Page 2162 of 2774 FirstFirst ... 11621662206221122152216021612162216321642172221222622662 ... LastLast
Results 32,416 to 32,430 of 41610
  1. #32416
    No........
    I'm lost!
    Tricky but obvious when you see it!
  2. #32417
    After testing every position of Lambda sensors I found the most consistant results are had placing it right at the start of the
    perf in the muffler.
    This seems to " average " the reading over several cycles.
    At the mufflers other exit end the sensor is contaminated with fresh air , being pulsed back and forth by the wave action
    reflecting off atmosphere.
  3. #32418
    I wonder if its a practical possibility .... interesting....
    Interesting discussion paper on High Temp Gas sensing for Automotive use, including 2 Strokes:
    https://www.researchgate.net/publica...ons_-_a_review
    If anyone can possibly do it practically, I'm sure you can.
    Wobbly, what sort of temperatures are present at the start of the muffler?
    If under say 600C, current sensor technology is more than up to the task.
    Cheers Daryl
  4. #32419
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Lubrication and cooling bigend connectionrod.
    As my bigend seized i´m about to rebuild it with a fresh rod, but i´m thinking maybe leave the axial plates/discs on the bigend and guide the rod in the piston instead.
    I figure i might loose some friction also, and by this not build as much heat in the bigend.
    And when having no axial plates/discs there are more space to cool it and lubricate it.
    Is it a good idea?
    Yes, a very good idea!
  5. #32420
    why is not a MAF sensor a good option?
  6. #32421
    Probably would be if it was at the entrance to a large well sealed air box.
    It would probably work particularly well with a multi cylinder like the Suter MMX500 road racer.
  7. #32422
    Use the MAF as a 24/7 flap valve??
    Cheers, Daryl
  8. #32423
    These Guys:
    https://www.google.com/url?sa=t&rct=...azkdvCb41UXgS8
    Used one of these:
    https://docs-emea.rs-online.com/webd...6b815a66d8.pdf
    In the stacks of wood stoves, far outside its rated operating temp, for 150 mins, with results not dissimilar to dedicated industrial units.
    Cheers, Daryl.
  9. #32424
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Is it a good idea?
    Would like to see your evaluation on this, if you proceed.
  10. #32425
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    Is it a good idea?
    RG500 has same arrangement. Be careful with washers material and arrangement as upper bearing is wider than rod.
    Hi everybody, been occupied for time beeing with racing, broken arm, racing WITH broken arm, and v16 diesel burned crankshaft
  11. #32426
    Rocket Science
    Might be Rocket Science:
    https://ntts-prod.s3.amazonaws.com/t...W-TOPS-112.pdf
    NASA is looking for partners to develop & use these in new applications.
    Bleeding Edge 2 Stroke technology might be appropriate, after all there is a technical bonding link, way back to Walter Kaaden, V-1 & 2's & WW2
    cheers, Daryl.
    PS. Don't mention the War! I did once... but I think I got away with it!
  12. #32427
    Hydrocarbon sensors available in NZ for less than 20 Kiwi Dollars.
    http://www.etech.kiwi/4310-gas-sensor-hydrocarbon/
    At that price you could replace them after each Heat (pun intended).
    Cheers, Daryl.
  13. #32428
    most conventional engines has the guiding discs on the big end but suzuki had several engines with guiding discs on the small end as well. if you remember the lt250 and lt500 qaudzilla
  14. #32429
    As was the RGV250
  15. #32430
    I´ll modify the piston to accept the rod with correct clearance, as is now, the rod is wider then inside of piston
There are currently 72 users browsing this thread. (0 members and 72 guests)
