Page 2067 of 2773 FirstFirst ... 10671567196720172057206520662067206820692077211721672567 ... LastLast
Results 30,991 to 31,005 of 41592
  1. #30991
    24th February 2013 - 08:12
    1993, suzuki rgv250
    You're right, of course. And even on the Aprilia RSA, with all those goodies that you're not allowed to use on a kart engine, like electronic power valve, pulsed power jet and 3D-ignition timing, a less restrictive restrictor could have its use. That is one reason I designed the restrictor-bypass shown in the drawing below (the other reason was to avoid high-rpm part-throttle detonation). But Jan Thiel retired before it could be put to the test.
    Attachment 339641
    Thinking about this problem with high "rpm part-throttle detonation". Could it help if one would combine the above restrictor bypass with an ATAC and a Suzuki type tripple blade exhaust valve (for example) where the third, top blade, would be higher up than normal and used to only be opened together with the ATAC valve at high rpm part throttle situations? It would relief the cylinder pressure earlier and the ATAC would change resonance such that return wave will be delayed (weakened?) and the restrictor-bypass lowers the magnitude of any moving pulses?
  2. #30992
    1993, suzuki rgv250
    Second blade..as the third blade is not moving, just for filling out the top.
  3. #30993
    Yes, increasing the blowdown angle.area beyond its present value would help counteract the high-rpm, part-throttle detonation, Norman. Your third blade (the Aprilia cylinder already has two blades) would also clutter up the shape of the exhaust port timing edge, which would cost power everywhere, and it would interfere with the coolant access around the exhaust port.
  4. #30994
    1993, suzuki rgv250
    Yes Frits, you are right, the timing edge there will not be so good..
  5. #30995
    26th April 2013 - 21:55
    BMW R1200R 2009
    Attachment 339641
    Frits, your concept of a variable tailpipe / restrictor-bypass was probably born with the idea to implement it on the absolute top performing two stroke engines at that time : the 125 cc GP engines and even the best at that : the RSA by Jan Thiel. What do you think of a possible use in other categories, like MX ? Do you think that your system could benefit a modern 250 2 stroke engine, of course when coupled with a well designed exhaust ?
    The 250's are not that far behind a 450 foulstroke, but they suffer very badly from a less usable (more narrow) powerband compared to the newest 4 strokes.
    Could your system be a way to broaden the powerband of an existing MX bike ?
  6. #30996
    3rd August 2012 - 02:39
    yzf 250
    holland
    Wel designed exhaust 262 cc 2 stroke ( were are the 450 fourstroke )
    https://www.youtube.com/watch?v=38aIL9f_G7k
  7. #30997
    For an engine without a power valve I would not hesitate to say yes, but I don't think we'll find a single MX-bike without a power valve these days.
    The restrictor bypass will no doubt counteract high-rpm part-throttle deto on any engine, but those MX-bikes are not that highly strung: a 250 cc MX-engine makes less power than a 125 cc GP-roadracer, so maybe they haven't got that deto problem. You'd have to try it, Peter. And let us know what you find .
  8. #30998
    Quote Originally Posted by patouille View Post
    Hello,
    I just registered in this forum as I saw this very interesting topic. I'm glad to see someone is trying and sharing his ideas.
    I built my own 2S EFI for my racing Solex (a very particular 50cc here in France).
    The beginning is very encouraging, take a look : https://www.youtube.com/watch?v=LW19l64nm7Y.
    I love it...... a fuel injected Solex racer.
  9. #30999
    Sat at the computer a couple of nights ago and tried to make an excel sheet for an evaluation of transfertemp vs power that we are going to do in dyno. Do not think i got it right wondering if there's anyone who can correct below. Perhaps you who are injecting have knowledge about this
    Added RSA values ​​as well as I know.
    125 cc
    Peake power rpm 13000
    54hp crank
    202 ° dur 56,767cc closed
    Gas for this test
    Octane (R + M) / 2 98
    Research Octane 103
    Motor Octane 93
    Specific Gravity 0.762
    Oxygen (weight%) 0
    Leaded No.
    BTU / Lb 18240
    Btu / Gallon 115800 (cooling props)
    Stoichiometric Air / Fuel Ratio 14.6
    trapped volume121.4cc at 40 ° C mix and 40% Engine efficiency of trapped.!?
  10. #31000
    Try this Muhr.
    125 cc
    Peak power rpm 13000
    54hp crank 54 hp at the gearbox exit shaft= about 57 hp at the crankshaft
    202 ° dur 56,767cc closed 57,4 cc trapped stroke volume above the exhaust port + 8,6 cc combustion volume
    Gas for this test
    Research Octane 103
    Motor Octane 93
    Oxygen (weight%) 0
    Leaded No.
    BTU / Lb 18240
    Stoichiometric Air / Fuel Ratio 14.6 Lambda=0,85; actual air/fuel ratio=12,5
    trapped volume121.4cc at 40 ° C mix and 40% Engine efficiency of trapped. Trapped volume=66 cc , 140% efficiency
  11. #31001
    Try this Muhr.
    Hello Frits thanks oracle
    What I did was tried to calculate the minimum amount of air / fuel needed for each revolotion to be able to produce the desired power output with the energy content of this specific fuel.
    So with your new values, I get 128,1cc trapped at 13000rpm or
    1: 1,945 in pre-compression. which I do not believe.
    Do you remember which fuel RSA run on?
  12. #31002
    The fuel was AGIP, 102 octane, with 5 % oil mixed in.
    For me, trapped volume means the maximum volume above the piston when all ports are closed. But obviously you use a different definition. What's yours?
  13. #31003
    As the calculation is now, I need 128.1cc of air at atmospheric pressure doing work to produce 57hp crank.
    I agree with your definition of trapped, I was unclear
  14. #31004
    22nd November 2012 - 23:14
    Anything with 2 wheels
    Chonburi, Thailand
    So maybe a redesign of the pipe biased towards the top rpm range, with a smaller restrictor, and then the bypass system to reduce the chance of deto (if this now becomes an issue), and also bring the midrange back up. Just a thought.
  15. #31005
    Quote Originally Posted by Matt@TYGA View Post
    Matt could you give us a run through on how to tell NSR model cylinders apart and what the differences are?
