Page 2132 of 2776 FirstFirst ... 11321632203220822122213021312132213321342142218222322632 ... LastLast
Results 31,966 to 31,980 of 41632
  1. #31966
    I admire the effort. They are certainly all memorable ......
  2. #31967
    Perhaps a descriptive name with a really memorable acronym, one that a major Corp is unlikely to appropriate.
    Crankcase Resolution of Airflow & Pressure.
    Parameters Of Oscillating Pressure.
    Pressure Evaluating Numerically Iterated Simulation.
    Measurements Inferring Localised Flow.
    Mass Airflow States Tabulated Under Repeated Base And Top Exhalations.
    All kidding aside... Great Work Tee Zee..
    Cheers, Daryl
    The acronyms are certainly memorable ....... Thanks ....
  3. #31968
    https://www.google.com/url?sa=t&sour...Nxc_qcqTH6T9jb
    What is this shit? Rendered down snakes?
    Only the Mercans can write that style of marketing blumph.
    Of the product itself, the very real benefit is the humble but bloody useable PWK wears its needle jet and its non replaceable. A replacement block with new jet is a way to fix an ailing carb.
    As far as being an improvement over stock I have no idea, but there's a few people raving about them on the dirt forums having done multiple bikes. Maybe there's something in it.
    But I won't be trying one out of interest as damn they are expensive.
  4. #31969
    I'd rather get one of these:
  5. #31970
    The H2 may be experiencing the age old issue of overscavenging.
    The pointers are the resleeve - were the A port front walls exactly the same backsweep angle before and after ?
    And second - the low egt , a real big givaway you are dragging A/F mixture straight out the Ex duct from the front transfers.
    These old engines for sure need more rearward angle on the A port as soon as you start using an efficient ( fat ) diffuser , and the
    flat/non staggered timing edges are crap as Frits said.
  6. #31971
    2nd January 2015 - 06:12
    RG500
    Thanks Wobbly
    So you mean it is not a problem with 204* ex duration?
    The exhaust side wall of the a-port is way more rearward aimed now then before resleeve. Before it was more aimed against center of bore now it is against boost ports (it is reed)
    The transfers are 22/10/50 but not staggered, before resleeve they were more "old school" 10/5/50
    The pipe is not fat diffuser pipes, they are typical old slim design. The previous owner of the bike use to have fat pipes but never got them to work.
    The egt was actually not any hotter before the resleeve
  7. #31972
    Quote Originally Posted by rtechracing View Post
    Thanks Wobbly
    How about some pictures?
    Lets go Brandon
  8. #31973
    Yes, we all love to see pictures of other peoples projects.
  9. #31974
    26th April 2013 - 21:55
    BMW R1200R 2009
    Couple more pics of the TM 300 Fi engine
    And another bit of electrical consumption...exhaust power valve.
    Cheers, Daryl.
    That is the most interesting part of the new TM 300 : till 2018 they had a servo + cable operated power valve and now a custom made system without cables, which should be more reliable. And now that KTM has a balance shaft, they have it too. Good thing !
    Unfortunately, it still is a copy of the honda CR250 2002-2007. It still has the typical honda exhaust...
  10. #31975
    The problem with the H2 is probably quite complex in that you are dealing with a mix of old and new ideas, along with increased blowdown
    capability gained by lifting the main Ex port.
    The problem with the high Ex duration is that this increases the time available ( and the efficiency due to higher opening pressure ratio )
    for the diffuser to overscavenge the A port.
    You then combine this with " modern " duct exit angles , but these new angles are derived from ports that always have alot of stagger.
    Be it normal or reversed.
    Thus we have an orphan scavenging system that has no history of long development by many tuners finding out , most importantly, what
    not to do.
    Sorry but I really cant logic my way thru the changes and recommend what to actually do to fix it - as its a real left field tangent.
  11. #31976
    The Classical Performance/Development Curve. .
    Cheers, Daryl.
  12. #31977
    6th October 2015 - 13:42
    2001 kx250
    USA
    Stic Metering Block
    George Boswell is the man behind this, I can not (yet) confirm this does or doesn?t work, but many seasoned users have given it very good reviews. I have seen his original design back about 1995 & it was very impressive the way the bikes ran and sounded.
    Here is a picture of his original design that I found on the web.
  13. #31978
    Yep, the quantum physics wormholes are clearly visible. This must be the best thing since sliced bread. Maybe even better
  14. #31979
    Oh gawd, that looks silly.
    The current product looks like the Keihin metering block and simply replaces that. Typically running larger jets I think the emulsion tube feed is altered.
  15. #31980
    2001 kx250
    USA
    Dyno
    Not endorsing the product, but IF this is a true example, then gain in HP per dollar spent is a bargain.
