Page 2152 of 2776 FirstFirst ... 11521652205221022142215021512152215321542162220222522652 ... LastLast
Results 32,266 to 32,280 of 41632
  1. #32266
    Katinas
    Did you test with just the overhang and then test with just the hydro diode. I wonder why the use of hydro diodes are not used on all the transfer passages for reversion? I also wonder if the placement of the diode makes a difference?
    First time we test on an engine just with the overhang and this itself gave 0.3 hp, but on the last engine we just add hydro diode and not measure this mod alone.
    C is most unrestricted port for reversion on reed engines , shortest of all with nearly to vertical angle, very comfortable for ex gases and for back pressure from the pipe at wrong time. A and B usually shape have some restrictions, especially with sharp A B widows upper edges.
  2. #32267
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    Katinas:
    Thank you very much for the info. Doing a very good job.
  3. #32268
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    https://www.kiwibiker.co.nz/forums/a...1&d=1563307439
    katrinas, you are so kind to give information about who this graphic is and how it works (I do not have the possibility of copying and pasting the text into a translator).
    It is a stratified loading system
    Thank you so much
  4. #32269
    6th October 2015 - 13:42
    2001 kx250
    USA
    Carburetor reversion / blowback
    Trying to understand this, in this case a cylinder reed motor...What can cause this?
    Ignition Timing/Port Timing/Fuel Type/Reed Material & Thickness/Pipe/Compression/MSV???
    Current motor stroked/bored/long rod/spacer plate has a lot of reversion requiring substantially leaner jetting & wanting to have an understanding of How & Why.
  5. #32270
    3rd August 2012 - 02:39
    yzf 250
    holland
    Yes this is Lotte. Congratulations for all team.
    22 hp amazing, but how high is rpm.
    Best what we see on our dyno 18.21 hp at 10861 rpm.
    Thats very good Katinas
    22 hp 12100
  6. #32271
    Hi, Ceci
    This book is more about mathematics simulation of Two stroke process.
    About 2.12 scheme
    Mathematics simulation show that, hydro diode in trans ports, help to rise torque in the whole range, with the full open throttle . In practice this has proved itself by testing with 111cc engine bore 58mm stroke 42mm. Torque rise everywhere up to 20 percent.
    Character of changed pressure in the crankcase, indicate about much lowered flow of exhaust gases to crankcase, when piston start rise up from BDC and trans windows still open.
    Hydro diode have no influence on fuel consumption.
    Add link where you can download whole book page by page.
    http://padaread.com/?book=742&pg=1
  7. #32272
    22 hp 12100
    Thank you very much.
  8. #32273
    Daelim besbi 2008
    España
    Hi, Ceci
    About 2.12 scheme
    Excellent book, for my taste a real jewel.
    The issue of load stratification if it is in the
  9. #32274
    2.16 Kawasaki ex pipe
    When ex gas temperature rise up, therm element 6 push part 4 closer to cylinder.
  10. #32275
Name:	Kitty Litter.jpg
    The sort of thing you find when your bike has taken a high speed lye-down in the kitty litter.
  11. #32276
    Yeah that's not pretty. Lucky it wasn't on the Rotary side. But I wouldn't count out some injection from bouncing gravel. I really wouldn't.
  12. #32277
    I will check that but after the race finised the bike did manage to quietly put lts way back to the pits.
  13. #32278
    15th May 2017 - 14:26
    2002 Aprlia RS125
    What is the thermostat off?
  14. #32279
    I am hoping that dropping the cylinder and grinding up the C with the sharp edge will give more everywhere - including into the overev.
    Bastard 2T will make a fool of me im sure , but I have to try it.
    Wob, restored C duration show 17,85 hp just at 10185rpm. mid power left the same, over rev little bit better. We never see that before on this particular engine ( previous best before World cup 17,33 hp). Today on track boy said that this is different engine.
    Sorry, I will not be able to answer week or two.
    Thank you very much
  15. #32280
    Wobbly had some made, they hold the water temperature to about 45 deg C. if you are interested in one, PM him to see if he has any left.
    There are a lot of posts on this thread about thermostats. To find them copy this line into your google search bar.
    thermostat site:https://www.kiwibiker.co.nz/forums/s...-engine-tuner?
