I´m struggeling with bad traction on dynoroller now, I will change the rear wheel tomorrow to the same I had 2017, that never slipped.
If you follow the blue line at top on dynochart.
It is calculated gearratio, it should be the same through the whole rpm range.
Where white arrow is, is where the new slipperclutch engages.
It doesn´t show, but when the bike should have ~170km/h on the roller, it only has 121km/h, that is a lot of power being spun away.
And today, the pic doesn´t show, the rear tire became flat after 4 pulls.
And already at third pull the bike were loose in the rear, it kind of 'drifted' like drifting on the roller.
Result is 49.95hp 11750rpm with a lot of tractionproblems.
The peakpower should be around 12600-13000rpm
What is the issue with getting the Ex port/duct modeled.
You have the Ex port shape you want ( a sketch on a plane across the bore offset from the mid line plane ), and you know the duct exit shape ( on an angled plane offset from the same mid line plane ).
Then all you need are multiple guide curves between the two to generate the duct shape along its length.
You can then also use the end point guides to make it any angle you want where the cut/loft enters the bore and then exits the casting.
The guide curve splines enable you to achieve the droop in the roof ( between the bore and the side Aux duct entry (, as well as the floor ski jump .Both of which reduce the duct volume in the right places.
Doing the duct as a surface extrude and then thickening it outward is one good way of generating a consistent water cooling jacket as well.
But many people do the reverse and generate a port core solid ( that can then also be used to manufacture the casting core easily ).
Dutch , the homologation of the new engine still allows huge changes in the head and port/duct configurations.
I wont know till I talk to Franco at Vegas exactly how much of my input will be seen in the first customer R1 engines.
Its all very secret squirrel and hugely ego driven - but im not after any sort of recognition ,as I got paid anyway ,and can still implement the tested ( but maybe unused ) details in new engines I build.
Two strokes & rum!
Two strokes & rum!
Edgecombe
Tim from Team ESE took out this seasons AMMC F5 Bucket Championship.
going down hill with the wind up its arse.
And Tim also gave the water cooled Suzuki NSR-GP 110 its maiden outing in A grade F4.
Easy to get the main jet right on the dyno but it took the best part of the day to get the needle, slide cutaway and pilot jet right. By the end of the day it was fair buzzing around the track.
This build was all about using basic parts without any tricky porting or pipe building. Stock cases, standard inlet and original GP carburetor, original NSR cylinder, re plated but no porting work at all and a discarded pipe from an old NF4 RS125. The only trick part is the de stroked crank. If you can get the crank done then the rest of it is basic engineering with no clever 2 stroke tuning knowledge required at all to have a competitive F4 bike.
Yep Mt Welly is gone. There are quite a few cart tracks around in other towns. I think the current plan is to do a two day camping on site away meeting maybe every two months.
Thanks!
Very true.
My first attempts were like in your videos, the problem is the first section with 0° exit angle. I'm trying to find the least complicated way to have a 20° exit angle from the bore wall while retaining the right port shape. Harder than I thought it would be.
Two strokes & rum!
There are currently 175 users browsing this thread. (0 members and 175 guests)
