Page 2020 of 2774 FirstFirst ... 10201520192019702010201820192020202120222030207021202520 ... LastLast
Results 30,286 to 30,300 of 41610
  1. #30286
    28th October 2011 - 20:02
    RGV
    Pommyland
    Pictures attached, but it seems I am not capable of doing the translation.
    Translated, but any others you want translating will have to be 1920x1080 x 600dpi, easier for the OCR
Name:	Normans rgv1-Finish.JPG
ID:	337908   Click image for larger version.
Name:	Normans rgv2-Fin.JPG
ID:	337909   Click image for larger version.
Name:	Normans rgv3-Fin.JPG
  2. #30287
    RGV
    Pommyland
    Add some drawings from "Racers" that can be helpful about YZR, NSR "Crank-angle-firing-forces".
    https://www.kiwibiker.co.nz/forums/a...3&d=1533200780
    Looks like the big bang was designed to have zero piston acceleration on the bottom cylinder while the top cylinder was on max deceleration (TDC), poss. 50% primary on the crank wheel married to 50% on the balancer ¯\_(ツ)_/¯
  3. #30288
    RGV
    Pommyland
    Spaan planned to produce his own cylinders (which would have had all the characteristics of Honda cylinders) but when Suzuki got wind of it, they insisted that the factory would take care of that, if Hans would only provide the drawings. Nothing ever happened,
    Likely fell to unwritten Japanese rule of not copying each others designs.
    .....but in any case Suzuki did not lose face quite as much as Yamaha did, when Harald Bartol made them pay him for putting shameless Honda-copies on the Yamaha TZ125 (and on the 125 cc Derbis. And on the 125 cc and 250 cc KTMs).
    Not forgetting the money Bartol received from the eyeties for the Gilera GFR250, with that perticular unit sporting some very Yamaha looking clyinders.
ID:	337912   Click image for larger version.
ID:	337913   Click image for larger version.
  4. #30289
    Yep.......
  5. #30290
    24th February 2013 - 08:12
    1993, suzuki rgv250
    Smile
    Yes, I am glad the pictures are not in Japanese, but I would not be surpised if Mr. Dutch Fisher could have fixed that too!
    Never mind Norman, as long as the pictures themselves are in English .
    I encountered this engine in the Molenaar GP-team where Hans Spaan tried to bring it on par with the 250 cc works Hondas on which he had been working previously. The Suzuki suffered from a lack of power and an overdose of complexity. Each cylinder had an exhaust power valve with no less than three blades, called SAEC, and an ATAC-type resonance volume, called AETC, which brought a lot of unwelcome heat in the cylinders.
    Spaan planned to produce his own cylinders (which would have had all the characteristics of Honda cylinders) but when Suzuki got wind of it, they insisted that the factory would take care of that, if Hans would only provide the drawings. Nothing ever happened, but in any case Suzuki did not lose face quite as much as Yamaha did, when Harald Bartol made them pay him for putting shameless Honda-copies on the Yamaha TZ125 (and on the 125 cc Derbis. And on the 125 cc and 250 cc KTMs).
    The best thing of the Suzuki works engines were their pistons, consisting of a light-alloy base material with embedded ceramic fibers. Spaan claimed they lasted ten times as long as Honda pistons.
    Attachment 337907
  6. #30291
    I agree with the first bit but not the second.
    MY take is the two lots of 50% are the balance factor on each crankshaft, ie half from the opposing piston and half from the counterweight .to achieve 100% primary balance
    the balance shaft is for secondary forces, it was added for the two up crank 180 degree crank used the last two years before the big bang. Its main function is the jack-shaft to change the direction of the engine to lessen gyro.
    If my theory is correct I dont believe the big bang even really needed it.
    Ducati twins have V-angle 90 degrees. This uniquely makes it possible to balance a 90-degree twin with counterweights of 100 percent of one piston’s shaking force. Here’s how it works. At the front cylinder’s TDC and BDC, the heavy crank counterweights cancel the front piston’s shaking force. But at 90 degrees and 270 degrees, those same heavy counterweights now cancel the TDC and BDC shaking force of the rear piston. In other words, both primary piston shaking forces are 100 percent balanced,
  7. #30292
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Attachment 337907
    Bartol also STOLE the fairing models from DERBI, and used them on the KTM.
    They were made for DERBI by Porsche.
    And of course paid for by DERBI.
    Later, while testing the RSA engine in 1996 it was discovered that this fairing had a very negative effect
    on steering, especially at high speeds!!!
