Page 2183 of 2776 FirstFirst ... 11831683208321332173218121822183218421852193223322832683 ... LastLast
Results 32,731 to 32,745 of 41626
  1. #32731
    The range of ambient air pressure we see in NZ is in the range of 990 to 1020 mBar , and we had no trouble at all of " correcting " this to an arbitrary
    1010 as this was a very common average condition.
    Yes Frits the pressure over area can be huge - sometimes it was all but impossible to open the door into the cell from the control room.
    25*C was chosen again, arbitrarily , as it was nice to be warm in the cell in mid winter and it needed little adjustment during most of summer.
    Bottom line was that the conditions were close to static for all testing - important for comparative purposes when ambient changes have greater effect than the element being changed.
  2. #32732
    In below pic, the 'holes' above the wristpin is shortcircuiting my aux exhaustports with the transfers, Is there any way, easy way of filling these holes?
    JB-Weld, Pour in polyurethane, pour in molten aluminium, anything?
    I have successfully glued the inside of the piston to block the bridge oiler holes.
    Attachment 230863
    The oiler holes for the exhaust bridge need plugging.
    Attachment 230864
    Normaly I would weld them but was persuaded to try gluing them with some super duper stuff that is as tough as shark shit.
    Attachment 230866
    The finished result.
    Attachment 230865
  3. #32733
    The stuff you mentioned: Is that it in the background, Belzona?
  4. #32734
    In below pic, the 'holes' above the wristpin is shortcircuiting my aux exhaustports with the transfers, i have no exchuse, i just measured wrong and now i have this piston, brand new with altered location of the ringstops.
    And to spare me a lot of search of a new piston(67mm) i thought i´d ask an insane question here with the guys that has tested it all, you guys.. =)
    As is now it 'puffs' quite bad into the aux exhaustports when spinning the engine without the head monted.
    Attachment 343232
    Or just search whole world again for a suitable piston.....
    maybe you can put pins from say a needle bearing. also maybe you can grind the side walls at the rear wider. even perhaps the roof at the rear taller. so basically the window gets larger as it goes toward the piston center. this would make it near impossible for epoxy to come out. also theres some over size piston for 250sx and such but I think are 68.5 mm.
  5. #32735
    Yes .......
    Attachment 232140
    After 40+ dyno pulls at near 30hp the glue blocking the oiler holes is still there inside the piston..
  6. #32736
    Yes, i had a slight memory you did =)
    Thanks for the links to the post, i´ll read up again =)
  7. #32737
    I understand completely, i had that thought also
    I can´t bore the cylinder any more, class rules
    I was thinking something like this:
    First, grind some grooves inside the pits,also grind the pit a bit larger then the opening and drill in some 'rebar' to secure it.
    then shotblast the pits to get a rough clean surface.
    Make a mold to get the pistonradious correct, drill small hole in the mold to pour the epoxi inside.
    Heat up the piston some before as it tends to make the epoxi less viscous and grab on to the material better, say about 70-80 degrees.
    Let it harden, and adjust after if necessery.
    I had luck before with jb weld in other locations it seems to take quite good beating with heat, i have also tested added aluminium 'dust' from grinding aluminium into JB-weld, and by that got a very aluminiumlike material.
    This engine is going away from methanol also as i want to test NOS instead
  8. #32738
    EWG standards (k=1,000 @ 990mbar / 25°C / rh 0%)
    Haufen, I cannot figure this out: why on earth would one specify a standard relative humidity of zero percent? It would mean cooling all the incoming air in the test cell (and that is a lot!) down to 0°C in order to condense all H2O vapor, which would require a huge amount of energy, and consequently heating all that air up again to the specified ambient temperature, which would once more devour energy.
    Jan Thiel and myself considered this approach in 1992 when we were working at Rumi, and it turned out that a separate transformer house would have to be installed for that to be possible. It would mean that 98% of all test facilities would not be able to meet the standard.
  9. #32739
    Haufen, I cannot figure this out: why on earth would one specify a standard relative humidity of zero percent? It would mean cooling all the incoming air in the test cell (and that is a lot!) down to 0°C in order to condense all the
    I remember reading something Cameron wrote about the USA Kawasakis tuning operation was all done in the winter on the cold hell hole of a place.
    They made huge HP in testing but for some reason not so much during summer and tended to have cooling issues.
  10. #32740
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Yes it is. While Jan sat on the comfortable side of the double-glazed window, I was squatting next to the engine, wearing a welding helmet with clear glass, and earplugs and hearing protectors, and fiddled with the ignition. It was our first encounter with HCCI; it has taken us decades to understand what was going on back then.
    We were very amazed I remember!
    We were trying to make an ignition advance curve.....
    You could change the timing 10° or more and nothing changed!!!!
    Later, at Aprilia we had a gear-change problem.
    Does this ever happen with kart engines?
  11. #32741
    You don´t copy the exact given enviroment in the dynocell just because the problems involved as you mention.
    You just compensate against that 'standard day' that would be a perfect day, from your numbers on your mediocre day
    If dynoing 30hp on a bad day, the correction says what it might produce that 'perfect day', just to beeing able to compare to others.
  12. #32742
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Andreas, I tested many times 1 alteration with different cut height, on similar Honda NS cylinders. This not changed max power, but rise torque at usual "dip zone" from 7000-8000 rpm.
    Not tried 2 alteration, but this could be very good for piston ported engines. Hans Hummel always used interesting solutions on his cylinders for TZ.
    Yes I remember seeing H Hummels cylinders. I think in your pic 1, and probably 2 (as a double) is the second alt. Here is the same on an old cylinder where things went too far.
    Warning: Photo is not for sensitive viewers.
  13. #32743
    I have successfully done this in the past with a product called scotch weld by manufacturer 3m. You roughen up the piston (do undercuts if you can), clamp an aluminium stripe around it (pour it in soapy water before so that it does not stick as much to the epoxy - use spit if you forgot to prepare the soapy water), then put it in the oven to dry and harden (@120-150°C iirc). Before use, do re-work on the new outer shape of the piston if required.
    I did several of these and all held up perfectly well for many hours at full load on the dyno on an engine with about 12k red line rpm.
    Today, I would, however, roll a small aluminum sheet, cut out the required shape and have it laser welded to the piston.
    Yes that's true. Fortunately, as pointed out be SwePatrick, you don't have to reproduce the exact target conditions, just get as close as you can. The measurement will then be 'valid' if the correction factor is between 0,96 and 1,06 (in EWG there may be other limits for other standards).
    BTW, seems like wobbly is only around 2 hp away from the RSA with his KZ engine, despite all the limitations in the KZ rulebook. Pretty cool stuff!
    (I got these number using the EWG standard to reverse - calculate the performance his KZ engine might have had when tested under the same ambient conditions as the RSA (and an assumed 25% humidity) the KZ would be at 51,9 and the RSA at 54 - both measured under the ambient conditions from wobbly's last dyno chart would leave the KZ at 50,5 and put the RSA at 52,6).
  14. #32744
    it seems like millenium once told me they could apply plating to .36mm thick. this may let you go back to any common 66.4mm 250 piston. other wise devcon titanium putty may be the way to go
  15. #32745
    Detail pictures of KR 500 1979 crankcase
    https://www.ebay.co.uk/itm/Kawasaki-...EAAOSwMcZc3Z~e
