OK one more
Anyone who has a wire diagram for a Tm MX 125 2018. Especially powervalv and ignition side?
it see why Every man and his dog has one of those now https://www.amazon.com/dp/B075W5NKL7
i think it was katinas wanted a cylinder in 65cc. i guess there is now ktm copies
https://www.ebay.com/itm/65SX-KTM-Cy....c100935.m2460
Found one earlier on ESE 2012
https://www.kiwibiker.co.nz/forums/s...post1130400306
Rob did you weld on an extension to the gearbox on one of the TF or GP gearbox mainshafts
i can't find the post?
Anyone ever made a mainshaft longer for a dry clutch or similar?
Yes, 1980's RD400 to 1970's RD350 conversion for a TZ dry clutch and better ratios in the TZ350.
The RD has a 60mm clutch shaft and it needs to be 90mm long for the TZ dry clutch. So the RD350 nose was cut off and had an oil hole and "O" ring grove added then the RD400 shaft was spigot-ed into it.
The RD400/250 or LC350/250 or RZ ratios work well in a TZ. 1st is a help in getting off the line and the other ratios are suitable spaced. The LC has only 3 selectors so some case mods are required if you are fitting it to a earlier RD. The other box's with 4 selectors are easier to work with. The TZ cylinder base was skimmed 0.75mm to get the exhaust duration at 196 and the squish was set to 0.8, ignition 1.8mm BTDC. This got rid of the TZ power band light switch effect and made for a very fast and ride-able bike.
5 speed TS125 to GP125 conversion that shows the basic idea.
Thanks, and thanks for asking!
I just finished catching up, almost two years.
Been busy, mostly due to kids, and the youtube thing has surpassed anything I would have imagined. I'm having a hard time keeping up with all emails, comments, messages etc.(With hard time I mean I'm not keeping up...)
Recent events made me realize I had to get up to date on what's going on.
It all started with the idea of running the Spx with the cylinder rotated 90° and closing off the exhaust side of the wristpin, thereby being able to run full width aux ex ports without short circuiting.
Posted a video about it and Mark Atkinson(video a few pages back) left a comment saying he could make me a piston after race season.
Neels sent me a link to Marks vid just a few hours later(Thanks Neels), funny coincidence!
You saw the piston, no need for rotating the cylinder anymore.
Then I had the idea of restraining the ring with pins, allowing it to move just enough to seal well, but not enough to catch in a 100% of bore single exhaust port. Posted another video.
Wobbly watched it(thanks for watching!) and sent Mark this link http://iffitech.com/project/gp-piston/ which he forwarded to me.
Much better than my pin idea!
Mark is thinking about incorporating it in his design.
Do anyone know anything about this stepped ring design? Have it been run with a really, really wide port successfully? Does it seal well?
Clickbait titles, I know...
Feels great to be back! Now to the other two threads...
Btw, Hollaendaren, are you on here?
Two strokes & rum!
Two strokes & rum!
I like it. In which direction is the step facing on these pistons? To the head or to the case? Did they encounter resonance effects at some ring dimensions / weight / rpm combination? And how do you avoid that both these piston parts become loose?
Two strokes & rum!
Missed seeing the reverse dykes ring bit. I had Moriwaki 2-ring pistons in my Z1. the motor turned over easily and made noticeably more power. Has a few other bits added as well so not totally the pistons and rings.
I worked for Savice in China on a mini MX bike project, that company gained the patent for the reversed L ring concept.
The ring is a reversed Dykes,with the vertical leg facing down.
This enables the combustion pressure from above to force the ring down ( as normal ) but also outward against the restraining slot wall ).
Thus it works the same as a Dykes,the additional wall friction prevents ring flutter at any rpm, the very reason the L ring was used in 20,000 rpm kart engines.
There are currently 79 users browsing this thread. (0 members and 79 guests)
