Page 2156 of 2776 FirstFirst ... 11561656205621062146215421552156215721582166220622562656 ... LastLast
Results 32,326 to 32,340 of 41633
  1. #32326
    I tried this at Garelli.
    Without balancer the engine gave 1,7HP LESS!
    I just removed the drive gear, without 'opening' the engine.....
    *bollocks* i didn´t want to hear that
    I was hoping it was robbing power from me, now it means that i have fucked up
    But the balancer works just fine =)
  2. #32327
    So in Jans case at Garelli , maybe the balance shafts added inertia was a case of the crank needing more inertia anyway.
  3. #32328
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Gordon Blair is Doc Fleck?
  4. #32329
    they are two people Robert Fleck and Gordon Blair, but they were both at QUB
    https://www.researchgate.net/scienti...9_Robert_Fleck
    https://www.researchgate.net/scienti...2926_G_P_Blair
  5. #32330
    sweden
    Makes better logic.
  6. #32331
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    [QUOTE=wobbly;1131137968]So in Jans case at Garelli , maybe the balance shafts added inertia was a case of the crank needing more inertia anyway.[/QUOTE
    Some people were telling me I was crazy putting a balancer in a racing engine, as it would cost power....
    6 years later Honda did it too.
    And the others followed....
    Around the year 2000 heavier crankshafts were tested successfully.
    Aprilia did this on-track
  7. #32332
    [QUOTE=jamathi;1131137992]
    Hi Jan, I would have also thought it would allow you to use lighter engine casing and frame etc as it would need to be as strong to absorb the vibrations for a double benefit.
    I remember an observation made decades before that on a MX bike with a World champ rider that it lapped the track faster with an effective silencer , not because it made more power, but the rider subconsciously backs off the throttle when its too loud.
    I wonder if vibrations would have the same effect on the rider.
  8. #32333
    Once tested my Honda VF500 F2 without generator flywheel, to see how engine react to less inertia, with intention to put on smaller rotor later.
    Immediately effects was very nice, the engine feels faster, riding through corners very light. Motorcycle became so lovely controllable with very nice on and off throttle feeling.
    BUT………..some very terrible sound appear at 8000-9200 rpm interval. Its not vibration, but horrible metallic sound, like crank resonated with deformation without flywheel or something when torque rise up. It feels like engine broke down in minutes. From 9500 to 12000 all goes quite.
    Then put on rotor again and bad sound disappear.
ID:	342629   Click image for larger version.
ID:	342630   Click image for larger version.
ID:	342631   Click image for larger version.
  9. #32334
    The VF400/500 had a 360 Crank compared to the VFR series 180 is that right?
  10. #32335
    Pretty sure both the 400 and 500 camchain VF's were 180 degree cranks. But it's been a long while...
    Katinas, I don't know what your noise was - but I built a VF500 to run in a speedway car without the alternator rotor. In fact, with that end of the crank cut off flush with the end main bearing. No problems with the lower end lasting. Only the idiot driver, unable to read traffic.
  11. #32336
    You remember better than i did.
    Def a 180 degree.
Name:	vf400 crank.jpg
  12. #32337
Name:	The Magician.jpg
ID:	342635 Click image for larger version.
Name:	30hp fourstroke Bucket.jpg
    The first ever 30 rwhp four stroke F4 Bucket.
    New valve springs and an adjust of the rev limiter and that power peak will carry on for another 1000 - 1500 rpm or so. Rev limited to 15,000 at the moment but this engine is proven to be mechanically good for 18.000 RPM.
  13. #32338
    wow unnaturally aspirated 104cc with 30hp
    Very nice work
ID:	342637Click image for larger version.
    PS you spelt FZR wrong
  14. #32339
    Husa, you are right, VF 400 500 is 360 crank.
    VFR 400 750 is 180, the same configuration like on NSR 500 V 90 84-85-86, just 84 rotate backward.
    Grumph, are you used original cdi or programmable, maybe without rotor, engine needed different ignition curve as piston velocity at TDC on compression phase slower than with flywheel. Maybe I need to play little with ignition timing, without rotor.
Name:	VFR 750 (1).jpg
ID:	342645   Click image for larger version.
ID:	342646   Click image for larger version.
Name:	VF 500 (1).jpg
  15. #32340
    VFR 750 is 180, the same configuration like on NSR 500 V 90 84-85-86, just 84 rotate backward.
    Used original ignition. TCI - transistor controlled ignition - not CDI. Run battery powered as total loss. No change to the curve or limiter. Went very well on quarter mile dirt ovals.
    You may be right about the crank configuration - it was some time ago.
    The rotor itself has no effect on the balance factor of the crank. The rotor is balanced as a separate unit. i've never seen a bike crank where the add-on rotor assists or alters the balance factor. On the other hand, it's quite common in cars. A lot of American V8's and V6's have flywheels with assymetric weights to bring the crank into balance.
    It's very common to ditch the alternator rotor on big fourstrokes used for racing. There's invariably enough crank inertia that changing ignition curves to compensate isn't necessary.
