Page 2082 of 2773 FirstFirst ... 10821582198220322072208020812082208320842092213221822582 ... LastLast
Results 31,216 to 31,230 of 41592
  1. #31216
    TZ could you reverse the cylinder?
    Yes, very easily.
Name:	H2O GP110cc.JPG
    But unfortunately the fat part of the pipe would be in the most restricted part of the bike.
Name:	Katies RS-GP125.jpg
    Katie's air cooled GP125 gives an idea of how crowded the Honda RS125 NF4 frame is.
    Tim's NSR-GP110. The mono shock and "A" frame swing arm are the biggest obstructions to reversing the cylinder.
  2. #31217
    Mazda 6
    That Mazda oil cooler looks the go. I will have a look at Pick a Part for one.
    How hot can the transmission oil typically be in a two stroke high performance engine?
    It looked like 90 - 100 deg C on my bike. It would be much better to be 30-40 and used for cooling the crankcase and inlet tract of my RV.
  3. #31218
Name:	AMA RACER SANDRA STAMMOVA.jpg
    Monocycle. not only is Sandra backing the bike into the corner like a flat tracker, the front wheel is off the deck.
    https://www.motorradonline.de/leute/...va.615252.html
ID:	340202Click image for larger version.
ID:	340203Click image for larger version.
  4. #31219
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Yes, very easily.
    Katies air cooled GP125 gives an idea of how crowded the frame is.
    250 kart? cylinder on the gp 125? in nsr 50? frame. Either way I like it.
  5. #31220
  6. #31221
    Honda NSR250, cylinder on a Suzuki GP100 engine, RS125 NF4 rolling chassis.
    The plate down the center of the cases is so a six speed gearbox can be fitted to replace the old five speed unit. It has a Kawasaki KE175 rotary valve cover and runs a Yamaha RD400 con rod assembly and Suzuki RGV250 big end brg, it currently tops out at 13,500 rpm.
    The whole story can be found here:-
    Follow the links to read the whole story about Team ESE's GP/NSR110cc engine build.
    There are several of these engines.
    One is fuel injected. The fuel injection system is still under development:- https://www.kiwibiker.co.nz/forums/s...2T-EFI-Project
  7. #31222
    sweden
    There are several of these engines. Ok, I'm currently reading the story about Thomas, thought it was an alter ego at first, great reading
  8. #31223
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    About 100°C or more
  9. #31224
    Two Stroke GP Restorations, worth having a look at. As well as pictures of their restorations there is a few clips of the "real" sound.
    https://www.facebook.com/60095201003...72575532873258
  10. #31225
    Thanks, nice eye-catching picture.
    MCN about RGV 500 1998, for photo collection.
    http://www.mcnews.com.au/1998-suzuki...prix-500-aoki/
  11. #31226
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    Anyone, variable crankcase volume. Piece of garden hose and different lengths (volumes)
  12. #31227
    20th June 2012 - 00:17
    yamaha
    Im going to ask a question and I want a general answer
    What does a pipe with a bid mid section have or not have in relation to a pipe with a mid section. Ie spread of power
  13. #31228
    Ideally the crankcase volume is one big volume without any nooks & crannies.
    Your setup could act as a pneumatic damper, unless you use a short length of big diameter hose.
    I want a McLaren 720S. And a camper. What is a bid mid section?
  14. #31229
    Island of Korcula
    [QUOTE=Frits Overmars;1131121299]Ideally the crankcase volume is one big volume without any nooks & crannies.
    Probably this position neither, too close to the petals would disrupt flow sideways at some rews.
    Longer hose-decrease in idle revs is what I notice.
    Bigger diameter hose and direct to crankcase connection would be indeed right approach.
  15. #31230
    I want a Speedtail
