Page 2081 of 2774 FirstFirst ... 10811581198120312071207920802081208220832091213121812581 ... LastLast
Results 31,201 to 31,215 of 41608
  1. #31201
    ......... whats the answer if the aim is to air cool the base of the cylinder and the transfers and any extra air cooling of the crankcase and its oil is just collateral damage.
    Pack it with paraffin
    https://ntrs.nasa.gov/search.jsp?R=20150003481
    http://www.andores.com/sale-9516724-...ge-system.html
    http://www.autospeed.com/cms/article...ooler&A=110772
    Specifically, its typical characteristics are:
    Melting point: 52 degrees C
    Specific heat: 3.27 kJ per kg per degree C
    Specific heat of fusion: 210 kJ/kg
    So to increase the temp of 1kg of the wax from 47 to 52 degrees takes 16.35kJ, but to push it past 52 degrees takes nearly 13 times as much energy. (Or, to risk causing confusion, you could dissipate in it a power of 14kW for 15 seconds to melt 1kg.)
    Paraffin wax is non-toxic, doesn't explode (although it will catch fire if you expose it to a naked flame) and is easily handled. Special waxes designed specifically for this change-of-state heat storage purpose are also available with melting points in 10-degree C increments from 50 degrees to 100 degrees C, however their availability is obviously less than simple candle wax.
  2. #31202
Name:	Air Cooled RGV125.JPG
    That was part of my air cooled RGV project. I abandoned it when I was handed the gift of 110cc max oversize for H2O 2T's.......
  3. #31203
    Sometimes clever people make their own luck.
    That said cooling that gear box oil would be pretty easy and cheap old trans cooler or oil cooler off XR400 are neat or even pitbike.
ID:	340175Click image for larger version.
    https://newmanz.co.nz/shop/index.php...2l567mce443pq5
    some of the car ones are WC now
    https://www.aliexpress.com/item/Tran...826806175.html
Name:	Transmission-Oil-Cooler-for-2012-2017-Toyota-Camry-2-5L-2ARFE-ASV50-33493-33030.jpg_640x640.jpg
ID:	340177Click image for larger version.
    Hondas too.
    https://www.aliexpress.com/item/Heat...d-636aa08949b6
    this one appears to go straight to the trans look at the other pics open at back?
    looking at theses you could run dual water circuits easy colder water for cases and cylinder ex port hotter for head.
  4. #31204
    The oil coolers are very interesting. As I am running a dry sump I have a gear box oil pump so it should be pretty easy to add an oil cooler. A water one would be great as the radiator runs about 40 deg C.
  5. #31205
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Some Mazdas (no idea sorry) had a little radiator to cool the power steering fluid. I've read of one being used in a water cooled CPU computer rig
    (PostalDave on ADVrider)
  6. #31206
    23rd March 2015 - 21:24
    Conti RX356 V3
    nearly all cars with an automatic double clutch transmission have a gearbox oil cooler. the issue I see is once the oil temps drops the viscosity will increase and therefore the losses, so you might ne to readjust for the cooler temperatures.
  7. #31207
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    If your drawing is somewhat to scale. I would have a piston-window fed single c port.
    It's schematic. In reality, with single dykes ring piston there is 2mm space between top of the inlet and ring.
  8. #31208
    Mazda 6
    or these
  9. #31209
    Yes,but this as a small rad, maybe 100 x 100mm, small enough to mount on a bike without over cooling
  10. #31210
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    If I remember correctly, Martin Wimmer on his TZ250N, back in '85 ran a transmission oilcooler in an effort to cool the crankcases. I think it was done by Helmut Fath.
  11. #31211
  12. #31212
    Quote Originally Posted by vannik View Post
    if i remember correctly, martin wimmer on his tz250n, back in '85 ran a transmission oilcooler in an effort to cool the crankcases. I think it was done by helmut fath.
    fairing nose?
    Although this is 83
    if they kept using it..........
  13. #31213
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Yes, that wont work.
  14. #31214
    sweden
  15. #31215
    24th February 2013 - 08:12
    1993, suzuki rgv250
    How hot can the transmission oil typically be in a two stroke high performance engine?
There are currently 72 users browsing this thread. (0 members and 72 guests)
