Page 1993 of 2773 FirstFirst ... 9931493189319431983199119921993199419952003204320932493 ... LastLast
Results 29,881 to 29,895 of 41593
  1. #29881
    ...the green bike blows past the other bikes like they're standing still! Did the RSA125 act like that?
    It would have, against a competition of reed-valve Hondas and KTMs. But except for the RSA's first outing, where it only displayed its full potential in a breathtaking final lap, there were always other RSAs around, and RSWs, that were not much slower.
  2. #29882
    Maybe someone thinks it’s interesting
    http://portal.research.lu.se/portal/...297/625826.pdf
  3. #29883
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    That intake rubber is huge - the old NX4 one is only around 25mm overall,so that pulls the whole carb and bowl way closer.
    16210-NX4-000 - hard to find though.
    A downdraft oval bore Keihin carb off a NS400 would be the go,its been done before.
    As would a 36mm downdraft off an Aprilia RS250 road bike.
    But the Lectron would work to.
ID:	337182Click image for larger version.
    Say I could grind 1cm and raise the flange lenght to fit a PWM, still good advantage over a worked pwk?
    Guess I will buy the PWM and still test the worked PWK
  4. #29884
    If you can find an NX4 manifold it would be as long as what you have shown, less the extra rubber and extra hoseclip on the carb.
    I have seen several PJS carb for sale, that is the short race carb off the later Honda RS125.
    It has TPS and the solenoid PJ - that makes the same power as a PWM, but depending on your end use, the PJ makes a huge difference to overev..
  5. #29885
    Leiria, Portugal
    I am pretty happy with the overrev I got already just with ignitech etc, dont need to blow parts even more.
    Going to try both pwk and pwm
    Hope to ear about any test of piston edge radius.
    cheers
  6. #29886
    Has someone got a pic of the Aprilia cylinder, looking directly at the Exhaust duct with a spigot fitted.
    I want to see what the steps actually look like at the bolt on face.
  7. #29887
  8. #29888
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Is this what you want Wobbly?Click image for larger version.
Name:	exhaust flange + cylinder 2.jpg
  9. #29889
    Yep, interesting. thanks.
  10. #29890
    Thanks Husa and Jan.
    I have a new cylinder to test from TM (designed with the side ears right thru the spigot ) and i want to run it with exactly the Aprilia style steps first
    then several versions with top/bottom steps removed with added material in the spigot.
  11. #29891
    2008 Yamaha fino
    Bangkok
Name:	Exhaust flange.jpg
    The flange was 40-41 conical. Length 40mm
  12. #29892
    The best TM spigot at the moment matches the oval duct exit, then matches the round header entry.
    But with the added area of the ears down the side,I have reduced the oval height - to keep the exit area the same as previously.
    Thus of course being a 2T you cant assume anything about what will make the best power with such a big change , so i will test all the different configurations again.
  13. #29893
    That discussion about methanol and corrosion.
    This floatbowl is from my VM44 carb, it has been lying in my garage since september untouched unopened.
    A couple of days ago i was curious if it was mayhem inside the bowl.
    This is what i saw: (dark spots were there when i bought the carb)
  14. #29894
    News from Bidalot, a new hot 50cc cylinderkit
    They say it will be a 70cc model also in the future.
    Originalpost on facebook:
    https://www.facebook.com/bidalot.tec...89852161083705
  15. #29895
    Leiria, Portugal
    Worked the pwk, bellmouth shortned 11mm, front shortened 2.5mm, air vents grinded, choke holes filled. and gone for some straight's. no plug checks yet.
    Mid to high range seems to had a little lost, overrev seems to be a litle improved.
