Page 1994 of 2774 FirstFirst ... 9941494189419441984199219931994199519962004204420942494 ... LastLast
Results 29,896 to 29,910 of 41597
  1. #29896
    2nd August 2011 - 11:11
    Connecticut, USA
    Picture of Pipe with Deto button in header
    I have searched and have not been able to find pictures of pipes with a deto button(small deflector) welded into the header on the pipe. Does anyone know where to find these pics? They were pretty early in this thread.
    Thanks,
    DT
  2. #29897
    6th October 2015 - 13:42
    2001 kx250
    USA
    That discussion about methanol and corrosion.
    This floatbowl is from my VM44 carb, it has been lying in my garage since september untouched unopened.
    A couple of days ago i was curious if it was mayhem inside the bowl.
    This is what i saw: (dark spots were there when i bought the carb)
    Attachment 337225
    That definitely looks like corrosion, could come from just sitting & collecting moisture, but that is what Methanol will do if you don't purge with gas & oil (I like Castor mixed a little heavy).
  3. #29898
    Quote Originally Posted by dtenney View Post
    Thanks,
    DT
    Yamaha Yzr 500
Name:	YZR 500 pipe.jpg
  4. #29899
    I have searched and have not been able to find pictures of pipes with a deto button(small deflector) welded into the header on the pipe. Does anyone know where to find these pics? They were pretty early in this thread. Thanks, DT
    The good old Google "SITE:" search turned up this:.....
    det button site:https://www.kiwibiker.co.nz/forums/s...-engine-tuner?
    ... follow the posts for the RGV500 version and pictures
  5. #29900
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    Thanks,
    DT
    https://www.kiwibiker.co.nz/forums/s...tuner/page1041
  6. #29901
    Did you read what i wrote?
    I wrote that the darkspots already were there when i bought the carb.
    And before me it has never seen methanol.
    And by that,, it hasn´t corroded any since i began using methanol.
  7. #29902
    16th February 2017 - 14:26
    2002 Yamaha YZ250WR
    Brisbane, Australia
    Update on my YZ, cylinder is now overbored from 250cc to 265cc, so I'm scaling then porting to suit, but also wanting to shift the powercurve up about 800rpm at peak, since I'm gearing limited already.
    Stock cylinder transfers give STA of 0.000936 at 8500rpm. For the 265, I widened the ports so the % of bore width was the same as stock 250, then increased duration to the same STA as stock but at 9300rpm. Went from A: 116°, B: 116°, C: 121° stock, to a slightly staggered A: 122°, B: 121°, C: 119°. Relative power from 48hp to 55.6hp.
    Stock exhaust gives STA of 0.000130 and 0.000168 with aux ports open. I widened the main exhaust to the full width of the PV blade, slightly reduced the radius on the upper corners, and increased duration from 185° to 190°. I'm reluctant to go much more duration as 190° is getting a bit much for 9300rpm. I left the aux ports at 185° to give them some stagger. I think this is about the limit of what I can do with the exhaust, but gives an STA of 0.000122 and 0.000157 with aux ports open. Power handling from 55.3hp to 58hp. So the transfers are still limiting.
    Is this the right way to go about reaching my goal? Will having the exhaust smaller relative to the old arrangement make it more peaky? It's only 5 speed so I need to keep the power curve pretty wide...
Name:	YZ265 CAD Port Map.jpg
    Just need to get this laser cut to a thin sheet and start cutting!
  8. #29903
    More Dyno adventures .....
    Had one of the very front running 4T's (Paul's EFI Yam 150) on the dyno today.
    4T Blue Line 2T Red line.
Name:	4T Blue 2T Red.jpg
    When you look at the low end torque of the 4T and extremely wide curve you can see why mere mortals on 2T's get well and truly trounced by the 4T's drive out of the corners.
Name:	Arduino Nano and MAP sensor.jpg
    Had a chance to try the Arduino MAP simulator today.
    RPM brown line, TPS blue and Arduino MAP simulation is the Yellow line.
Name:	Arduino MAP Simulator.jpg
    The Arduino uses a MAP sensor to measure crankcase pressure and looks for the maximum and minimum pressure and outputs the difference as a simulated MAP value to the EFI's CPU.
    Bike sounded good and was even starting to show signs of improved drivability.
    I was rely starting to enjoy myself laying consistent runs and making little improvements with ignition/fuel and PV adjustments.
    Things were going real well, on the home run I thought, then I heard the dreaded dyno death rattle......
    Quick as a flash, in with the clutch and let the beast coast to a stop.
    (&^%%$#$#^+_!!! could be the problem this time.
    Turns out that it had drunk all its cooling water during 20-30 runs. .... wasn't expecting that ....
    Have not taken it apart yet but I suspect that small pressure drilling I put in a while back may be leaking or the head "O" ring. Not many other possibilities.
  9. #29904
    2001 kx250
    USA
    Yes, I read what you wrote & replied regarding to its content ( or lack there of ) , did you read what I wrote?
  10. #29905
    22nd September 2012 - 16:31
    1995 kx 125
    [QUOTE=TZ350;1131100765].
    When you look at the low end torque of the 4T and extremely wide curve you can see why mere mortals on 2T's get well and truly trounced be the 4T's drive .
    That's why you gotta use everytjing you can to your advantage. 3 stage baffles. Low and wide tranfers. Staggerd tranfers.
    Longest pipe you can get away with. And good inner/outer radius. Radius on the right in pic, is absoulty terrible thru the whole curve.
  11. #29906
    You assumed things, and thereby you disqualifies yourself *lol*
  12. #29907
    Attachment 337225
    I don't suffer corrosion on my stuff when I neglect them for a while either.
    We do live in a rather dry climate though, especially in the winter time, that for sure helps.
    In my case the 20% castor helps a lot too, but gives other problems than corrosion if left for too long.
  13. #29908
    13th February 2016 - 09:21
    None
    Holland
    Too many ups and downs in the graphic. There are RPM's that are up, and RPM's that are down, close to each other, looks like a bandwith measurement problem. Try to get a datasheet of the MAP sensor, look at the response time and find out if you can take like 8-10 samples per revolution. Choose the 8-bit resolution ADC conversion off the Arduino to speed the software part up. Get rid of noise: sample deeper.
    If I look at it filtered, I see the data increasing with rpm ,without significant spike.
    Bandwith is just like: I want to look into this at let's say 12000 rpm, thats 200/sec, so you sample sort of valid at 2000/sec.
  14. #29909
    The dry climate is probably the biggest factor in preventing corrosion.
    The worst customer carbs I ever had were those used on the West Coast of the South Island of NZ - Husaberg's home territory.
    They'd regularly come back to me white with corrosion inside and out.
    The 18 metres of annual rainfall may have had something to do with that.....wait for husa's response, LOL.
  15. #29910
    I have tested the Suzuki type deto cone, and the Yamaha type ( penny on a stick ) is better.
    Piston and insert are ready to test the edge radius, will have some dyno results in a day or two.
