In my defense , that engine ran on Methanol , so crankcase cooling wasnt a limiting issue at all.
Thanks for the info on the rod lengths guys.
I'm hoping for more time this year to do some engine projects instead of just staring at my computer screen 24/7.......
I'm wanting to pull my Honda NSR150SP apart for a bit of a make over, using several of the ideas from this most informative site.
Wobbly, I read before that you'd used 3D printed reed stuffers. How about a 3D printed reed valve? I understand sealing and integrity would be an issue in the long term, but it might be enough to last a dyno run or three. my cheapo 3D printed does PLA and ABS without issue, and PETG at a stretch. Worth a shot maybe? I think with the incoming mixture helping with cooling that it won't just end up in a nasty blob in the bottom of the case, and should it fail catastrophically then hopefully no engine damage will occur. I'm just thinking about Wobbly's work with thick and thin reed petals to direct flow. Maybe worth a shot at actually having an angled valve to direct flow instead of relying on the petals.
Got the extendo, water cooled exhaust port stub to try also. Looking forward to seeing what that does. Only got the 3D printed version at the mo which was just to test fit. Will knock something up in aluminium for a dyno test. Been using the oval to round transition since 1994 for my NSR250s, so I know that works.
NSR150SP rod length is 110mm. Perhaps this length would have been a better choice for the 250, based on other info here ;-)
Anyway, here's hoping that I can get these other projects done and dusted so that I can have some fun!
Hi Husa,
Yes, well tested indeed, but we do because we can. And I could whittle a reed valve from granite with a tooth pick for less than VF charge
I haven't had anything much to do with the std NSR150, but I do know that the cylinder is totally different. Still a bridged exhaust port, but tiny in comparison to the SP. no data on the timings as all I did was look at one in the Honda shop. The head is also different and I think that the piston is different too.
The old model NSR150R was a single port with a single flap exhaust valve. We cut auxiliary ports when I raced one back in 1995. Also welded up the valve and trimmed it to a nice snug fit. What was noted then has been well documented here in that the wider one went with the auxiliaries, the more power it made. Right up until we broke into the water jacket. the way to go would have been to cut in from the outside, weld up and fit a patch, but we weren't allowed to alter the outside look of the cylinder. Crying shame.
We ended up at about 40hp at the rear wheel, on avgas. Honda gave us the bike at 21hp.......
The piston and crank had to be stock. As did the reed valve, but you were allowed to modify the reed valve. Had a PJ34mm carb.
I didn't really fit that well on it and much preferred the 250.
Yes on the intake. Fitting an MC21 carb boosts things at the top end, but need to make a spacer block to get clearance, which is a pain.
Matt.
Never say never, Ken. Having air flowing between crankcase and gearbox is a good thing for sure. But then this air exits right under the exhaust header. Not under the first part of the duct, that should be cooled, but under the remainder of the header, where gas energy should not be used for global warming, but for efficient wave action. A heat shield wrapped around the header would be the obvious solution in my opinion, but I could not discover any trace of it on the Vortex documentation.
As air cooling question is more or less elaborated, next question about added transfer ports. On the drawing is common moped/old timer arrangement. Easiest is to drill/grind finger B ports. But, because of intake port there is very little or no space for adding finger-C port ,then additional "bypass" C ports are fed from B ports.
So cross section of B duct untill starting of "bypass" should be equal B+C ports after junction to spread the flow more or less equally.
Is it better to have only B ports with uninterrupted flow or to use as much area as possible with C port?
The other issue is that all added B and C ports are aiming upward cyl head which is good for overrew as I could see on my test track and mychron. Lowering upward angle of B ports to 10°( which is sometimes achievable)like on "modern" cylinders added some power but lost a bit of overrew.
Any comments?
(PostalDave on ADVrider)
Crankcase Cooling
The question is, do you want to shield the cylinder from the heat generated in the crankcase or isolate the cylinder heat and keep it away from the crankcase. Which side needs the extra cooling the most?
No problems with sealing when you use copper head gasket sealing paint/glue.
Copper under the exhaust tract to improve cooling in that area.
Crankcase air cooling, you can go as crazy as you like.........
Maybe check the rules rob does it say liquid cooled or water cooled.
if it says Water oil is on the table
nope has to be air cooled
https://www.mnz.co.nz/docs/default-s...ses-(road).pdf
There are currently 165 users browsing this thread. (0 members and 165 guests)
