Page 2180 of 2774 FirstFirst ... 11801680208021302170217821792180218121822190223022802680 ... LastLast
Results 32,686 to 32,700 of 41606
  1. #32686
    That is a very interesting bike. I particularly like the chain idler pulley. AS well as neutralizing some of the chain pull effects on suspension geometry. It looks a great way to stop the chain dragging on the swing-arm. I am going to copy the idea for my bike as the chain is slowly cutting its way through the swing-arm pivot on my beast.
ID:	343191 https://www.mcnews.com.au/honda-nsr5...ic-offenstadt/
  2. #32687
    ATK used to do it with two small sprockets one top one bottom.
    https://motocrossactionmag.com/the-r...horst-leitner/
ID:	343192Click image for larger version.
ID:	343193Click image for larger version.
  3. #32688
    19th October 2014 - 17:49
    San Francisco
    The large idler wheel will give a lower RPM at the bearing than the small wheels/sprockets, but it is more difficult to fit in an often crowded space. An idler that locates the bottom run of the chain can adjust the reaction to the lower forces on the over-run.
  4. #32689
    My understanding is that will absorb a decent amount of power, if it gets warm you'll know, but try it on the dyno.
  5. #32690
    19th June 2011 - 00:29
    you also lose the benefits of the chain-effect. there is a reason not a single racing motorcycle uses this ;-)
  6. #32691
    San Francisco
    You can also have too much chain effect which is one reason why so many powerful race bikes have adjustable swing arm pivots. In addition, it may be that they are not so much trying to increase/reduce the chain effects, but to reduce the amount of variation in them in the working area of the rear suspension so the suspension can work smoothly based on contact patch loads and not the chain jerking things around.
    Chris Cosentino has used dual idlers to control chain forces on his Rotacular singles and had them as a design feature on his Moto2 project (thanks for killing that FIM with the "no prototypes" rule):
    http://www.eurospares.com/graphics/c...singleiso2.jpg
  7. #32692
    Countershaft sprocket is nice and close to swingarm pivot.
    C/S is inline with S/A pivot or slightly above.
    This can cause chain to contact the bottom of the Swing arm, during suspension compression.
    C/S sprocket is about as small (13T) as would generally be recommended.
    A larger sprocket would provide more S/A clearance, but require correspondingly larger rear sprocket to maintain ratio.
    (More chain length, more mass, more inertia and more unsprung weight.)
    Idler, as positioned, keeps chain further away from S/A than it would be without one.
    Idler is significantly behind S/A pivot, and located on the frame, not on S/A, so does not really try to eliminate chain length variation through the suspension travel.
    Hence, spring loaded chain tensioner, fitted on bottom of S/A.
    Idler is 'sort of' in line with lower pivot point of suspension unit and might also be intended to direct squat/anti-squat chain forces to the line of action of the rear suspension.
    Is this a good thing? Too many unknowns and variables for me to know.
    But I give 1 point to the builder, for trying something outside the box.
    Cheers, Daryl
  8. #32693
    Totally agree, ....... for trying something outside the box.
  9. #32694
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    BMW G450X had the countershaft sprocket centre in line with the swingarm pivot, so chain tension remained constant and to reduce chain effect on the rear suspension
    (PostalDave on ADVrider)
  10. #32695
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Which is the gimmick Bimota used in the 1970's but had forgot about by the 1990's.
    . . . That shit's Nasty.
  11. #32696
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Old gold Blair. He says 23* spark advance is optimum. How would a kart 250 single spark graph look, like 19* at peak torque?
    Attached Thumbnails Attached Thumbnails Blair500ccSingle.pdf
  12. #32697
    12th October 2016 - 01:24
    1964 Vespa GS
    San Francisco
    Have a scavenging balance question. Is there a recommended target or range for the 'radial scavenging direction resultant'?
    Clearly it's bad if it's greater than 90°, but is 90° the target or is it better to keep the resultant leaning away from the exhaust to keep it attached to the back wall?
    Cylinder I'm starting with has a resultant of 73°
    I understand this method is only a guidance and starting point, but that's where I'm at with this cylinder.
    Patrick Owens
    www.OopsClunkThud.com
  13. #32698
    Quote Originally Posted by OopsClunkThud View Post
    Have a scavenging balance question. Is there a recommended target or range for the 'radial scavenging direction resultant'? Clearly it's bad if it's greater than 90°, but is 90° the target or is it better to keep the resultant leaning away from the exhaust to keep it attached to the back wall? Cylinder I'm starting with has a resultant of 73°.
    With a radial scavenging direction resultant of 73° the scavenging column is leaning away from the exhaust, which in itself is a good thing: no losses.
    But if you wish to maximize the transfer area, you'll also need ports more or less opposite the exhaust port, which will make the scavenging column lean towards the exhaust. A little leaning can be tolerated as a compromise (more area and more losses), but do not go too far past 100°.
  14. #32699
    Blair wrote that this value was for a designed BMEP of 105 psi, or 7,24 bar in real money. That was some time ago, in 1971.
    The Aprilia RSA, a somewhat younger engine (2005), has a BMEP of more than double that, at 16° spark advance. Take your pick.
  15. #32700
    Blairs 500 single was hamstrung by super conservative design elements.
    A square Exhaust port - parallel header - 120mm skinny pipe etc.
    This then results in very low dynamic compression, and with the low bmep generated , peak combustion efficiency was only gained with a ton of advance.
    Modern race engines generate double the bmep , and all end up needing around 15* advance at peak power.
