Yes.......... your right.......![]()
seeing as how they have built 2 new bikes and rebuilt another + keepet 2 f5 and a 4th f4 bike going I dont think they have done to bad do you ?
I bet there isn't a standard fxr as reliable and fast as my 2 smoker. 18 h/pat the rear wheel. 5 years and counting, 4 2 hours, 3 taupos , 5 years non stop racing and I have had the engine apart only once (to see how it was going)
My standard FXR engine is having a freshen up after 4500 race km (all at ruapuna, levels, methven, nelson and greymouth street races) thats after Sketchy owned and thrash it. Relaible....i'd say more than........faster we will never know but it wasnt as fast as the ones that won the last three taupo gp's.
I never questioned what Team ESE has achieved this year....just thought the team might have started preparing earlier?
how much earlier should they start ? ( 20th november 2008 )
there has been more than 250hours spent on each of the 2 new bikes this year + Ned kellys bike has had a compleat rebuild
the 2 f5's are still running
then zebras bike needs a tune
a couple of fxr's to run up and play with
a half dosen hours on Speedpros bike
Tz's rg50 to finish
the aprilla 50 to start
you get the point ? there just isn't enough time in the day ( or year )
they spend more time playing with bikes than working and started before getting home from the last TRRS
There is certainly something to be said for FXR's and with any luck they might make it 4 in a row .........![]()
We started in earnest on our new Taupo bikes last March and have been working hard on them all year, I can't believe we have run out of time ....
Looks like I will be dragging an untested bike to the TRRS, still if it all turns to custard there will be plenty of exciting Bucket racing to watchand people to catch up with.
Just test it changes gear properly this time huh TZ?
One week to go before Taupo and this is where I am at.
The engine vibrates real bad and I need to re-balance it.
As there is no one universally "correct" balance factor, there is only the one that works in your bike and it has to be found by trial and error.
Engine frame and suspension all affect how much you feel the vibration given off by the crank. The likely range of ballance factors that will work well with a high speed 2-Stroke seems to be in the region of 50% to 65%
Check out the quote for info on working out ballance factors and how to change them.
Looks like testing in the rain over the weekend will you be splashing around over the weekend?![]()
No, Family Xmas get together.......... are you ready for Taupo? will the RS be there?
I must have been lucky. The KE125 bottom end with RG400 piston runs smooth as silk. I would be interested to know if the other builders with the same setup have had similar results.
There are currently 177 users browsing this thread. (0 members and 177 guests)
