Page 2163 of 2773 FirstFirst ... 11631663206321132153216121622163216421652173221322632663 ... LastLast
Results 32,431 to 32,445 of 41592
  1. #32431
    Successfully relocated pins:
  2. #32432
  3. #32433
    EFFEN Football!!??
    Is this the ESEsWET Jumping the Shark Moment?
    Cheerless Daryl.
  4. #32434
    21st March 2014 - 22:00
    Hanau, Germany
    YZR500 replica..
    May be some of you have seen that, I like it...
    http://forum.2temps.fr/viewtopic.php?f=8&t=19432
  5. #32435
    When designing a crankshaft, Lesson number one: Do NOT exaggerate the interferencefit, sometime somebody maybe want to rebuild it.
    Quite disappointed now as the bolt wouldn´t move when pressing with a shitload of force(over 40tonnes).
    And the material around the lighteningpockets on the inside collapsed instead.
    Sad day.
  6. #32436
    Oh. That's upsetting
  7. #32437
    If the big end and rod are completely ruined the trick is to hold the rod in a vice. And cut through the rod and big end pin with a disk grinder. Then you have the two flywheel halves to deal with separately. Much easier to place one crank half in the press to press the remains of the pin out.
  8. #32438
    28th November 2013 - 21:58
    Dawes Jaguar
    UK
    Presumably it took a lot, or excessive, amount of force to assemble it in the first place, and was difficult to align?
  9. #32439
    It was almost impossible to align the crank i noticed earlier, it took very high forces to get it to move just a couple of thousands of a millimeter.
  10. #32440
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    I once had a similar problem, compounded by a lack of intelligence in failing to support crank halves immediately surrounding the pin and over enthusiastic use of a very large press. Better tooling might have worked, but experience with similar assemblies suggested another approach. Pushing the end of a shaft swells that end and increases the radial pressure against its bore, I've felt this many times where it takes more force to remove a shaft than it took to initially install it, in some cases the increase in force is indeed enough to distort the shaft beyond it's elastic limit, at which point you're buggered.
    One solution is to make the pin hollow, (which is common enough) but not for its full length. Pressing against the bottom of this pin hole is effectively the same as pulling it out, which slightly stretches it, microscopically reducing the diameter, the opposite effect of applying force to the upper face. The force required to disassemble the shaft where I first used that design is about 60% of the original with the same fit.
  11. #32441
    The mother country had this stuff sorted years ago
ID:	342753Click image for larger version.
ID:	342754Click image for larger version.
  12. #32442
    The Yamaha KT100 kart engine used steel plugs inserted in the end of the big end pin to expand it and lock it in place.
    To disassembly it, before pressing, you drilled one plug out and then tapped the other side out with a pin punch.
    I like Ocean1's approch very much.
  13. #32443
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Why not disassemble it from the other dirction, one half at the time?
  14. #32444
    19th October 2014 - 17:49
    San Francisco
    The problem of breaking shafts was solved by fitting a shock absorber.
    Something like old English bikes had....
    It appears that the twin cylinder Seadoo model 580 2T that takes the rotary valve drive from between the cylinders has a spring on the drive shaft that may let the skew gear float a bit which might serve as a damping device.
    cheers,
    Michael
  15. #32445
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    If the sleeve thing doesn't work, we will just lower the exhaust ports and re cast as an FOS cylinder.
    Sorry, I'm curious, your new project is related to this statement.