    Only good in a straight line...…The bike only wanted to go straight....
    Shame on Porsche!!!
    And Yamaha also copied the Honda cylinders on the 500/4's, helped by Bartol.
    As did Yamaha-France for their 250's.
    Yamaha even published an SAE paper about this....
    Really SHAMEFUL!
    Maybe Honda, just like Aprilia, liked to SELL a lot of pistons.
    At Aprilia this was bringing in lots of cash----
    80% gains on the price, or more!
    Only few people knew this.....
  8. #30293
    RGV
    Pommyland
    ... poss. 50% primary on the crank wheel married to 50% on the balancer
    We are saying the same thing..
    At the risk of the blind leading the blind (kinematics are my weakest topic) here's a theory.
    Using the formula I stated earlier (2xAv)-180) the 112* comes out spot on at 44* pin offset.
    That means primary balance is achieved right there, as noted by the zero piston accleration on the bottom cylinder and max decel on the top cylinder (TDC)
    The fly in your soup is the secondary forces are having a party in a wasps nest and buzzing away merrily.
    I've modded the pic and added the sum of inertia force lines of the secondary in yellow.
    Now it seems Honda has approached this problem (likely 2 mins on the back of a cigarette packet for them) by reduced the crank balance factor to 50% and added that other 50% to the balancer so maintaining primary balance. This has allowed them to use a good % of the rotating interia of the balancer counter weight (thats counter-rotating) to offset a fair degree of that untamed secondary inertia force.
    The counter force angles are not absolutely in-line while at their respective peaks, but it looks like the level of vibratory forces is reduced to the point that its ok to solidly mount the crankcase into the frame.
Name:	NSR 500 Second forces.jpg
  9. #30294
    Loads of RGV500 pics
    including inside the crankcases
    https://www.kiwibiker.co.nz/forums/a...p?albumid=4848
ID:	338033Click image for larger version.
ID:	338034Click image for larger version.
ID:	338035Click image for larger version.
ID:	338036Click image for larger version.
ID:	338037Click image for larger version.
  10. #30295
    2008 Yamaha fino
    Bangkok
    It is well known that Gilera got Kocinsky's bike from Yamaha after John won the championship on it.
    Gilera did not excactly improve it, stupid fools....
    And even the great Bartol failed miserably....
    They spent millions for nothing!
  11. #30296
    All is very interesting, thanks.
    Looks like RGV 500 piston skirt cut at C is big like on street RGV 250 and at the same level like main side cuts. Street RGV 250 piston skirt looks very fragile, but is it made for better flow acceleration through C port, when piston at TDC , or for less obstructed way in/out crankcase when piston at BDC.
    Add RGV 500 XR78 1989 cylinder drawing, and probably this was first decade when was discovered that A higher than B work in good way for wider power range, but really I don't know. Ex duct with small step and then two sections before pipe.
    Looks like on Honda RSW 250 2009 cylinder duct and spigot dimension gradually changed before pipe without step.
    NSR 500 crank-sprocket chain.
Name:	Suzuki RGV 500 xr 75  1989.jpg
ID:	338040   Click image for larger version.
Name:	NSR 500 crank-sprocket (1).jpg
ID:	338041   Click image for larger version.
Name:	NSR 500 crank-sprocket (2).jpg
ID:	338042   Click image for larger version.
  12. #30297
Name:	yoshimura multiple jet nozzle 2.jpg
    Suzuki on RGV 250 XR96/98 used Mikuni with Yoshimura type multiple jet nozzle and in 1995 on XR95 they tried EFI with 40mm body (not on the factory "Lucky ..., but on JAJA team's engine, maybe in All Japan Championship).
    Chambers has a 24mm version of one of those carbs on his F5 Suzuki RG50 Bucket, seems to work Ok.
ID:	338043 Click image for larger version.
  13. #30298
    Interesting how better atomization influence two stroke piston cooling at high revs.
    Yoshimura developed this for four stroke GSX-R SBK from 1988 and was launched in 1992.
  14. #30299
    1993, suzuki rgv250
    The steps and contracting exhaust ducts; could it be that they help such that the exhaust gas does not heat up the duct walls as much. The flow get's separated from the walls after the step? The air-fuel slug going out in the exhaust port will be less heated up? (As the exhaust port opens there is a lot of tubulence and pressure which enhances forced convective heat transfer a lot)
  15. #30300
    Yes, good point. maybe not so much piston cooling, might be a problem.....
