Page 2151 of 2773 FirstFirst ... 11511651205121012141214921502151215221532161220122512651 ... LastLast
Results 32,251 to 32,265 of 41589
  1. #32251
    Here is a 60.5mm piston, not finished outside. Thats why there is a lump on its head, to hold on to, to do the cut aways and piston ring groove. Material? magic.
    https://youtu.be/MxyTBXiaFQw
  2. #32252
    60.5 mm piston, clearly not outside finished yet.
  3. #32253
    What sorcery is hiding in here?......
  4. #32254
    tried to put up a video but won't take.
    So here is a picture instead, my new 175 piston, 60.5mm
  5. #32255
    Thanks Wob very much about this info, maybe we must to rise C before Europian final round
    You are right, for accurate comparison test we must found right cylinder height for std piston and from this point start to test with rounded. But its even more pain.
    Usual modification route is-
    Work with bottom end (crank, crankase) then testing
    Work with cylinder, then testing
    Rounded piston, then testing
    Add photo with another modification on C, crankcase step, its mimic to hydrodiode , we do this on SX50 and World Cup SX65, but still blind zone.
    Maybe this coud help with full rounded piston, but we not tested.
    I think for all of us would be very interesting to see your work results with sharp edge at C on much higher revs and power output engines than MX.
  6. #32256
    I have lowered C port openings with epoxy. Maybe fully Radius piston and epoxy lowered C.
    Entrance of C wider than cases works good. Any benefit from A and B entrance wider than cases?
  7. #32257
    6th February 2016 - 06:52
    ducati
    Have wondered this myself...
  8. #32258
    Thanks for responce. The more information is on producer site.
    http://sibaero.ru/%d0%b4%d0%b2%d0%b8...-sibaero-2r-i/
    I nether see this engine working, only read information on Russian amateur aviation forum. Both cylinders are working (have the same themperature).
    Hi,
    On parallel two cylinders air cooled engines, aviators use isolation plate between cylinders to lower and maybe equalized cylinders temperature for both transfers sides. Without plate engine lost power.
    Maybe this help.
  9. #32259
    Yes, on dyno entrance of C wider than cases add something on reed engine, but with rotary or piston ported maybe all goes in different way.
    Minarelli scooter engines made with big step, aprox 3mm at A ex side wall and case.
  10. #32260
    DB Errors have been fixed. You can now view the thread images again.
  11. #32261
    Katinas , I am tuning for a team in OZ champs till next week , but as soon as I am back I will try C duct step ( sides only first , then all 3 edges ).
    Its a test I can do back to back on the dyno in probably 1/2 an hour , so really worthwhile if a sucess , no drama if its no use.
    I have a new piston from Vertex to test with angled squish only - then flat top.
    Once I have done this is I will CNC that piston with radius to test again , but with a sharp C edge and test C height as well.
    As I said , with full radius the front side power was very good - exactly what you want in MX.
    But using a radius with sharp C and dropping the cylinder essentially makes the C lower in timing - again good for front side power.
    I am hoping that dropping the cylinder and grinding up the C with the sharp edge will give more everywhere - including into the overev.
    Bastard 2T will make a fool of me im sure , but I have to try it.
    I think if you add big ball nose radius on the duct entry wall you will see a gain - worth over 1/2 Hp in the kart engine.
  12. #32262
    Thanks you Wob for your clear reference.
    Actually for World Cup we send boy with two reverse restrictions in C port (add sketch blue color where was grinded) because KTM 65 cylinder is relatively high. With shorter cylinder, shorter Lc, and just one step on case is enough. On dyno with 65 this add 0,3 hp with better midrange. We use grinded spark plug that Jan and Frits recommended and this again add mid range. But very interesting, it looks like plug works one number cooler that before grinding, maybe better flush..
    At World Cup boy was only one, in the whole group, with std. KTM exhaust pipe, but for us it works very well.
    But Lotte van Drunen, what a ride !!! She won both starts, amazing.
Name:	Sx65 World cup.jpg
ID:	342501   Click image for larger version.
  13. #32263
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    c port
    Katinas
    Did you test with just the overhang and then test with just the hydro diode. I wonder why the use of hydro diodes are not used on all the transfer passages for reversion? I also wonder if the placement of the diode makes a difference?
  14. #32264
    3rd August 2012 - 02:39
    yzf 250
    holland
    22 hp
    cil. std. only exhaust port and aux. ports
    And pipe
  15. #32265
    22 hp
    And pipe
    Yes this is Lotte. Congratulations for all team.
    22 hp amazing, but how high is rpm.
    Best what we see on our dyno 18.21 hp at 10861 rpm.
There are currently 143 users browsing this thread. (0 members and 143 guests)
