Page 2179 of 2774 FirstFirst ... 11791679207921292169217721782179218021812189222922792679 ... LastLast
Results 32,671 to 32,685 of 41606
  1. #32671
    9th August 2013 - 20:06
    kreidler rs 1976
    Netherlands
    Kawa H2
    Quote Originally Posted by rtechracing View Post
    I just wanted to update you guys on the issue I experienced with the H2 engine previously discussed. Luc had the oportunity to help me and after performing changes according to Luc`s calculations the engine have never been more powerful. We have made a new PB in top speed and ET and is currently second fastest bike in europe with this type of bike. There is still more to come from this engine and it has been a privilege to work with Luc so far and I look forward to future colaboration as well
    I can understand it but don't respect it, taking from the table without contributing in return, would you respect that?
    Ha ha , we bitched about Luc because ( among other things ) we never got one useful piece of actual hard info .
    Now you come on here singing his praises - and funny that , no info about the project.
    So the point of telling us about this is ?
    But you want us to help you - which we can as a group tell you all about the power band dip , its common knowledge.
    Get real.
    rtechracing,
    If you don't get the right information, I'm ready to make the right calculation for you.
    Which will show exactly what is wrong, but only directly and without any information to this forum.
    Everyone was free to help him !
  2. #32672
ID:	343180 very good big end brg.
    Rod kits with this style of flat big end bearing are much better than the old copper coated W bearing which tends to break up.
ID:	343181 not so good big end brg.
  3. #32673
    does anybody know about these conrods ? https://www.ebay.com/itm/Yamaha-RD35....c100010.m2109
    Yeah and as Mike says I built a crank with Long brand rod. Not a good ending. Bit like the picture Mike uses for his avatar.
  4. #32674
    I saw the "L" on the rod and immediately thought "Long" brand, and F5 of course.
  5. #32675
    I dug out a ac cr80 Clutch cover the oher day turns out they bolt onto a MB for those that wanted to delete the oilpump balancer set up to fia RS frame.
    I also found the FZR250 rocker cover i swore i never had, that was for the Grumph engine..
    What I have learnt is Long brand rod kits used to have crap bearings in them. I'd buy genuine MB50 bearings (if they are the same for yours) as I seem to remember they got superceeded by the CR part, but that now listed as MB part is super legal.
    One of the Honda Leads runs the MB/CR big ed as well. either the 100 or 80SS
    With no money for new parts the cycle repeated till I finally rebuilt my now fast engine with a new aftermarket Long brand rodkit. I'd won my first race mostly by luck and speed. Rod snapped. New std parts and it never did it again. Now other parts broke. I spent so much time chasing my tail I never had time to learn to ride.
    The RG changed all that but heck I was in my mid twenties by then.
    Sheesh.
  6. #32676
    24th April 2016 - 19:07
    2001 zx9
    bop
    They are re branded Long brand rods
    I remember someone not being happy with some... Mike?
    but it might have been more to do with the bearing?
    Years ago i remember someone wandering around the "Powder Keg" hotel in Ohakune , half a beer in one hand and half a con-rod in the other telling a sorrow filled story about Long rods... i think he ended up a sad drunk
  7. #32677
    Probably ended up spitting out diced carrots. He did well to walk after a broken rod.
  8. #32678
    rtechracing,
    Not sure why I'm wasting time and forum space writing this, but anyway.
    Why the h-- spend time on a forum intended for sharing knowledge and ideas with such attitude?
    Nothing good will come out of that for anyone, and certainty not for you lucf.
  9. #32679
    Well if it was me, I resent that. I'm not Sad.
    But mine broke in Palmy and the bike shop I bought it from was given it to show the distributor.
  10. #32680
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    Hello
    Long time not posting.
    Sadly the shinning kz kart pistons don't fit the honda T-Port shape. Leaving small entrances from cranckcase to the exhaust port at TDC..
    one more piece for the shelf
    Cheers
  11. #32681
    11th November 2011 - 12:15
    93 kx500
    Aus
    Hello
    Cheers
    Depending on which KZ piston you tried, there may be one that has a larger radius to keep the exhaust covered.
    Last year Meteor released a TM KZ 10C piston that had the larger radius as shown in the pic. Casting 2630 (117gm) on top/left of original style 2311.
    They also have a flat top version the TM factory team was using in 2018 as well with the larger radius.
  12. #32682
    Leiria, Portugal
    Hi.
    Thanks.
    This is actually a Iame piston because I need the 29,50mm height!
    I will contact the dealer if they have this version for IAME
  13. #32683
    6th October 2015 - 13:42
    2001 kx250
    USA
    Pistons
    Hi.
    Thanks.
    Don’t know if this helps but:
    Kawasaki 1994 KX125 Flat Top Piston has a 29.5 Compression Height & a 15mm Pin
    1993 KX125 Flat Top Piston has a 29mm Compression Height & a 16 mm Pin.
  14. #32684
    17th September 2013 - 01:07
    SWE
    Maybe (most likely) posted before, but what the...
    Up here in the north it starts to get dark and cold so everything easing the pain is welcomed.
    Ones again I’m amazed by the Jamathi-story and the complete sacrifice and devotion...and all the success and know how accumulated. And now shared with us through sites like Kiwibiker! ��
    http://www.classic50racingclub.co.uk...the-bikes.html
  15. #32685
