Page 2154 of 2776 FirstFirst ... 11541654205421042144215221532154215521562164220422542654 ... LastLast
Results 32,296 to 32,310 of 41630
  1. #32296
    My approach for such operations: pull a piece of tight-fitting inner tube over the piston and gently (but not too gently; it's not your sister) clamp it in the lathe.
    This won't be sufficiently accurate for a complete ring groove fabrication, but it will do for the limited angle of rotation required to grind away the pin.
    My method is similar, I have had success using masking tape to make up for the taper in the piston. It is also possible by carefull positioning of the chuck jaws to compensate for the piston cam.
Name:	A Piston Skim.jpg
    I have had some success filling away the ring peg with a slim file with the teeth on the flats ground off. Carefully grinding the file to the ring width and slightly radising the edges to protect the sealing surfaces of the ring land worked well.
Name:	Filing the Ring Peg 020.jpg
    The new peg was made from piano wire with it secured by bending the tip over into a hole like Yamaha did on their TZ's.
Name:	Ring Peg 003.jpg
  2. #32297
Name:	No Piston Ring Locating Pin.jpg
ID:	342548 Click image for larger version.
Name:	Piston Ring Turned.jpg
ID:	342547 Click image for larger version.
Name:	Bore Dammage.jpg
    I had problems with Weisco forged pistons. If they got over heated in my air cooled engine the original ring locating pin would move further into its hole and allow the ring to rotate. I needed to find a more reliable way of locating the ring.
    Another option I've thought about but never done is to drill into the underside of the crown behind where the original pin ends and then push the pin in below ID of ring groove.
    Brett's idea may work well, there seems to be plenty of room at the bottom of the Weisco pin hole to be able to punch the ring locating pin down a lot further.
  3. #32298
    13th February 2016 - 09:21
    None
    Holland
    Don't forget soft jaws. Tight, concentric and scratch-free.
  4. #32299
    19th October 2014 - 17:49
    San Francisco
    As an aside, when using tiny drill bits you can bump up the stiffness with a single flute version. I used one of those in carbide to put some oiling holes in case-hardened linear shaft and there was a distinct lack of drama during the operation (much to my relief).
    cheers,
    Michael
  5. #32300
    for the hell of it, i just might pickup one of these to see how well it removes the pins on some old pistons.. in my mind im thinking it could be the bees knees. chuck it up in the drill press jaws and just plunge down. essentially the same as drilling but the cutter is flat on the end with teeth and solid carbide so deflection would likely be nil. should mill the pin away in no time
    https://www.travers.com/4-flute-micr.../p/08-601-038/
  6. #32301
    11th November 2011 - 12:15
    93 kx500
    Aus
    I suppose officially the hole shouldn't be deep enough to let the pin go down too far if the interferance fit is wrong..
    I have had a customer with the issue before on a batch of IAME kart pistons and i suggested to work out where the end of the pin is(cut open a failed one to see pin length) and centerpop the underside of the crown to both stop the pin being able to go in any further and hopefully increase the interferance fit.
    I never heard back from him to know if it fixed the issue.
  7. #32302
    Jeez Brett, just where do you get all these good ideas from ?????
  8. #32303
    The new peg was made from piano wire...
    That is my favorite source. The material is top notch, available in any diameter you need, and one string is enough to modify at least a hundred pistons.
    Did you misspell that name on purpose? Never mind, now I can divulge that I've never seen anything good coming from them, without having to worry about lawsuits.
  9. #32304
    Funny thing,, you discuss moving the pin.
    I have the latest days tested moving one my self as i can´t find desired piston needed for my setup.
    I use a different approach, which i suppose is the 'best' way.
    I use Spark erosion to remove old pin.
    This leaves me with totally untouched ringgroove.
    And when pressing in a new pin i used my cnc mill, drilling a hole with a tungsten 1.5mm diam drilling mill.
    And the pin i made from an shaft of a 1.55mm drillbit.
    Small taper on the end that goes in first in the piston, then just press it in.
    I made the pin go all the way down in the hole i drilled, and by that forcing it to NOT move inwards into the piston, and as my ring closes the gap it won´t let the pin move outwards either.
    And, if worried about spark erosion might spark onto the sides of the groove, one can either paint the piston or mask it with some thin tape.
    Rgds
    Patrick
  10. #32305
    I use a similar one, but,, be aware!
    They need about at least 3000rpm and about at top 0.02mm feed per tooth.
  11. #32306
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    I believe I'm right that the top model has more balancing effect per rotational mass than the lower, and thats what we want right?
  12. #32307
    The efficacy of a balance shaft is dependant upon two factors = m x r.
    If you take the whole mass as being at a single point then that mass at the radius squared is the rotational inertia.
    In the diagram it would appear that the bottom shaft has more eccentric mass within the same outer radius , thus will
    have more rotational ineria effect.
  13. #32308
    sweden
    I'm not shure I followed, say lets design the two to do the same job- then the upper would give faster accelleration?
  14. #32309
    Sure - less ineria = faster acceleration.
    But either you balance the crank properly or you dont - cant have both.
    A crank with no balance shaft simply moves the shake from the vertical to the horizontal plane as the balance % is increased.
    Balance shafts can eliminate the shake altogether, if thats what you want or need,
  15. #32310
    sweden
    But either you balance the crank propderly or you dont - cant have both.
    I Don't intend to compromise the balancing act in any way, just better designed. Damn my minimalism. It must have larger diameter/length/density, but the more centered excentricity I think could make it possible to lose some inertia.
