Page 2164 of 2776 FirstFirst ... 11641664206421142154216221632164216521662174221422642664 ... LastLast
Results 32,446 to 32,460 of 41630
  1. #32446
    It appears that the twin cylinder Seadoo model 580 2T that takes the rotary valve drive from between the cylinders has a spring on the drive shaft that may let the skew gear float a bit which might serve as a damping device.
    cheers,
    Michael
    When Jan said lik a pommy i was thinking this, it could be the same set up but with the cam so steep and the spring that is so strong it cant go to the next slot in the cam changing the timing?
  2. #32447
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    New Fuel management system soon will be ready to order
    Dont consider it as advertisiment. I going to make smaller version baced on this. The first OPEN SOURCE Tuner Studio compatible Stm32 based engine management system. Unlike Microsquirt or Speeduino it is "real time" system which will allow got max of your engine.
  3. #32448
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Hello,
    Do you have pictures of the v4 swissauto?
    Other than the one that have seen it everywhere
    For example the open crankcase
  4. #32449
    When designing a crankshaft, Lesson number one: Do NOT exaggerate the interferencefit, sometime somebody maybe want to rebuild it.
    Quite disappointed now as the bolt wouldn´t move when pressing with a shitload of force(over 40tonnes).
    And the material around the lighteningpockets on the inside collapsed instead.
    Attachment 342752
    Sad day.
    I have no problem with small crap throwing campaigns directed at me. but leave him out thank.
  5. #32450
    [video=youtube;YD1suLdczv8] The first OPEN SOURCE Tuner Studio compatible Stm32 based engine management system.
    I like that its Tuner Studio compatible and open source. Can you tell us more about its features please.
  6. #32451
    Hello,
    Here is all i have.
    https://www.kiwibiker.co.nz/forums/a...p?albumid=4833
  7. #32452
    1997 Yamaha rd 350
    Russia
    Rusefi
    Please visit forum https://rusefi.com/ and https://rusefi.com/forum to understand better
    Your comments at https://rusefi.com/forum/viewtopic.p...p=34177#p34177 highly appreciated
  8. #32453
    28th November 2013 - 21:58
    Dawes Jaguar
    UK
    Hello,
    Got this one showing the bottom/rear case, although there's a bit of the top/front case behind it.
Name:	MuZ rear case.jpg
  9. #32454
ID:	342775 Click image for larger version.
    Playing on the dyno with Cotswold and Chambers. Cotswold's new 50cc F5 Bucket, 16 rwhp.
  10. #32455
    That's indeed a good effort. Is that with the honda barrel?
    Edit, oh hold on is this the one from his other thread?
  11. #32456
    2nd April 2012 - 00:54
    Exhaust port should be what Wob
  12. #32457
    1988 cagiva freccia
    france
    Thanks you
  13. #32458
    15th May 2017 - 14:26
    2002 Aprlia RS125
    Have any of you guys fitted a dry clutch to a wet clutch bike or modified you bike to run a wet clutch dry.
    What did you adapt? How did it go?
  14. #32459
    I knew someone who tried something along those lines on a customer's VF1000 when they were new. The dry sump was less than successful. He left that line of employment thereafter.
  15. #32460
    23rd March 2015 - 21:24
    Conti RX356 V3
    Didn't do but thought about it for my Derbi 50cc engines. High likely you'll need a longer transmission primary shaft, some mods to the clutch basket to get a sealing surface and a new clutch cover...wasn't worth the effort for me since you'd need quite a few special parts made (read $$$).
There are currently 197 users browsing this thread. (0 members and 197 guests)
