Nice site with nice bit on Mr Jan Thiel
http://www.classic50racingclub.co.uk/jamathi.html
Simplified drawing of the pressure cycle in a two stroke crankcase. The low pressure is typically at TDC and the Maximum pressure is typically 140 deg ATDC this is much the same for all typical two strokes. The average pressure is high, about 0.8 bar at WOT and near 1 bar at idle.
The difference in height between the maximum and minimum pressures changes with air flow, more air, the bigger the difference.
The plan is to use this difference to see the changes when the engine is on the pipe or not.
The changes are subtle enough to be used as a MAP value in the traditional 4S sense.
Probably what KTM are doing.
Axially mounted? How old fashioned!
This way of reasoning could block your brain, TeeZee. The part played by the piston is quite weak compared to what the Helmholtz resonance is capable of.
For example, at low revs you can experience blowback while the piston is still rising, just because the Helmholtz frequency is too high for the inlet angle/rpm combination.
whom as seen this?
There are currently 112 users browsing this thread. (0 members and 112 guests)
