Page 2122 of 2776 FirstFirst ... 11221622202220722112212021212122212321242132217222222622 ... LastLast
Results 31,816 to 31,830 of 41630
  1. #31816
    Ken, you will have to trade it on a TM now😆.
  2. #31817
    At least TM are good enough to send me one😆.
  3. #31818
    I'm happy for you, Neil. By the way, how are TM-gearboxes?
  4. #31819
    Haven't sampled it yet. Do they have a problem? It is just a 125, interestingly.
  5. #31820
    I don't know about any problems. I was asking because you always seem to struggle finding Yamaha gearbox parts and I thought your Italian friends might have a solution.
  6. #31821
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Vforce Reed valve on Honda Nx4. Breaks every 2 races. An idea ?
  7. #31822
    turn the little metal bar which keeps the plates in place around (set stiffness from low to high).
  8. #31823
    2nd August 2011 - 11:11
    Connecticut, USA
    reeds
    That is pretty ugly. It looks like something is not agreeing with the resin. I had heard that V-Force may have changed resin at somepoint over the last year or 2. We were having some problems with reed delamination/chipping about a year ago but nothing to the extent that you are seeing. Today we are still getting some chipping at the reed tips.....we are running methanol not gasoline.
  9. #31824
    wob you can see the cooling will be complete shit but since its not a road going petrol engine im not losing any sleep over it. with a small bit of grinding I got barely .5mm air gap between the cyl . just have to weld on the water bungs then off to the machinist and straighten out the decks
ID:	341851   Click image for larger version.
ID:	341852   Click image for larger version.
ID:	341853   Click image for larger version.
  10. #31825
    I found this yesterday but it gives some idea of how much flow is reduced with elbows in the cooling lines
    https://www.ekwb.com/blog/do-angled-...y-reduce-flow/
  11. #31826
    Quote Originally Posted by dtenney View Post
    V force told me their reeds were not compatible with ethanol, perhaps its the same with methanol.
    You need a steel rotary valve😆
  12. #31827
    You need a steel rotary valve��
    Well, given that methanol is normally more aggressive than ethanol to epoxy resins, that's most likely true.
  13. #31828
    Drop one of your broken ones in some of your fuel mix. Post pics please.....
  14. #31829
    hey guys on the yami twin theres a small hose from the head to top of rad. im guessing this is a self air bleeder like the bleeder screw found on most other heads. what im not sure of is if its only purpose is just for the first time the system is filled and after that its useless. ?
  15. #31830
    I have something similar on my bike. It continuously runs a small amount of water from the head to the radiator and takes any evolved air/gas leakage with it. As well as being easy to bled the head, it Leaves me confidant I am not going to wind up with an air/gas pocket at the back of the head. It is a piece of mind thing.
There are currently 229 users browsing this thread. (0 members and 229 guests)
