Page 2063 of 2773 FirstFirst ... 10631563196320132053206120622063206420652073211321632563 ... LastLast
Results 30,931 to 30,945 of 41592
  1. #30931
    World beating super shit hot two stroke fuel injection is old hat now. This could be Team ESE's next Side Car project.
  2. #30932
    World beating super shit hot two stroke fuel injection is old hat now. This could be Team ESE's next project.
    thats 90cc each cylinder me thinks. they got me another time.
  3. #30933
    Then we'd better provide you with some more pictures of the beast.
Name:	Maxiscoot Michael Burgard patent 01.jpg
ID:	339494 Click image for larger version.
Name:	Maxiscoot Michael Burgard patent 02.jpg
ID:	339495 Click image for larger version.
Name:	Maxiscoot Michael Burgard patent 03.jpg
ID:	339496 Click image for larger version.
Name:	Maxiscoot Michael Burgard patent 04.jpg
ID:	339497 Click image for larger version.
Name:	Maxiscoot Michael Burgard patent 05.jpg
ID:	339498 Click image for larger version.
Name:	Maxiscoot Michael Burgard patent 06.jpg
  4. #30934
    And some more.
Name:	Maxiscoot Michael Burgard patent 07.jpg
ID:	339510 Click image for larger version.
Name:	Maxiscoot inserts.jpg
ID:	339509 Click image for larger version.
Name:	Maxiscoot dimensions.jpg
ID:	339511 Click image for larger version.
Name:	Maxiscoot twin-01.jpg
ID:	339508 Click image for larger version.
Name:	Maxiscoot twin-02.jpg
ID:	339506 Click image for larger version.
Name:	Maxiscoot twin-03.jpg
  5. #30935
    hey frits in that first photo is that what wobbly keeps refering as wasted studs?
  6. #30936
    Looks like it, doesn't it? But in Wobbly's case (pictures below) they really are studs, holding the cylinders and the heads down.
    In the Maxiscoot cylinder they are merely filler bars, hanging from the head cover; they have no connecting function.
Name:	waisted studs-00.jpg
ID:	339512 Click image for larger version.
Name:	waisted studs-02.jpg
  7. #30937
    I thought the maxiscoot ones locked into underside od the bottom allen bolt "studs" and then hold the head on,
    If not is there only reason for being to provide access for the to closely spaced 50cc stud pattern?
    If thats the case why attach them to the head a all?
  8. #30938
    I thought the maxiscoot ones locked into underside od the bottom allen bolt "studs" and then hold the head on, If not is their only reason for being to provide access for the too closely spaced 50cc stud pattern?
    They provide access to the studs and they fill the space above those studs in order to create decent flow paths for the auxiliary exhaust ducts and the B-transfers.
    Where else? You can't just screw them into the cylinder; they need to be held in a fixed position. The small pins indicated by the arrows are taking care of that.
Name:	Maxiscoot Michael Burgard patent 01b.jpg
  9. #30939
    And some more.
    Frits, looks like a neat bit of intersitial engineering (ie filling the gaps).
    Now the reed block manifolds. Are these nylon of some sort and were they moulded, 3D printed or machined from solid?
  10. #30940
    5th January 2013 - 13:23
    89 KX500
    USA
    I just noticed the keyslots in the casting.
    I'm going to guess that the patent holder, Michael Burgard, is a moldmaker by trade.
  11. #30941
    I am so sick of our Sla 3D printer. Bane of my life.
    Ok. . . Not as bad as the accountant.
  12. #30942
    They're 3D-printed. I don't remember the type of material.
    I just noticed the keyslots in the casting. I'm going to guess that the patent holder, Michael Burgard, is a moldmaker by trade.
    Guess again, Larry. Burgy is a two-stroke developer by trade; has been all his life.
  13. #30943
    6th February 2016 - 06:52
    ducati
    Who says they need to be fixed???
  14. #30944
    That was me, wasn't it? Are you thinking of doubling their function and rotate them like throttle valves, Shnaggs? Good idea
  15. #30945
    ducati
    I was actually
