !!!!
  6. #29286
    Thanks for the tips on degree wheel etc.
  7. #29287
    Simple Dutchpower - in the Temp page you have not simulated the pipe wall temp correctly.
    The new rpm dependent inputs now also have the opportunity to enter the real ,as measured, surface temp data from the header,the mid, and in front of the stinger.
    As the bmep reaches the outer limits, as in say a KZ2 engine, at 50Hp from a 125, the smallest changes in this type of data, make big effects on the result.
    That is Bullshit in = Bullshit out.
    For many tuned engines I have found that a global average temp of 325*C at the bottom of the powerband and 425*C at peak is a good start point,when the tuning gives low to mid 600*C inside the header.
    The other issue is the correct modelling of say a step in the header flange.Just putting in the dimensions to correctly show the position of a step is not the same as defining
    a step properly in the opening page of the pipe inputs.
    The code has a very difficult time handling steps ,and not defining them correctly creates havoc in the results.
  8. #29288
    yzf 250
    holland
    Thanks Wobbly
  9. #29289
    27th January 2011 - 11:30
    asdasd
    AKL
    I'm racing 50s here in Europe, it's pretty rad. I also got to meet Frits finally after reading so much of his advice online.
    Check out what I'm up to here: www.grandprixmachine.com
  10. #29290
    Chris how do you get in these situations? I would love to have been in those pits with all those 50s.
    I guess they make our efforts look a little shaky.
  11. #29291
    31st July 2005 - 11:15
    a shed full of crazy shit
    Choice Chris.
    Loving the pictures and the updates.
  12. #29292
    I'm racing 50s here in Europe, Check out what I'm up to here: www.grandprixmachine.com
    Really Really Great write up Chris, and super great to see Frits there with you.
  13. #29293
    19th December 2013 - 09:36
    triumph
    italy
    works very well.
    Sells ready to use. Easy to manufacture support
    http://srp-racingshop.com/shop/en/eq...l-degree-wheel
    if you do not want to throw money ...
    https://www.ebay.com/itm/Remote-Disp...4AAOSwlAZadJ1C
  14. #29294
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    That's where I bought it. And copy the idea of support kart shop
  15. #29295
    14th December 2015 - 07:33
    Aprilia RS250 and Aprilia RS50->125cc
    All over
    what tires are you using chris ?
