Page 2083 of 2773 FirstFirst ... 10831583198320332073208120822083208420852093213321832583 ... LastLast
Results 31,231 to 31,245 of 41593
  1. #31231
    I want a Speedtail
    Ugliest car they ever made. And you don't even get four hubcaps for yer money.
Name:	McLaren Speedtail-02.jpg
  2. #31232
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    Cool
    Similar design
    ...only two stroke in it
    More appropriate for this thread
  3. #31233
    Ideally the crankcase volume is one big volume without any nooks & crannies.
    Your setup could act as a pneumatic damper, unless you use a short length of big diameter hose.
    I want a McLaren 720S. And a camper. What is a bid mid section?
    At the time the "......." engine came out the panel had discussions about what turned out to be an oil separator with connections to the crankcase some thought it might be a variable volume device with a bladder inside or diaphragm to vary the volume of the crankcase.
  4. #31234
    You are so hard.
    sometimes beauty comes from within! It is possible to take a nap in the back seat, and store a Trangia kitchen in the glove compartment. And why not use the hub caps as plates. see best of both worlds
  5. #31235
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Im going to ask a question and I want a general answer
    What does a pipe with a bid mid section have or not have in relation to a pipe with a mid section. Ie spread of power
    The general answer is it converts more of the wave energy into a negative wave.
  6. #31236
    24th February 2013 - 08:12
    1993, suzuki rgv250
    About 100°C or more
    Thanks for the info Jan. And with the hot exhausts coming down the transfers at highest rpm and/or low throttle also heating up the internals of the crankcase I see the advantage of having high flow low temp liquid cooling of it..
  7. #31237
    The crankcase being bolted to a cylinder and head burning petrol at 1000's of degrees the friction of a piston and sealing ring and the act of compressing the air fuel mixture also account for most of the heat along with the gears meshing and clutch might account for a fair bit of that heat. as is just spinning shafts and bearings at high rpm's.
    Just touching the outer gearbox cover of a hard running gearbox is pretty much an eye opener and hand burner.
    Unfortunately due to the rules and design limitations on TZ's bucket ,water cooled crankcases although the obvious best solution isnt a really an option
  8. #31238
    remember when photos of that engine were first seen and everyone was frantic to figure out how it worked and what secrets the large cyl spacer was hiding and what purpose was the glass jar and how could it possibly rev to 30k . those are days ill never forget
  9. #31239
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    It was all nonsense of course...
    Not even 1 was sold
  10. #31240
    So who's money was getting pissed away?
  11. #31241
    26th April 2013 - 21:55
    BMW R1200R 2009
    Not even 1 was sold
    This is the most recent status on their patent demand. https://patentscope.wipo.int/search/...IO&maxRec=1000
    No economic activity that I could find...
    Mister Gerrits Gerrit Hendrik and the mysterious german Aumiller Danny Walter are good in hiding in the dark...
    In 2016 he created a company called "Rygerbaas BV" that was cancelled in november 2018 https://drimble.nl/bedrijf/almelo/33...erbaas-bv.html
    The original company "Ryger-Engine" that was created in 2013 seems to still exist https://drimble.nl/bedrijf/almelo/27...er-engine.html
  12. #31242
    Gerit posted on a thread for a while
    Aumiller drobve the kat in this video
    https://www.youtube.com/watch?v=RJbxxdzhESA
    But here he is
    https://www.linkedin.com/in/danny-aumiller-383558134
    He it seems is a engineer andd specialises in sealing etc
  13. #31243
    Shame we had to ban one " engineer " from this site , who was till the end still reciting the company line " its almost ready ".
    And the other " engineer " fixes compressors - about all is good for and manages to drive one faster than some 4T hire karts.
    The whole thing was completely mismanaged from start to end and was doomed to fail , as everyone seemed to be either full of shit or highly narcissistic
    or both - and I say that fully recognizing I am one.
    Where the hell are all the engines that were built for the CIK homologation process , as no way would they have been signed off without them.
  14. #31244
    I'd pick locked in a container somewhere. If they'd been scrapped, someone would have latched onto one. Scrap yard guys are notorious for picking up anything they can make a buck from.
  15. #31245
    Somebody/s lost some serious coin out of this. Glad I got a personal assurance when I ordered the V4 version or I'd be worried. It'll be ready soon, but it is taking a while.
