Page 2119 of 2773 FirstFirst ... 11191619201920692109211721182119212021212129216922192619 ... LastLast
Results 31,771 to 31,785 of 41594
  1. #31771
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    BATTLE OF THE BULGE
    The alternative to achieving more exhaust area is to add more ports than the current generic 3 port arrangement. To do this will most likely require an alternative scavenging arrangement and we all know what some of these are.
    Will this do?
  2. #31772
    Will this do?
    Niels, have put some thought into the transfer flow?
  3. #31773
    27th November 2012 - 11:25
    16' xtz125e super-adventure, Ninja 650
    may aswell go 4 stroke
  4. #31774
    1991 MZ 301
    Denmark
    Lots of thinking.
    My MZ had mikuni oil pump and that shall feed directly on the cam.
    A reed valve inlet directly into the scavenge port belt will do until I get wiser.
    Dreams of not much else.
    To old for women, money and power.
    When the sidevalve single has proved what a genious I still am,I will do a directcoupled V2 for aircrafs.
    The pistons need not have same diameter.
  5. #31775
  6. #31776
    4th May 2016 - 21:50
    Bultaco Metralla GT
  7. #31777
  8. #31778
    Yes plenty of examples of uniflow scavenging.
    There is an issue with transfer flow into the cylinder to get a clean fill, the gas doesn't necessarily go where the little arrows point.��
  9. #31779
    i made up some exh spigots. just alittle more work on the water jacketing at the side of the cyl and figure out some sort of water nipples near the exh exit. easiest for me would be some threaded weld on bungs then a brass 90* elbow screwed into the bung but that sharp 90* may not be the best for water flow. what do you guys think ? I kind of wanted to make the elbows removable but I haven't found anything other than the brass 90*. I guess i could probly make a bit of a radiused elbow with a bunch of pie cut tube welded together
ID:	341774   Click image for larger version.
  10. #31780
    ..... that sharp 90* may not be the best for water flow. what do you guys think ? I kind of wanted to make the elbows removable but I haven't found anything other than the brass 90*.
Name:	Screenshot (151).png
ID:	341776 https://www.jegs.com/i/Aeroquip/023/FBM4032/10002/-1 these bolt onto a nipple that is threaded into the engine block.
    Expensive but light and come in all sorts of sizes and look the bees knees too.
  11. #31781
    18th October 2015 - 06:45
    Aprilia tuono 03/ 2x ktm 500 89
    Netherlands
    Hoses
    https://www.siliconhoses.com/search?...one+hose+bends
  12. #31782
    A welded on bung with a right angle 8mm hose tail on each spigot end going up to hose tails screwed into the triangle outlet
    piece in the head will flow more than enough water imho.
    Of more concern is the hopeless water flow regime from the factory.
    You need to change it with all the cold water entering the cylinder in the middle at the rear.
    Then using a lasercut "gasket " that forces all that flow to travel around each liner above the transfer tops.Then up into the head
    at the front , flowing around the inserts and exiting the head cover at the rear highest point.
    The trapped water at the highest point in the cylinder rear needs a couple of small bleed holes to allow air to escape into
    the head.
    Makes the system self bleeding , and uses the coldest water to cool the transfers.
  13. #31783
    What, as opposed to a bucket with a 2 holed lid and a weak hose pushed in one and outlet in the other,?
    If it was good enough for Kenny Roberts' 3rd uncle. . .
  14. #31784
    I have been fighting a bit of a battle with the PesudoMAP sensor. The issue is that the PesudoMAP value drops away over 8,000 RPM or so as seen in the picture above (Yellow line). Currently my code can make a sensible reading every 8 deg at 13,000 RPM and with a bit of clever coding it could make a reading every 2 deg. 8 deg is good enough for the three high pressure readings I make at 15 deg intervals. 115, 130, 145 deg ATDC.
Name:	MAP sensor signal at 4k RPM.jpg
    So I put the oscilloscope on the crankcase pressure sensor tonight, purple line, yellow line is the ignition pulse. I wanted to see what sort of signal it produced and what it looked like compared to EnginMod's prediction. Pretty close I recon. The next move is to try and capture a trace at 12,000 rpm.
    I have been having problems with the MAP value dropping away above 8,000 RPM and suspect either the pressure sensor is not keeping up or the speed of response from it is so slow that the indicated pressure peak moves away from my last measuring point at 145 deg ATDC.
Name:	Crankcase Pressure Traces.png
  15. #31785
    the head.
    thats great idea but with sqaushed cylinders its hard to have much water on that side. whats worse still is most of the water jacket is filled with weld to let the aux ports go to near bore center. ill do the best i can and that will have to be good enough
There are currently 120 users browsing this thread. (0 members and 120 guests)
