Hey! How did you get one not anodised Garish Red?
got a small update guys. after the local machinist was taking so long , i sent the cyls to another place thats a yami twin expert supposedly. still it was several weeks time but finally i have them back in my hands. top and bottom decks were machined flat and the bore is rough bore for now while i do the port grinding. unfortunately the machinist sort of stuffed the bores and went to 68mm (8gr heavier) instead of 66mm. so i have to relocate the ring peg once again and weld the hole in a new set of pistons. not the end of the world but a set back still. to keep the same pin height in 68mm diam and not go the blaster type piston, i had to use wsm. which i believe are rebadged wossner since the package says Germany. anyways the intake side has some small fingers hanging down, do you think theres any concearn they could break off or should i round those off alittle ?
so I started preparing the pistons today. a while back when working on the wisecos I discovered a very fast and good method of removing the ring pin. the dremel discs fit well in the groove and grind off the pin in seconds . if you try it, first practice on some old pistons to get familiar![]()
If you're going to grind out anti rotation pin with a dremel, put the piston in the lathe and the dremel in the tool post so you have full control to not hit the bottom of the ring land.
Another option I've thought about but never done is to drill into the underside of the crown behind where the original pin ends and then push the pin in below ID of ring groove.
PeeWee and Brett, I have tried before but made a mess of mine. So thanks for your great ideas about how to go about removing the pin.
Depending on the height of the groove and the thickness of the disc, you can also use several discs on top of each other. I used to glue paper with superglue to the top and bottom side of the discs to protect the groove a bit, but if you have a calm hand it should work out without this, also.
i tried drilling the pin with all sorts of different bits in a drill press. regular drill bit, various carbide bits. mini dremel disc worked best and by far fastest method. this is just my conclusion. a small stiff fly cutter type of bit might work but i didnt have one. biggest problem i found is most bits i tried, just deflected sideways and buggered the ring groove. i had a fair bit of practice on old pistons. the main thing about dremel discs, do a few practice runs on junk pistons to ensure the groove doesnt get stuffed when its go time on the good pistons but dont over complicate it.![]()
The accuracy of this method depends on front and back of the piston skirt being equally long. And due to the conicity of the piston you cannot check this with a machinist square.
Pistons with a desax้ pin bore, which occurs more often than you might think, won't help either.
My approach for such operations: pull a piece of tight-fitting inner tube over the piston and gently (but not too gently; it's not your sister) clamp it in the lathe.
This won't be sufficiently accurate for a complete ring groove fabrication, but it will do for the limited angle of rotation required to grind away the pin.
There are currently 92 users browsing this thread. (1 members and 91 guests)
