Page 2001 of 2762 FirstFirst ... 10011501190119511991199920002001200220032011205121012501 ... LastLast
Results 30,001 to 30,015 of 41427
  1. #30001
    Piston edges. While the conversation is around radiussing, here’s something slightly different. A dude, who just came in today, over here is running twin KF engines that he sourced out of the UK. These run Dyke rings against the CI bore. Traditionally these just have the square edge on the land above the ring, see pic.
    As these engines are not running under any rules, they came modified from the basic 4 deg crown angle. They were flat topped and the edge was chamfered as per pic. While not perfect in terms of carrying the radius to the full diameter, it does look like it would flow better, in that a sharp edge has been removed.
    The head, which I haven’t actually seen, does not have any profile to follow the chamfer, but just has a matching 4 deg squish angle out to the bore diameter. This must result in an annular volume at the bore edge. It’s possibly why the piston was replaced, as it was detonated away at the top ring land area above the A/R pin.
ID:	337332Click image for larger version.
ID:	337333Click image for larger version.
  2. #30002
    53.87mm - wow surely thats not in a 54 nominal bore ?????
    And yes, having a large trapped volume in the squish/bore corner is simply asking for Mr Deto to come visit.
  3. #30003
    And I dont intend on spending the silly money they want for pistons or heads - far rather learn how its done myself , alot more interesting as well.
    After testing full rounded piston, interesting tests was with three sharp location on piston edge: near C port and two narrow sharp edges between A and EX. Even without fully matched head, on the road feels better than with full roundness, but if you have possibilities to try this with dyno would be very nice and more clear.
    Add pic - rounded piston with black spots where two C ports located
Name:	Rounded piston 57 mm  Honda NS  C- ports.jpg
  4. #30004
    23rd March 2015 - 21:24
    Conti RX356 V3
    Quote Originally Posted by schutten View Post
    For the 85cc mx engines, they look like this.
    Those have no rounded timing edge, rather 12° squish with a flat top - insert looks accordingly.
    https://www.vhm.nl/en/catalog/engine.../g+c+a+nr+view
  5. #30005
    Cylinder from 84' NSR 500 "low tank position".
Name:	NSR- 500  1984 -low side tank-.jpg
  6. #30006
    So. . When you are producing the gearbox version in significant numbers as a road- legal bike at a consumer product price. . . Make sure you export a bunch over here won't you?
    This is more of a unicorn hopefully, if I not miss something so I have to make another one. Would certainly be interesting to make a geared engine!
  7. #30007
    That is very interesting, the exhaust port bridge is fatter in the middle.
    It looks like that is there to keep the area unchanged going down the duct. Not seen that before but it makes sense.
Name:	Fat Exhaust Bridge.jpg
ID:	337344 Fat Ex bridge.
  8. #30008
    21st June 2012 - 14:20
    1974 Yamaha RD250
    Camden, S.C. USA
    Perhaps the fat bridge has a water passage through it?
  9. #30009
    Yes, maybe. That would make sense too. Does anyone know for sure?
  10. #30010
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    If its done no more it was/is probably not better....
  11. #30011
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Yes, they have.
  12. #30012
    That shape a modified teardrop is also the most efficient in terms of drag. Compared to a sharp end first.
  13. #30013
    Maybe too much material exposed to hot gases, even with cooling passage. One of the head studs goes directly to Ex divider, maybe help to finish this passage. This was the first NSR 54x54,5 and claimed 142.6 hp/ 11,500 rpm.
    But after more than 30 years many things changed and who knows how it works with all new things.
    Massive cooling "arc" around exhaust, maybe was first steps to what we have now, con rod -104 mm (NS 500-106mm) - looks like this engine main things became basic for all later NSR/RS models.
    Interesting Yamaha late 2 Ex 7 Trans ( 2001).
Name:	Brno 2001 Yamaha Biaggi.jpg
ID:	337346   Click image for larger version.
  14. #30014
    Think that the problem here is that the flow speed is so high that you get flow separation even though the shape is optimized
Name:	Post-Processor Screenshot-3.png
  15. #30015
    Leiria, Portugal
    Much lower port timings on the 2001?!
